Pasting Graphics Problem in Okular
I see that in Okular if I copy an image on the clipboard,
The paste functionality does not activate in the “Edit” menu.
Am I missing something?
Is there a workflow to paste an image or a snapshot in a PDF using Okular?
Thanks for any help
A good habit to cultivate is to always provide system information (as descibed below) to assist those who might wish to help.
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
Required reading
Resources
Possibly because Okular is not an editing tool.
While it provides means of annotating notes and highlighting texts, it cannot be used to alter the original content beyond recognition.
This. :point_up:
okular is the wrong tool for the job. You need something like perl-pdf-builder (from the Manjaro repositories) or masterpdfeditor (from the AUR) for that.
If you opt for the latter, there is also masterpdfeditor-free, which leaves out the watermark.
There’s also LibreOffice Draw. It is quite complete.
@algarues Yes you can cut Copy and Paste any images you like into or out of a PDF with LibreOffice Draw.
Thanks to everyone for sharing the dos and dont’s with Okular
I marked the post as solved
