I’m a new user. Can’t install any app from repository because it asks for a password and I did not set one is there a default pw to do it? I tried root:manjaro and manjaro:manjaro none worked.
Thanks a lot for your help.
manjaro is running from a usb drive.
Hi and welcome!
If you are using a live environment like the install iso, then the default user is manjaro and the password is manjaro.
If you have installed manjaro on a usb drive, then you need the password of the current user which you have set during the installation.
Hi, megavolt
Ok got it just manjaro worked,
thank you much.
