On my filesystem I have a folder (and subfolders and files) I want password-protected.
it is a native Linux FS (whole partition is LUKS+ext3);
I took into account that root can browse it anyway and good so;
DE is GNOME;
folders are not HOME;
folders can be viewed by root: other users must not without password.
According to my idea, I log in as a user in my session and I cannot normally browse that folder.
Then when I want to access that folder, I get asked for password.
After that, I can freely navigate that folder/subs/file, viewing previews/thumbs.
At its best, that password could automatically time out after a while.
I know I could encrypt folders, but I would avoid it.
I have already tried with chmod 770 + chown XY + chgrp ZZ but, especially when I leave that folder and try to browse it again, I am no longer asked for the password and its content is left freely browsable.
If the folder/files are stored on a non-native Linux file system - exfat and ntfs - encryption is the only way.
With a native Linux file system - even though you can apply permission - which is the first step - this will not prevent a root account from accessing the files/folders.
Files+Thunar+Nemo compain: “A problem has been detected with thumbnail cache. Fixing it will require administrative privileges”. Means should I chmod some folder in that user’s home cache?
No application can read those files;
no thumbnail.
I also tried to sudo usermod -a -G secretGroup casualUser
but without avail.
When I am done with that folder, how can I “unprivilege” it (since it does not automatically time out/log ot)?
Yes, I know I have to gauge hints
I am a bit of a worry because in ancient days I had problems recovering data in emergency from eCryptfs. I am a bit scarried off.
If you are using KDE, I highly recommend plasma-vault
Super easy to setup and very robust and safe. YOU select what method to encrypt with, then just unlock/lock with the applet.
I opted to go with cryfs.
No, I use GNOME but since looking interesting I’ll give it a go!
Right now I am delving with eCryptFS and ACL, the latter being more promising, the former with dangerous deficiencies as stated in Making sure you're not a bot!.
Also, tested GNOME Vaults: installed 130MB deps for 2.4MB app… and didn’t work because of am adwaita version mismatch… uninstalled.
Seems cryfs the most viable solution without too much hassle.
After a couple of hours one discovers that:
it is prone to data corruption;
after setting it up and playing around, - at least on my system - it cannot longer unmount the unencrypted directory;
Switched to gocryptfs: worked at first shot. Go on testing:
was slower at the beginning but works fine now.
TOMB is good: a LUKs FS within my LUKs. Works fine.
