Hi,
since the recent update to NVidia driver 570.xx I have problems unlocking my screen after an automatic screen lock (after inactivity) because the password prompt is missing.
Two weeks ago I still could blindly type my password which then would take 20-30 seconds and a few automatic screen on/off toggles to finally unlock the screen. This is not working anymore. Even after blindly typing the password the screen remains locked.
This only happens when running Plasma in X11 but not when running Wayland. But since Wayland has other problems I would like to keep using X11.
What I have tried so far:
- remove custom background from lockscreen
- switch SDDM/lockscreen theme to other options
- test with Wayland (no lockscreen issue here)
- test with manually locking the screen (no issue, password prompt shows up as expected)
- deleted ~/.cache/* and ~/.Xauthority
- ensured that I have a swap partition enabled
- checked /var/log/Xorg.0.log (no errors or warnings)
[user@host ~]$ inxi --filter --verbosity=8
Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=915e20e5-3c7d-4fdd-89e4-898400ef1a1c rw
resume=UUID=e00e0ab6-6611-48d8-aa55-02fc48975561 udev.log_priority=3
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Desktop System: Gigabyte product: Z690 UD DDR4 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z690 UD DDR4 v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F28
date: 12/14/2023
ID-1: hidpp_battery_0 charge: 100% condition: N/A volts: 4.2 min: N/A
model: Logitech G703 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: full
System RAM: total: 64 GiB available: 62.56 GiB used: 3.17 GiB (5.1%)
Device-1: DDR4-A1 type: no module installed
Device-2: DDR4-A2 type: DDR4 detail: synchronous size: 32 GiB speed:
spec: 2133 MT/s actual: 3200 MT/s volts: curr: 1.35 min: 1 max: 1.35
width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK64GX4M2E3200C16 serial: N/A
Device-3: DDR4-B1 type: no module installed
Device-4: DDR4-B2 type: DDR4 detail: synchronous size: 32 GiB speed:
Info: model: 12th Gen Intel Core i7-12700K bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x38
Topology: cpus: 1x dies: 1 clusters: 9 cores: 12 threads: 20 mt: 8 tpc: 2
st: 4 smt: enabled cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32
KiB, 4x64 KiB L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB
desc: 1x25 MiB
Speed (MHz): avg: 800 min/max: 800/4900:5000:3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 144440
de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pconfig
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand
rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel AlderLake-S GT1 vendor: Gigabyte driver: i915 v: kernel
alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: none empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:4680 class-ID: 0380
Device-2: NVIDIA AD103 [GeForce RTX 4070 Ti SUPER] vendor: CardExpert
driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none
off: DP-3,DP-4 empty: DP-2,HDMI-A-3 bus-ID: 01:00.0 chip-ID: 10de:2705
class-ID: 0300
Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6.4.2:11
chip-ID: 046d:08e5 class-ID: 0102
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x2160 s-dpi: 139 s-size: 1053x392mm (41.46x15.43")
s-diag: 1124mm (44.24")
Monitor-1: DP-3 mapped: DP-2 note: disabled pos: right
model: Idek Iiyama PL2492H serial: <filter> built: 2016 res: mode: 1920x1080
hz: 60 scale: 100% (1) dpi: 93 gamma: 1.2 chroma: red: x: 0.647 y: 0.333
green: x: 0.306 y: 0.616 blue: x: 0.153 y: 0.043 white: x: 0.314 y: 0.329
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
modes: 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x960,
1280x720, 1152x720, 1024x768, 800x600, 720x576, 720x480, 640x480
Monitor-2: DP-4 note: disabled pos: primary,left
model: Idek Iiyama PL3288UH serial: <filter> built: 2020 res:
mode: 3840x2160 hz: 60 scale: 100% (1) dpi: 140 gamma: 1.2 chroma: red:
x: 0.686 y: 0.310 green: x: 0.259 y: 0.686 blue: x: 0.153 y: 0.055 white:
x: 0.314 y: 0.329 size: 698x393mm (27.48x15.47") diag: 801mm (31.5")
ratio: 16:9 modes: 3840x2160, 1920x2160, 2560x1440, 2048x1152, 1920x1200,
1920x1080, 1600x1200, 1680x1050, 1600x900, 1280x1024, 1280x800, 1280x720,
EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
unhandled CEA mode 95 3: parse_edid: unhandled CEA mode 94 4: parse_edid:
unhandled CEA mode 93
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 vendor: nvidia v: 570.133.07 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 4070 Ti SUPER/PCIe/SSE2
memory: 15.62 GiB
API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4070 Ti SUPER driver: nvidia v: 570.133.07
device-ID: 10de:2705 surfaces: xcb,xlib
Device-1: Intel Alder Lake-S HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA vendor: CardExpert driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22bb
class-ID: 0403
API: ALSA v: k6.12.20-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 10.35 TiB used: 3.28 TiB (31.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 45.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 990 EVO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QKXJ7 temp: 47.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST6000DM003-2CY186
size: 5.46 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5425 serial: <filter> fw-rev: 0001 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 1TB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 840 Series
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 9B0Q scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSD5 rev: LV00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 73.24 GiB size: 71.54 GiB (97.68%) used: 45.85 GiB (64.1%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: /
uuid: 915e20e5-3c7d-4fdd-89e4-898400ef1a1c
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 300 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: BOOT
uuid: EB6E-F9EC
ID-3: /data raw-size: 1.91 TiB size: 1.91 TiB (100.00%)
used: 1013.61 GiB (51.9%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18 label: /data
uuid: 211AF22C1F6B486A
ID-4: /devel raw-size: 1.64 TiB size: 1.64 TiB (100.00%)
used: 495.89 GiB (29.5%) fs: ntfs dev: /dev/sdb3 maj-min: 8:19 label: /devel
uuid: 2A3686667D7AB1C6
ID-5: /home raw-size: 1.74 TiB size: 1.71 TiB (98.37%)
used: 151.3 GiB (8.6%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: /home uuid: 99f614aa-420c-456f-8ed8-a24bdfb51142
ID-6: /opt raw-size: 1.91 TiB size: 1.88 TiB (98.38%)
used: 353.49 GiB (18.4%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: /opt
uuid: 71217bea-4f44-462f-9329-428cce46b38f
ID-7: /ssd_opt raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 830.71 GiB (45.3%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:6
label: /ssd_opt uuid: dfa8d35b-f496-473a-836f-08688beb6237
ID-8: /windows raw-size: 292.17 GiB size: 292.17 GiB (100.00%)
used: 151.19 GiB (51.7%) fs: ntfs dev: /dev/sdc3 maj-min: 8:35 label: N/A
uuid: 8AE0B453E0B446EB
ID-9: /windows_opt raw-size: 638.54 GiB size: 638.54 GiB (100.00%)
used: 251.3 GiB (39.4%) fs: ntfs dev: /dev/sdc5 maj-min: 8:37
label: /windows_opt uuid: 302EC2912EC25010
ID-10: /windows_ssd2 raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
used: 63.24 GiB (56.6%) fs: ntfs dev: /dev/sdd1 maj-min: 8:49
label: /windows_ssd_128GB uuid: F6E0FA0FE0F9D5B9
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: e00e0ab6-6611-48d8-aa55-02fc48975561
ID-1: /dev/sda1 maj-min: 8:1 size: 238.47 GiB fs: ntfs label: /windows_ssd2
uuid: 1DA6E41338F4C35E
ID-2: /dev/sdc1 maj-min: 8:33 size: 100 MiB fs: vfat label: N/A
uuid: EAA6-1684
ID-3: /dev/sdc2 maj-min: 8:34 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdc4 maj-min: 8:36 size: 698 MiB fs: ntfs label: N/A
uuid: 52689BA4689B857F
Hub-2: 1-1:2 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2813
Device-1: 1-3:3 info: Canon CanoScan LIDE 25 type: <vendor specific>
driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 04a9:2220 class-ID: ff00
Hub-3: 1-6:4 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-4: 1-6.2:6 info: Genesys Logic Hub ports: 4 rev: 2.1
Hub-5: 1-6.4:8 info: Genesys Logic USB 2.0 Hub / D-Link DUB-H4 ports: 4
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA
chip-ID: 05e3:0606 class-ID: 0900
Device-1: 1-6.4.1:10 info: Logitech Lightspeed Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c539 class-ID: 0300
Device-2: 1-6.4.2:11 info: Logitech C920 PRO HD Webcam type: video,audio
driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.1
Device-3: 1-6.4.3:12 info: Logitech G703 LIGHTSPEED Wireless Gaming Mouse
w/ HERO type: mouse,keyboard,HID driver: logitech-hidpp-device,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 046d:c090 class-ID: 0300 serial: <filter>
Hub-6: 1-9:5 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-11:7 info: Integrated Express RGB LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-2: 1-12:9 info: Logitech G815 Mechanical Keyboard
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c33f class-ID: 0300 serial: <filter>
Hub-7: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
Hub-8: 2-1:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0813
Hub-9: 2-5:3 info: Genesys Logic Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
System Temperatures: cpu: 45.0 C mobo: 36.0 C gpu: nvidia temp: 40 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Packages: pm: pacman pkgs: 1715 libs: 501 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
2: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
3: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 409
1: cpu: 46.5% command: firefox pid: 1799 mem: 551.0 MiB (0.8%)
2: cpu: 29.5% command: thunderbird pid: 1737 mem: 499.3 MiB (0.7%)
3: cpu: 28.4% command: firefox pid: 2167 mem: 235.0 MiB (0.3%)
4: cpu: 13.8% command: plasmashell pid: 1359 mem: 656.8 MiB (1.0%)
5: cpu: 9.5% command: firefox pid: 2104 mem: 214.1 MiB (0.3%)
Memory top: 5 of 409
1: mem: 656.8 MiB (1.0%) command: plasmashell pid: 1359 cpu: 13.8%
2: mem: 551.0 MiB (0.8%) command: firefox pid: 1799 cpu: 46.5%
3: mem: 499.3 MiB (0.7%) command: thunderbird pid: 1737 cpu: 29.5%
4: mem: 235.0 MiB (0.3%) command: firefox pid: 2167 cpu: 28.4%
5: mem: 214.1 MiB (0.3%) command: firefox pid: 2104 cpu: 9.5%
Processes: 409 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.99 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: Bash v: 5.2.37
running-in: konsole inxi: 3.3.38
