Password prompt hidden by splash screen
Installed both the KDE and XFCE editions. Both setup with encryption at installation time
Both had an issue
After unlocking the initial screen with my encryption passphrase I get slot 0 opened and manjaro shows that it is starting. However it just sits there with a screen indicating Manjaro with 3 dots blinking in sequence.
After lots of reboots I accidentally discovered that pressing Esc brings a console that wants me to enter a passphrase
Enter passphrase for /dev/disk/by-uuid/f740f83a-0846-4b7b-a06d-3d42bb141750:
No key available with this passphrase.
After this it then gives an error but continues to boot normally.
That device is the swap partition.
Resolved eventually by changing unlock_method="password" which is the default to ## unlock_method="password" in /etc/openswap.conf.
The default creates a catch-22 situation where the boot process expects you to enter a password in a prompt hidden by the bootsplash and at the same time it cannot verify the pass phrase since the root partition is not properly unlocked.
For reference here’s my config
/etc/openswap.conf
## cryptsetup open $swap_device $crypt_swap_name
## get uuid using e.g. lsblk -f
swap_device=/dev/disk/by-uuid/f740f83a-0846-4b7b-a06d-3d42bb141750
crypt_swap_name=luks-f740f83a-0846-4b7b-a06d-3d42bb141750
## unlock_method can be either password, keyfile or keyfile_raw
## keyfile will use the keyfile_device and keyfile_filename to unlock the swap
## keyfile_raw will use the keyfile_device and keyfile_block_number to unlock the swap
## password will prompt for the password to unlock the swap
## if unlock_method is not set, then method is keyfile if keyfile_device and keyfile_filename are set
## otherwise it is password
####### WARNING: There is a risk of data loss when using unlock_method="keyfile"
## You should double-check keyfile_device_mount_options,
## and note that this method is potentially dangerous regardless.
## https://docs.kernel.org/power/swsusp.html
## https://wiki.archlinux.org/title/Dm-crypt/Swap_encryption#busybox-based_initramfs
## keyfile_device is the device that contains the keyfile
## set it to the device that contains the keyfile
## e.g. /dev/mapper/root-device
####### THIS OPTION IS MANDATORY IF unlock_method IS keyfile OR keyfile_raw
keyfile_device=/dev/mapper/luks-310ed4f0-a4f1-4b48-b117-c9166f679cdc
## keyfile_filename is the path to the keyfile on the keyfile_device
## e.g. /etc/swap.key
keyfile_filename=crypto_keyfile.bin
## keyfile_block_number is the block number of the keyfile on the keyfile_device
## e.g. 12345
## on the ext4 filesystem, you can get the block number using
## debugfs $keyfile_device
## extents $keyfile_filename
## the relevant block number will appear under the Physical column in the output
####### THIS OPTION IS MANDATORY IF unlock_method IS keyfile_raw
#keyfile_block_number=
## key_size is the size of the key in bytes
## e.g., 4096
## This is the size of the keyfile and should match the actual size of the keyfile.
## You can get the size of the keyfile using: wc -c <keyfile_filename>
## The openswap script will fail if the keyfile is fragmented,
## so keyfile_length should not exceed the filesystem block size.
## For ext4 filesystems, keyfile_length should not exceed 4096 bytes,
## and it SHOULD be greater than ~200 bytes to avoid inode inlining.
#keyfile_length=4096
## additional arguments are given to mount for keyfile_device
## has to start with --options
## it is important to use the correct options for your filesystem
## to prevent any writes to the keyfile device and thus
## minimize the risk of data loss
#keyfile_device_mount_options="--options=subvol=__active/__"
keyfile_device_mount_options=--options=subvol=@
## additional arguments are given to cryptsetup
## --allow-discards options is desired in case swap is on SSD partition
cryptsetup_options="--type luks"
sudo sed -i 's/unlock_method="password"/unlock_method="keyfile"/g' /etc/openswap.conf
Thanks. Had not seen that one. It would have saved me a lot of grief.
Problem is that this had always been working so whatever has changed in the new ISOs will cause a lot of people some grief.
There is also the option to disable the splash screen instead of changing unlock_method
[HowTo] Disable or Remove Plymouth (boot splash)
Unlocking the splash screen wont resolve :backhand_index_pointing_up: but the good thing with disabling is that one will be now aware there’s a 2nd prompt for passphrase even though it will not accept the correct passphrase but at least will continue with boot up after failing.
