Hello dear Manjaro forum members,
on my brothers machine I’ve installed and configured boinc-nox today and ran the most recent updates. I didn’t reboot after the update and suddenly, during the running SSH session the password stopped working. Since then the machine got rebooted (autologin) and the PW still doesn’t work. The PW is not accepted via SSH and not via the keyboard attached. I’m at a loss here…
The machine is usable as a living room PC, but without the PW working this might get complicated.
inxi --full --verbosity=7 --filter --no-host
System: Kernel: 5.7.17-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Console: tty 1 DM: LightDM 1.30.0
Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASRock model: A300M-STX serial: <filter> UEFI: American Megatrends v: P3.60
date: 10/28/2019
Memory: RAM: total: 5.80 GiB used: 655.0 MiB (11.0%)
CPU: Topology: Quad Core model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP arch: Zen+
rev: 1 L2 cache: 2048 KiB bogomips: 28812
Speed: 1262 MHz min/max: 1400/3600 MHz boost: enabled Core speeds (MHz): 1: 1260 2: 1266 3: 1260 4: 1260
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext clflush clflushopt
clzero cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca mce
misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge
pni popcnt pse pse36 rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale v_vmsave_vmload
vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Picasso driver: amdgpu v: kernel bus ID: 03:00.0
chip ID: 1002:15d8
Display: server: X.org 1.20.8 driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa tty: 119x39
Message: Advanced graphics data unavailable in console. Try -G --display
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus ID: 03:00.1 chip ID: 1002:15de
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus ID: 03:00.6 chip ID: 1022:15e3
Device-3: Creative SB X-Fi Surround 5.1 Pro type: USB driver: snd-usb-audio bus ID: 1-2:2
chip ID: 041e:30df serial: <filter>
Device-4: Corsair CORSAIR HS70 Pro Wireless Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-1:2 chip ID: 1b1c:0a4f
Sound Server: ALSA v: k5.7.17-2-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8169 v: kernel
port: f000 bus ID: 02:00.0 chip ID: 10ec:8168
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
IP v6: <filter> type: deprecated dynamic noprefixroute scope: global
WAN IP: No WAN IP found. Connected to web? SSL issues? Try --no-dig
Drives: Local Storage: total: 465.76 GiB used: 167.36 GiB (35.9%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS500G2B0C-00PXH0 size: 465.76 GiB speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 211070WD scheme: GPT
RAID: Message: No RAID data was found.
Partition: ID-1: / size: 457.16 GiB used: 167.35 GiB (36.6%) fs: ext4 dev: /dev/nvme0n1p2 label: N/A
uuid: 6d3b06b6-82e6-45ce-ad6f-4d26809184e1
ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 label: N/A
uuid: AA00-8706
Swap: Alert: No Swap data was found.
Unmounted: Message: No unmounted partitions found.
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-2:2 info: Creative SB X-Fi Surround 5.1 Pro type: Audio driver: snd-usb-audio interfaces: 3
rev: 1.1 speed: 12 Mb/s chip ID: 041e:30df serial: <filter>
Hub: 1-3:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 05e3:0608
Hub: 1-3.2:4 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s chip ID: 2109:2813
Device-1: 1-3.2.1:7 info: MosArt Wireless Mouse type: Mouse driver: hid-generic,usbhid interfaces: 1
rev: 1.1 speed: 12 Mb/s chip ID: 062a:4102
Device-2: 1-3.2.2:5 info: Shenzhen Riitek wireless mini keyboard with touchpad type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 1997:2433
Hub: 1-3.2.4:6 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s chip ID: 2109:2813
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 3-1:2 info: Corsair CORSAIR HS70 Pro Wireless Gaming Headset type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s chip ID: 1b1c:0a4f
Hub: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 41.5 C mobo: N/A gpu: amdgpu temp: 35 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1549 fan-3: 0 fan-4: 0 fan-5: 0
Info: Processes: 189 Uptime: 17m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1016 Shell: Zsh
v: 5.8 running in: tty 1 (SSH) inxi: 3.1.05
