Partitions are not aligned correctly
Hello,
there is a remark in the KDE partition management log. Actually everything works. That means I can read and write all my partition, but still the entries worry me.
I basically have 4 hard disks in the system, two of which are affected by the messages.
My second Kingston is affected three times and my fourth Samsung also receives a message.
My Kingston is set up like this:
1MB are unallocated before the first partition
1st partition: dev/sdb1 300MB Fat32 Boot/efi
2nd partition: dev/sdb2 103GB ext4 root
3rd partition: dev/sdb3 8.29GB Linux swap
after that approx. 2.5MB unused
my Samsung is an external USB disk, which is completely intended for Backup and set up like this:
1st partition : dev/sdd1 here was a 16MB partition reserved for Microsoft, which I had simply left untouched.
2nd partition: dev/sdd2 477GB ext4 home backup
3rd partition: dev/sdd3 68GB ext4 root backup
4th partition: dev/sdd4 152GB NTFS Windows backup
The output of the log would be
2024-08-04 18:01:06: Use backend module: pmsfdiskbackendplugin (1)
2024-08-04 18:01:06: Devices are searched ...
2024-08-04 18:01:06: Device found: CT2000BX500SSD1
2024-08-04 18:01:06: Device found: KINGSTON SA400S37120G
2024-08-04 18:01:06: The partition "/dev/sdb2" is not correctly aligned (last sector: 217.051.457, modulo: 322).
2024-08-04 18:01:06: The partition "/dev/sdb3" is not correctly aligned (first sector: 217.051.458, modulo: 322).
2024-08-04 18:01:06: The partition "/dev/sdb3" is not correctly aligned (last sector: 234.436.544, modulo: 1.985).
2024-08-04 18:01:07: Device found: WDC WD15EADS-00P8B0
2024-08-04 18:01:08: Device found: ST750LM022 HN-M750MBB
2024-08-04 18:01:09: The partition "/dev/sdd1" is not correctly aligned (first sector: 34, modulo: 34).
2024-08-04 18:01:10: Search finished.
How can this misalignment be corrected and where does it come from?
This happens occasionally when using the KDE partitioner and the Calamares installer combination.
You can fix this misalignment using GParted installed to a bootable Manjaro Live DVD/ISO/USB. Resize the partition by even a small amount (1 MB), and the partition should extend to the next available (1 MB increment) boundary.
If the partition in question is / (root), then only resize from the end of the partition (the right side, as it appears in GParted).
GParted is a GUI tool which can be installed to memory on a Manjaro Live Installer as easily as in your own user account.
sudo pacman -S gparted
I hope this helps. Cheers.
This is indeed the combination I used, as the most obvious thing to do is to use the existing software.
Yes, that is the case, which means that I can no longer correct all the alignments in the current installation, but would have to completely reinstall my Linux, which I think is exaggerated, since I don’t notice any problems.
Thanks for the information, it’s really very helpful, it’s just a shame that I’m only finding out about it now.
Reinstalling shouldn’t be necessary; especially if the misalignment is at the end (right side) of / – Whatever partition is next to it (on the right) can be shrunk by 1 MB, and then / (root) can be extended (to the right) by 1 MB to fill the space.
The procedure is generally non-destructive.
I should also mention that some people just choose to ignore it, though, it’s still irritating to know the issue exists, and not fix it. :smile_cat:
Cheers.
