When I try to open KDE Partition Manager, after typing the root password the application closes.
I tried to launch it using a Terminal and the information was this …
partitionmanager
Loaded backend plugin: “pmsfdiskbackendplugin”
“Using backend plugin: pmsfdiskbackendplugin (1)”
“Scanning devices…”
“Device found: Samsung SSD 970 EVO Plus 500GB”
getting temp failed for “/dev/nvme0n1” : Success
getting powered on time failed for “/dev/nvme0n1” : Success
getting power cycles failed for “/dev/nvme0n1” : Success
Segmentation fault (core dumped)
the GUI doesn’t show up at all and the answer is …
[sudo] password for knight:
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to ‘/tmp/runtime-root’
“Session bus not found\nTo circumvent this problem try the following command (with Linux and bash)\nexport $(dbus-launch)”
Without sudo, now the answer is …
Loaded backend plugin: "pmsfdiskbackendplugin"
"Using backend plugin: pmsfdiskbackendplugin (1)"
"Scanning devices..."
smartctl initialization failed for "/dev/loop0" : No such file or directory
error during smart output parsing for "/dev/loop0" : No such file or directory
"Device found: loop0"
unknown file system type "" on "/dev/loop0"
Maybe there’s a problem with the SSD where I have installed the system, Samsung SSD 970 EVO Plus.
I have 5 drives … 1 NVMe SSD, 1 SSD SATA, and 3 HDD SATA.
They all work perfectly.
I don’t even use that app, i just wanted to rule-out root privileges.
Never thought about it using the XDG_RUNTIME_DIR
Anyway disregard that reply then
Could it be a problem with the firmware of the Samsung SSD 970 EVO Plus?
I don’t think so, because I’ve installed GParted and it works properly.
It seems the problem is with this application only.
I understood nothing from your comment.
Install symbols?
Inside gdb? What’s gdb?
DrKonqi? What’s that?
I’m sorry, I thought I knew about Linux but it’s obvious I’m not there yet.
