Hi. After resuming from sleep I’m able to log in (albeit with some lagginess when unlocking) but KDE plasma shell is mostly unresponsive and for example the network (wifi) is disconnected.
What is also strange is that I’m able to continue working (without wifi) but for example if I try to use ‘sudo’, it doesn’t ask for a password and just hangs (I can’t ctrl+c out of it).
Output from inxi
System: Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=c480e883-aea6-4e9b-b1d0-4a30959bab52 rw quiet
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: LightDM 1.30.0, SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: TOSHIBA product: SATELLITE PRO U200 v: PLUA1E-01901KN5 serial: <filter> Chassis:
type: 10 v: Version 1.0 serial: <filter>
Mobo: TOSHIBA model: Portable PC v: Version A0 serial: <filter> BIOS: TOSHIBA v: Version 3.40
date: 02/14/2007
Battery: ID-1: BAT1 charge: 5.3 Wh condition: 5.3/50.8 Wh (10%) volts: 11.2/10.8 model: G71C0004G810 type: Li-ion
serial: <filter> status: Full
Memory: RAM: total: 1.93 GiB used: 1.42 GiB (73.6%)
CPU: Info: Dual Core model: Intel Core2 T7200 bits: 64 type: MCP arch: Core Merom family: 6 model-id: F (15)
stepping: 6 microcode: D1 L2 cache: 4 MiB bogomips: 7982
Speed: 1223 MHz min/max: 1000/2000 MHz Core speeds (MHz): 1: 1223 2: 1208
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64
dtherm dts est fpu fxsr ht lahf_lm lm mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse
pse36 pti rep_good sep sse sse2 ssse3 syscall tm tm2 tsc vme xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: Intel Mobile 945GM/GMS 943/940GML Express Integrated Graphics vendor: Toshiba driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:27a2
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.3x8.3") s-diag: 398mm (15.7")
Monitor-1: LVDS1 res: 1280x800 hz: 60 dpi: 125 size: 260x160mm (10.2x6.3") diag: 305mm (12")
OpenGL: renderer: Mesa DRI Intel 945GM v: 1.4 Mesa 20.3.1 direct render: Yes
Audio: Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: Toshiba driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:27d8
Sound Server: ALSA v: k5.10.2-2-MANJARO
Network: Device-1: Intel PRO/Wireless 3945ABG [Golan] Network driver: iwl3945 v: in-tree:ds port: afa0
bus ID: 02:00.0 chip ID: 8086:4222
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Intel PRO/100 VE Network vendor: Toshiba driver: e100 v: kernel port: bf40 bus ID: 03:08.0
chip ID: 8086:1092
IF: enp3s8 state: down mac: <filter>
RAID: Message: No RAID data was found.
Drives: Local Storage: total: 93.16 GiB used: 15.93 GiB (17.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS541010G9SA00 size: 93.16 GiB block size:
physical: 512 B logical: 512 B speed: <unknown> serial: <filter> rev: C60R
Optical-1: /dev/sr0 vendor: ■■■■■■■■ model: DVD-RAM UJ-842S rev: 1.40 dev-links: cdrom
Features: speed: 24 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
Partition: ID-1: / raw size: 93.16 GiB size: 91.19 GiB (97.89%) used: 15.93 GiB (17.5%) fs: ext4 dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: c480e883-aea6-4e9b-b1d0-4a30959bab52
Swap: Alert: No Swap data was found.
Unmounted: Message: No Unmounted partitions found.
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 8 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip ID: 1d6b:0001
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip ID: 1d6b:0001
Device-1: 3-1:2 info: STMicro Fingerprint Reader type: <vendor specific> driver: N/A interfaces: 1 rev: 1.0
speed: 12 Mb/s chip ID: 0483:2016
Device-2: 3-2:3 info: Toshiba Integrated Bluetooth HCI type: Bluetooth driver: btusb interfaces: 3 rev: 2.0
speed: 12 Mb/s chip ID: 0930:0508
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip ID: 1d6b:0001
Hub: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip ID: 1d6b:0001
Sensors: System Temperatures: cpu: 52.0 C mobo: N/A
Info: Processes: 163 Uptime: 15m wakeups: 1 Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: 1322
pacman: 1312 lib: 411 flatpak: 4 snap: 6 Shell: Bash v: 5.1.0 running in: yakuake inxi: 3.2.01
Output from journald
-- Journal begins at Thu 2020-08-27 00:42:12 EEST, ends at Tue 2021-01-05 22:16:13 EET. --
tammi 05 22:11:15 kisu-laptop systemd-logind[338]: Lid closed.
tammi 05 22:11:15 kisu-laptop ModemManager[638]: <info> [sleep-monitor] system is about to suspend
tammi 05 22:11:15 kisu-laptop kded5[1027]: bluedevil: About to suspend
tammi 05 22:11:15 kisu-laptop kernel: audit: type=1130 audit(1609877475.528:110): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:11:15 kisu-laptop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:11:15 kisu-laptop dbus-daemon[332]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=333 comm="/usr/bin/NetworkManager --no-daemon ")
tammi 05 22:11:15 kisu-laptop NetworkManager[333]: <info> [1609877475.4852] manager: sleep: sleep requested (sleeping: no enabled: yes)
tammi 05 22:11:15 kisu-laptop dbus-daemon[332]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
tammi 05 22:11:15 kisu-laptop NetworkManager[333]: <info> [1609877475.4854] manager: NetworkManager state is now ASLEEP
tammi 05 22:11:15 kisu-laptop NetworkManager[333]: <info> [1609877475.4857] device (wlp2s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
tammi 05 22:11:15 kisu-laptop kded5[1027]: plasma-nm: Unhandled active connection state change: 3
tammi 05 22:11:15 kisu-laptop systemd[1]: Starting Network Manager Script Dispatcher Service...
tammi 05 22:11:15 kisu-laptop systemd[1]: Started Network Manager Script Dispatcher Service.
tammi 05 22:11:15 kisu-laptop kernel: wlp2s0: deauthenticating from 54:83:3a:1d:37:71 by local choice (Reason: 3=DEAUTH_LEAVING)
tammi 05 22:11:15 kisu-laptop wpa_supplicant[1313]: wlp2s0: CTRL-EVENT-DISCONNECTED bssid=54:83:3a:1d:37:71 reason=3 locally_generated=1
tammi 05 22:11:15 kisu-laptop NetworkManager[333]: <info> [1609877475.7604] device (wlp2s0): supplicant interface state: completed -> disconnected
tammi 05 22:11:15 kisu-laptop NetworkManager[333]: <info> [1609877475.7631] device (wlp2s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
tammi 05 22:11:15 kisu-laptop wpa_supplicant[1313]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
tammi 05 22:11:15 kisu-laptop avahi-daemon[330]: Withdrawing address record for 2001:2003:f758:9b00:2f7e:a0f3:8747:bb22 on wlp2s0.
tammi 05 22:11:15 kisu-laptop avahi-daemon[330]: Leaving mDNS multicast group on interface wlp2s0.IPv6 with address 2001:2003:f758:9b00:2f7e:a0f3:8747:bb22.
tammi 05 22:11:15 kisu-laptop avahi-daemon[330]: Joining mDNS multicast group on interface wlp2s0.IPv6 with address fe80::b14a:b531:b4a5:8121.
tammi 05 22:11:15 kisu-laptop avahi-daemon[330]: Registering new address record for fe80::b14a:b531:b4a5:8121 on wlp2s0.*.
tammi 05 22:11:15 kisu-laptop avahi-daemon[330]: Withdrawing address record for fe80::b14a:b531:b4a5:8121 on wlp2s0.
tammi 05 22:11:15 kisu-laptop avahi-daemon[330]: Leaving mDNS multicast group on interface wlp2s0.IPv6 with address fe80::b14a:b531:b4a5:8121.
tammi 05 22:11:15 kisu-laptop avahi-daemon[330]: Interface wlp2s0.IPv6 no longer relevant for mDNS.
tammi 05 22:11:15 kisu-laptop NetworkManager[333]: <info> [1609877475.7748] dhcp4 (wlp2s0): canceled DHCP transaction
tammi 05 22:11:15 kisu-laptop NetworkManager[333]: <info> [1609877475.7749] dhcp4 (wlp2s0): state changed bound -> done
tammi 05 22:11:15 kisu-laptop NetworkManager[333]: <info> [1609877475.7783] dhcp6 (wlp2s0): canceled DHCP transaction
tammi 05 22:11:15 kisu-laptop NetworkManager[333]: <info> [1609877475.7787] dhcp6 (wlp2s0): state changed bound -> done
tammi 05 22:11:15 kisu-laptop avahi-daemon[330]: Interface wlp2s0.IPv4 no longer relevant for mDNS.
tammi 05 22:11:15 kisu-laptop avahi-daemon[330]: Leaving mDNS multicast group on interface wlp2s0.IPv4 with address 192.168.1.192.
tammi 05 22:11:15 kisu-laptop avahi-daemon[330]: Withdrawing address record for 192.168.1.192 on wlp2s0.
tammi 05 22:11:15 kisu-laptop NetworkManager[333]: <info> [1609877475.7958] device (wlp2s0): set-hw-addr: set MAC address to 0A:0A:AC:8D:55:5E (scanning)
tammi 05 22:11:15 kisu-laptop avahi-daemon[330]: Joining mDNS multicast group on interface wlp2s0.IPv4 with address 192.168.1.192.
tammi 05 22:11:15 kisu-laptop avahi-daemon[330]: New relevant interface wlp2s0.IPv4 for mDNS.
tammi 05 22:11:15 kisu-laptop avahi-daemon[330]: Registering new address record for 192.168.1.192 on wlp2s0.IPv4.
tammi 05 22:11:16 kisu-laptop NetworkManager[333]: <info> [1609877476.0367] device (wlp2s0): supplicant interface state: disconnected -> interface_disabled
tammi 05 22:11:16 kisu-laptop NetworkManager[333]: <info> [1609877476.0369] device (wlp2s0): supplicant interface state: interface_disabled -> disconnected
tammi 05 22:11:16 kisu-laptop NetworkManager[333]: <info> [1609877476.0376] device (wlp2s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
tammi 05 22:11:16 kisu-laptop kded5[1027]: plasma-nm: Not emitting connection deactivated notification as we're about to suspend
tammi 05 22:11:16 kisu-laptop NetworkManager[333]: <info> [1609877476.0496] device (wlp2s0): set-hw-addr: reset MAC address to 00:19:D2:53:79:8E (unmanage)
tammi 05 22:11:16 kisu-laptop kscreenlocker_greet[1956]: Qt: Session management error: networkIdsList argument is NULL
tammi 05 22:11:16 kisu-laptop wpa_supplicant[1313]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
tammi 05 22:11:16 kisu-laptop kscreenlocker_greet[1956]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/lockscreen/LockScreen.qml:52:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
tammi 05 22:11:16 kisu-laptop systemd[1]: Reached target Sleep.
tammi 05 22:11:16 kisu-laptop systemd[1]: Starting Suspend...
tammi 05 22:11:17 kisu-laptop kscreenlocker_greet[1956]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
tammi 05 22:11:17 kisu-laptop kscreenlocker_greet[1956]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
tammi 05 22:11:17 kisu-laptop systemd-sleep[1966]: Suspending system...
tammi 05 22:11:17 kisu-laptop kernel: PM: suspend entry (deep)
tammi 05 22:11:17 kisu-laptop kscreenlocker_greet[1956]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/lockscreen/MainBlock.qml:79:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
tammi 05 22:11:17 kisu-laptop kscreenlocker_greet[1956]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/lockscreen/LockScreenUi.qml:35:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
tammi 05 22:11:27 kisu-laptop kernel: Filesystems sync: 0.794 seconds
tammi 05 22:11:27 kisu-laptop kernel: Freezing user space processes ... (elapsed 0.003 seconds) done.
tammi 05 22:11:27 kisu-laptop kernel: OOM killer disabled.
tammi 05 22:11:27 kisu-laptop kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
tammi 05 22:11:27 kisu-laptop kernel: printk: Suspending console(s) (use no_console_suspend to debug)
tammi 05 22:11:27 kisu-laptop kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
tammi 05 22:11:27 kisu-laptop kernel: sd 0:0:0:0: [sda] Stopping disk
tammi 05 22:11:27 kisu-laptop kernel: ACPI: Preparing to enter system sleep state S3
tammi 05 22:11:27 kisu-laptop kernel: PM: Saving platform NVS memory
tammi 05 22:11:27 kisu-laptop kernel: Disabling non-boot CPUs ...
tammi 05 22:11:27 kisu-laptop kernel: smpboot: CPU 1 is now offline
tammi 05 22:11:27 kisu-laptop kernel: ACPI: Low-level resume complete
tammi 05 22:11:27 kisu-laptop kernel: PM: Restoring platform NVS memory
tammi 05 22:11:27 kisu-laptop kernel: Enabling non-boot CPUs ...
tammi 05 22:11:27 kisu-laptop kernel: x86: Booting SMP configuration:
tammi 05 22:11:27 kisu-laptop kernel: smpboot: Booting Node 0 Processor 1 APIC 0x1
tammi 05 22:11:27 kisu-laptop kernel: ACPI: \_PR_.CPU1: Found 3 idle states
tammi 05 22:11:27 kisu-laptop kernel: CPU1 is up
tammi 05 22:11:27 kisu-laptop kernel: ACPI: Waking up from system sleep state S3
tammi 05 22:11:27 kisu-laptop kernel: usb usb2: root hub lost power or was reset
tammi 05 22:11:27 kisu-laptop kernel: usb usb3: root hub lost power or was reset
tammi 05 22:11:27 kisu-laptop kernel: usb usb4: root hub lost power or was reset
tammi 05 22:11:27 kisu-laptop kernel: usb usb5: root hub lost power or was reset
tammi 05 22:11:27 kisu-laptop kernel: sd 0:0:0:0: [sda] Starting disk
tammi 05 22:11:27 kisu-laptop kernel: ata2.00: ACPI cmd ef/03:0c:00:00:00:00 (SET FEATURES) filtered out
tammi 05 22:11:27 kisu-laptop kernel: ata2.00: ACPI cmd ef/03:42:00:00:00:00 (SET FEATURES) filtered out
tammi 05 22:11:27 kisu-laptop kernel: usb 3-1: reset full-speed USB device number 2 using uhci_hcd
tammi 05 22:11:27 kisu-laptop kernel: firewire_core 0000:03:0b.1: rediscovered device fw0
tammi 05 22:11:27 kisu-laptop kernel: ata1.00: ACPI cmd ef/03:0c:00:00:00:00 (SET FEATURES) filtered out
tammi 05 22:11:27 kisu-laptop kernel: ata1.00: ACPI cmd ef/03:45:00:00:00:00 (SET FEATURES) filtered out
tammi 05 22:11:27 kisu-laptop kernel: OOM killer enabled.
tammi 05 22:11:27 kisu-laptop kernel: Restarting tasks ... done.
tammi 05 22:11:27 kisu-laptop kernel: video LNXVIDEO:00: Restoring backlight state
tammi 05 22:11:27 kisu-laptop kernel: PM: suspend exit
tammi 05 22:11:27 kisu-laptop kernel: usb 3-2: USB disconnect, device number 3
tammi 05 22:11:27 kisu-laptop systemd-sleep[1966]: System resumed.
tammi 05 22:11:27 kisu-laptop bluetoothd[502]: Endpoint unregistered: sender=:1.44 path=/MediaEndpoint/A2DPSink/sbc
tammi 05 22:11:27 kisu-laptop systemd-logind[338]: Lid opened.
tammi 05 22:11:27 kisu-laptop bluetoothd[502]: Endpoint unregistered: sender=:1.44 path=/MediaEndpoint/A2DPSource/sbc
tammi 05 22:11:27 kisu-laptop systemd[1]: Starting Load/Save RF Kill Switch Status...
tammi 05 22:11:28 kisu-laptop upowerd[904]: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.1/usb3/3-1
tammi 05 22:11:28 kisu-laptop systemd[1]: Stopped target Bluetooth.
tammi 05 22:11:28 kisu-laptop systemd[1]: Started Load/Save RF Kill Switch Status.
tammi 05 22:11:28 kisu-laptop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: qt.svg: <input>:406:376: Could not add child element to parent element because the types are incorrect.
tammi 05 22:11:28 kisu-laptop kernel: audit: type=1130 audit(1609877488.103:111): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: qt.svg: <input>:407:130: Could not add child element to parent element because the types are incorrect.
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: qt.svg: <input>:408:130: Could not add child element to parent element because the types are incorrect.
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: qt.svg: <input>:408:393: Could not add child element to parent element because the types are incorrect.
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: qt.svg: <input>:409:130: Could not add child element to parent element because the types are incorrect.
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: qt.svg: <input>:410:129: Could not add child element to parent element because the types are incorrect.
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: qt.svg: <input>:411:129: Could not add child element to parent element because the types are incorrect.
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: qt.svg: <input>:412:129: Could not add child element to parent element because the types are incorrect.
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: qt.svg: <input>:413:129: Could not add child element to parent element because the types are incorrect.
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: qt.svg: <input>:413:379: Could not add child element to parent element because the types are incorrect.
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: qt.svg: <input>:413:631: Could not add child element to parent element because the types are incorrect.
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Autumn" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Breath2" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/BytheWater" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Canopee" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Cascade" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Cluster" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/ColdRipple" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/ColorfulCups" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/DarkestHour" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Elarun" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/EveningGlow" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/FallenLeaf" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Flow" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/FlyingKonqui" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Grey" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/IceCold" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Kite" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Kokkini" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Next" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/OneStandsOut" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Opal" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/PastelHills" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Path" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/SafeLanding" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/summer_1am" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Volna" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds/manjaro-wallpapers-18.0" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds/wallpapers-2018" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds/wallpapers-juhraya" is a directory. Use addDir!
tammi 05 22:11:28 kisu-laptop kscreenlocker_greet[1956]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
tammi 05 22:11:28 kisu-laptop systemd[1]: systemd-suspend.service: Succeeded.
tammi 05 22:11:28 kisu-laptop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:11:28 kisu-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:11:28 kisu-laptop systemd[1]: Finished Suspend.
tammi 05 22:11:28 kisu-laptop systemd[1]: Stopped target Sleep.
tammi 05 22:11:28 kisu-laptop systemd[1]: Reached target Suspend.
tammi 05 22:11:28 kisu-laptop systemd[1]: Stopped target Suspend.
tammi 05 22:11:28 kisu-laptop kernel: audit: type=1130 audit(1609877488.923:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:11:28 kisu-laptop kernel: audit: type=1131 audit(1609877488.923:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:11:28 kisu-laptop systemd-logind[338]: Operation 'sleep' finished.
tammi 05 22:11:28 kisu-laptop kded5[1027]: bluedevil: About to resume
tammi 05 22:11:28 kisu-laptop ModemManager[638]: <info> [sleep-monitor] system is resuming
tammi 05 22:11:28 kisu-laptop NetworkManager[333]: <info> [1609877488.9452] manager: sleep: wake requested (sleeping: yes enabled: yes)
tammi 05 22:11:28 kisu-laptop NetworkManager[333]: <info> [1609877488.9454] device (enp3s8): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
tammi 05 22:11:31 kisu-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:11:31 kisu-laptop systemd[1]: NetworkManager-dispatcher.service: Succeeded.
tammi 05 22:11:31 kisu-laptop kernel: audit: type=1131 audit(1609877491.343:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:11:31 kisu-laptop ModemManager[638]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.2/0000:02:00.0': not supported by any plugin
tammi 05 22:11:31 kisu-laptop ModemManager[638]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1e.0/0000:03:08.0': not supported by any plugin
tammi 05 22:11:33 kisu-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:11:33 kisu-laptop systemd[1]: systemd-rfkill.service: Succeeded.
tammi 05 22:11:33 kisu-laptop kernel: audit: type=1131 audit(1609877493.133:115): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:11:38 kisu-laptop audit[2314]: USER_AUTH pid=2314 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="olli" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
tammi 05 22:11:38 kisu-laptop kernel: audit: type=1100 audit(1609877498.103:116): pid=2314 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="olli" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
tammi 05 22:11:39 kisu-laptop plasmashell[1079]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding loop detected for property "height"
tammi 05 22:11:53 kisu-laptop kscreenlocker_greet[1956]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/components/VirtualKeyboard.qml:27: TypeError: Cannot read property 'width' of null
tammi 05 22:11:53 kisu-laptop kwin_x11[1031]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34892, resource id: 69206049, major code: 18 (ChangeProperty), minor code: 0
tammi 05 22:14:10 kisu-laptop kernel: INFO: task Qt bearer threa:1162 blocked for more than 122 seconds.
tammi 05 22:14:10 kisu-laptop kernel: Not tainted 5.10.2-2-MANJARO #1
tammi 05 22:14:10 kisu-laptop kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
tammi 05 22:14:10 kisu-laptop kernel: task:Qt bearer threa state:D stack: 0 pid: 1162 ppid: 1 flags:0x00000080
tammi 05 22:14:10 kisu-laptop kernel: Call Trace:
tammi 05 22:14:10 kisu-laptop kernel: __schedule+0x295/0x810
tammi 05 22:14:10 kisu-laptop kernel: schedule+0x5b/0xc0
tammi 05 22:14:10 kisu-laptop kernel: schedule_preempt_disabled+0x11/0x20
tammi 05 22:14:10 kisu-laptop kernel: __mutex_lock.constprop.0+0x17d/0x4f0
tammi 05 22:14:10 kisu-laptop kernel: ? rht_deferred_worker+0x480/0x480
tammi 05 22:14:10 kisu-laptop kernel: __netlink_dump_start+0xca/0x2d0
tammi 05 22:14:10 kisu-laptop kernel: ? rtnl_fill_ifinfo+0x1410/0x1410
tammi 05 22:14:10 kisu-laptop kernel: rtnetlink_rcv_msg+0x287/0x390
tammi 05 22:14:10 kisu-laptop kernel: ? rtnl_calcit.isra.0+0x130/0x130
tammi 05 22:14:10 kisu-laptop kernel: netlink_rcv_skb+0x5b/0x100
tammi 05 22:14:10 kisu-laptop kernel: netlink_unicast+0x242/0x340
tammi 05 22:14:10 kisu-laptop kernel: netlink_sendmsg+0x243/0x480
tammi 05 22:14:10 kisu-laptop kernel: sock_sendmsg+0x5e/0x60
tammi 05 22:14:10 kisu-laptop kernel: __sys_sendto+0x120/0x180
tammi 05 22:14:10 kisu-laptop kernel: __x64_sys_sendto+0x25/0x30
tammi 05 22:14:10 kisu-laptop kernel: do_syscall_64+0x33/0x40
tammi 05 22:14:10 kisu-laptop kernel: entry_SYSCALL_64_after_hwframe+0x44/0xa9
tammi 05 22:14:10 kisu-laptop kernel: RIP: 0033:0x7f70c6e5d77c
tammi 05 22:14:10 kisu-laptop kernel: RSP: 002b:00007f70a37fcd60 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
tammi 05 22:14:10 kisu-laptop kernel: RAX: ffffffffffffffda RBX: 000000000000001c RCX: 00007f70c6e5d77c
tammi 05 22:14:10 kisu-laptop kernel: RDX: 0000000000000020 RSI: 00007f70a37fce00 RDI: 000000000000001c
tammi 05 22:14:10 kisu-laptop kernel: RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000
tammi 05 22:14:10 kisu-laptop kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 00007f70a37fcec8
tammi 05 22:14:10 kisu-laptop kernel: R13: 00005582f1386900 R14: 00007f7094013998 R15: 0000000000000000
tammi 05 22:14:10 kisu-laptop kernel: INFO: task Qt bearer threa:1116 blocked for more than 122 seconds.
tammi 05 22:14:10 kisu-laptop kernel: task:Qt bearer threa state:D stack: 0 pid: 1116 ppid: 1 flags:0x00000080
tammi 05 22:14:10 kisu-laptop kernel: RIP: 0033:0x7f55766d677c
tammi 05 22:14:10 kisu-laptop kernel: RSP: 002b:00007f556adecd60 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
tammi 05 22:14:10 kisu-laptop kernel: RAX: ffffffffffffffda RBX: 000000000000000f RCX: 00007f55766d677c
tammi 05 22:14:10 kisu-laptop kernel: RDX: 0000000000000020 RSI: 00007f556adece00 RDI: 000000000000000f
tammi 05 22:14:10 kisu-laptop kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 00007f556adecec8
tammi 05 22:14:10 kisu-laptop kernel: R13: 0000559aee5eaa80 R14: 00007f555c015388 R15: 0000000000000000
tammi 05 22:15:11 kisu-laptop systemd[1]: Starting Network Manager Wait Online...
tammi 05 22:15:36 kisu-laptop systemd[1]: Finished Network Manager Wait Online.
tammi 05 22:15:36 kisu-laptop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:15:36 kisu-laptop systemd[1]: Reached target Network is Online.
tammi 05 22:15:36 kisu-laptop kernel: audit: type=1130 audit(1609877736.868:117): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:15:36 kisu-laptop systemd[1]: Starting Generate mirrorlist...
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::WARNING https://gitlab.manjaro.org '<urlopen error [Errno -2] Name or service not known>'
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::WARNING https://wikipedia.org '<urlopen error [Errno -2] Name or service not known>'
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::WARNING https://bitbucket.org '<urlopen error [Errno -2] Name or service not known>'
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::INFO Internet connection appears to be down
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::INFO Mirror ranking is not available
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::INFO Mirror list is generated using random method
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::INFO Writing mirror list
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::France : https://manjaro.ynh.ovh/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Netherlands : https://manjaro.mirrors.lavatech.top/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::United_Kingdom : http://manjaro.mirrors.uk2.net/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Poland : http://ftp.vectranet.pl/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::United_States : http://distro.ibiblio.org/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Germany : https://mirror.alpix.eu/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Germany : https://mirror.netzspielplatz.de/manjaro/packages/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Sweden : https://ftp.lysator.liu.se/pub/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Ukraine : https://fastmirror.pp.ua/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::United_States : https://repo.ialab.dsu.edu/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Ukraine : http://mirrors.colocall.net/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::France : http://kibo.remi.lu/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Germany : https://manjaro.moson.eu/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Poland : https://mirror.tuchola-dc.pl/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Costa_Rica : https://mirrors.ucr.ac.cr/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::United_States : https://mirrors.ocf.berkeley.edu/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/sta
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Italy : https://ct.mirror.garr.it/mirrors/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Spain : https://ftp.caliu.cat/pub/distribucions/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Russia : https://mirror.yandex.ru/mirrors/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Italy : https://manjaro.mirror.garr.it/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Netherlands : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Switzerland : https://manjaro.osmir.ch/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Sweden : https://mirror.zetup.net/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::United_States : https://mirror.math.princeton.edu/pub/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Belarus : http://mirror.datacenter.by/pub/mirrors/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Denmark : https://www.uex.dk/public/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Hungary : https://quantum-mirror.hu/mirrors/pub/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Canada : https://osmirror.org/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Germany : https://manjaro.moson.org/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::France : https://manjaro.mcofficer.me/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::United_States : https://us.mirrors.fossho.st/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Turkey : http://ftp.linux.org.tr/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Italy : https://ba.mirror.garr.it/mirrors/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Austria : http://mirror.easyname.at/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Kenya : https://manjaro.mirror.liquidtelecom.com/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::New_Zealand : http://manjaro.mirrors.theom.nz/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Uruguay : https://manjaro.repo.cure.edu.uy/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Germany : https://ftp.halifax.rwth-aachen.de/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::South_Africa : http://mirror.is.co.za/mirrors/manjaro.org/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::United_States : https://mirror.dacentec.com/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Netherlands : https://mirror.koddos.net/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Chile : https://mirror.ufro.cl/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Chile : https://mirror1.cl.netactuate.com/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Germany : https://manjaro.re/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Greece : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Switzerland : https://mirror.init7.net/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Indonesia : https://mirror.deace.id/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Czech : https://mirror.dkm.cz/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Brazil : https://manjaro.c3sl.ufpr.br/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Pakistan : https://repo.inara.pk/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Australia : https://manjaro.lucassymons.net/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::China : https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::Bulgaria : https://manjaro.ipacct.com/manjaro/stable
tammi 05 22:15:41 kisu-laptop pacman-mirrors[2802]: ::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
tammi 05 22:15:41 kisu-laptop systemd[1]: pamac-mirrorlist.service: Succeeded.
tammi 05 22:15:41 kisu-laptop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-mirrorlist comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:15:41 kisu-laptop systemd[1]: Finished Generate mirrorlist.
tammi 05 22:15:41 kisu-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-mirrorlist comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:15:41 kisu-laptop kernel: audit: type=1130 audit(1609877741.772:118): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-mirrorlist comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:15:41 kisu-laptop kernel: audit: type=1131 audit(1609877741.772:119): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-mirrorlist comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
tammi 05 22:16:13 kisu-laptop kernel: INFO: task kworker/0:1:15 blocked for more than 122 seconds.
tammi 05 22:16:13 kisu-laptop kernel: Not tainted 5.10.2-2-MANJARO #1
tammi 05 22:16:13 kisu-laptop kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
tammi 05 22:16:13 kisu-laptop kernel: task:kworker/0:1 state:D stack: 0 pid: 15 ppid: 2 flags:0x00004000
tammi 05 22:16:13 kisu-laptop kernel: Workqueue: ipv6_addrconf addrconf_verify_work
tammi 05 22:16:13 kisu-laptop kernel: Call Trace:
tammi 05 22:16:13 kisu-laptop kernel: __schedule+0x295/0x810
tammi 05 22:16:13 kisu-laptop kernel: schedule+0x5b/0xc0
tammi 05 22:16:13 kisu-laptop kernel: schedule_preempt_disabled+0x11/0x20
tammi 05 22:16:13 kisu-laptop kernel: __mutex_lock.constprop.0+0x17d/0x4f0
tammi 05 22:16:13 kisu-laptop kernel: addrconf_verify_work+0xa/0x20
tammi 05 22:16:13 kisu-laptop kernel: process_one_work+0x1d6/0x3a0
tammi 05 22:16:13 kisu-laptop kernel: worker_thread+0x4d/0x3d0
tammi 05 22:16:13 kisu-laptop kernel: ? rescuer_thread+0x410/0x410
tammi 05 22:16:13 kisu-laptop kernel: kthread+0x133/0x150
tammi 05 22:16:13 kisu-laptop kernel: ? __kthread_bind_mask+0x60/0x60
tammi 05 22:16:13 kisu-laptop kernel: ret_from_fork+0x22/0x30
tammi 05 22:16:13 kisu-laptop kernel: INFO: task Qt bearer threa:1162 blocked for more than 245 seconds.
tammi 05 22:16:13 kisu-laptop kernel: task:Qt bearer threa state:D stack: 0 pid: 1162 ppid: 1 flags:0x00000080
tammi 05 22:16:13 kisu-laptop kernel: ? rht_deferred_worker+0x480/0x480
tammi 05 22:16:13 kisu-laptop kernel: __netlink_dump_start+0xca/0x2d0
tammi 05 22:16:13 kisu-laptop kernel: ? rtnl_fill_ifinfo+0x1410/0x1410
tammi 05 22:16:13 kisu-laptop kernel: rtnetlink_rcv_msg+0x287/0x390
tammi 05 22:16:13 kisu-laptop kernel: ? rtnl_calcit.isra.0+0x130/0x130
tammi 05 22:16:13 kisu-laptop kernel: netlink_rcv_skb+0x5b/0x100
tammi 05 22:16:13 kisu-laptop kernel: netlink_unicast+0x242/0x340
tammi 05 22:16:13 kisu-laptop kernel: netlink_sendmsg+0x243/0x480
tammi 05 22:16:13 kisu-laptop kernel: sock_sendmsg+0x5e/0x60
tammi 05 22:16:13 kisu-laptop kernel: __sys_sendto+0x120/0x180
tammi 05 22:16:13 kisu-laptop kernel: __x64_sys_sendto+0x25/0x30
tammi 05 22:16:13 kisu-laptop kernel: do_syscall_64+0x33/0x40
tammi 05 22:16:13 kisu-laptop kernel: entry_SYSCALL_64_after_hwframe+0x44/0xa9
tammi 05 22:16:13 kisu-laptop kernel: RIP: 0033:0x7f70c6e5d77c
tammi 05 22:16:13 kisu-laptop kernel: RSP: 002b:00007f70a37fcd60 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
tammi 05 22:16:13 kisu-laptop kernel: RAX: ffffffffffffffda RBX: 000000000000001c RCX: 00007f70c6e5d77c
tammi 05 22:16:13 kisu-laptop kernel: RDX: 0000000000000020 RSI: 00007f70a37fce00 RDI: 000000000000001c
tammi 05 22:16:13 kisu-laptop kernel: RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000
tammi 05 22:16:13 kisu-laptop kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 00007f70a37fcec8
tammi 05 22:16:13 kisu-laptop kernel: R13: 00005582f1386900 R14: 00007f7094013998 R15: 0000000000000000
tammi 05 22:16:13 kisu-laptop kernel: INFO: task Qt bearer threa:1116 blocked for more than 245 seconds.
tammi 05 22:16:13 kisu-laptop kernel: task:Qt bearer threa state:D stack: 0 pid: 1116 ppid: 1 flags:0x00000080
tammi 05 22:16:13 kisu-laptop kernel: RIP: 0033:0x7f55766d677c
tammi 05 22:16:13 kisu-laptop kernel: RSP: 002b:00007f556adecd60 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
tammi 05 22:16:13 kisu-laptop kernel: RAX: ffffffffffffffda RBX: 000000000000000f RCX: 00007f55766d677c
tammi 05 22:16:13 kisu-laptop kernel: RDX: 0000000000000020 RSI: 00007f556adece00 RDI: 000000000000000f
tammi 05 22:16:13 kisu-laptop kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 00007f556adecec8
tammi 05 22:16:13 kisu-laptop kernel: R13: 0000559aee5eaa80 R14: 00007f555c015388 R15: 0000000000000000
tammi 05 22:16:13 kisu-laptop kernel: INFO: task kworker/u4:31:2134 blocked for more than 122 seconds.
tammi 05 22:16:13 kisu-laptop kernel: task:kworker/u4:31 state:D stack: 0 pid: 2134 ppid: 2 flags:0x00004080
tammi 05 22:16:13 kisu-laptop kernel: Workqueue: events_power_efficient reg_check_chans_work [cfg80211]
tammi 05 22:16:13 kisu-laptop kernel: reg_check_chans_work+0x2d/0x3c0 [cfg80211]
