Hi,
I had difficulties installing the last batch of updates, which was caused by some version of electron (
icu
refused to install), and I found somewhere someone recommending removing electron. I did, but the result is that several packages no longer work/start, and from my limited knowledge “by launching a package in the terminal” I found that the packages wont start due to some library issue.
I did not want to paste some command in the terminal, then end up with a non-functioning system, so I though to ask first ![]()
This is what happens when I launch some packages in the terminal:
fsearch
fsearch: error while loading shared libraries: libicuuc.so.75: cannot open shared object file: No such file or directory
easystroke
easystroke: error while loading shared libraries: libboost_serialization.so.1.86.0: cannot open shared object file: No such file or directory
The following happens for youtube-dl & yt-dlp
sudo pacman -Syy yt-dlp
reinstalling yt-dlp
(1/1) reinstalling yt-dlp [############################################################################] 100%
ldconfig: /usr/lib/libicuio.so.75 is for unknown machine 183.
ldconfig: /usr/lib/libicutest.so.75.1 is for unknown machine 183.
ldconfig: /usr/lib/libicuuc.so.75.1 is for unknown machine 183.
ldconfig: /usr/lib/libicutu.so.75 is for unknown machine 183.
ldconfig: /usr/lib/libicutu.so.75.1 is for unknown machine 183.
ldconfig: /usr/lib/libicutest.so.75 is for unknown machine 183.
ldconfig: /usr/lib/libicudata.so.75.1 is for unknown machine 183.
ldconfig: /usr/lib/libicui18n.so.75 is for unknown machine 183.
ldconfig: /usr/lib/libicuuc.so.75 is for unknown machine 183.
ldconfig: /usr/lib/libicudata.so.75 is for unknown machine 183.
ldconfig: /usr/lib/libicui18n.so.75.1 is for unknown machine 183.
ldconfig: /usr/lib/libicuio.so.75.1 is for unknown machine 183.
(1/2) Arming ConditionNeedsUpdate...
(2/2) Refreshing PackageKit...
/usr/bin/chromium --disable-features=GlobalMediaControls --disable-features=CustomizeChromeSidePanel %U
/usr/lib/chromium/chromium: error while loading shared libraries: libicui18n.so.75: cannot open shared object file: No such file or directory
ldconfig
ldconfig: Can't create temporary cache file /etc/ld.so.cache~: Permission denied
libicu, libicuio, and libicu-dev gave:
bash: libicu: command not found
bash: libicuio: command not found
bash: libicu-dev: command not found
I waited now for 3 days before posting this, I seem not to find anyone who has had the same issues ![]()
In the meantime, I found this fix:
Chromium does not run after latest unstable update
And after applying it, …
please update the chromium package
… rebooted, saw that nothing was fixed, reread & saw the tags ![]()
ARM
Chromium
Raspberry-pi
Arm-unstable
Edit-01:
I did not apply the last step in (please update the chromium package) ;
To remove the above tmp fix (remove leftover files in the future when fixed)
sudo rm /usr/lib/libicu*75 /usr/lib/libicu*75.1 /usr/lib/libFLAC.so.12
All and any help is much appreciated.
My system:
Note that I did redact some info!
Kernel: 6.12.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=b672b51b-7667-46e5-8a89-26f7e3900126 rw rd.driver.pre=vfio-pci
amd_iommu=on quiet
cryptdevice=UUID=a566765b-d961-42f0-8993-e5516f206be3:luks-a566765b-d961-42f0-8993-e5516f206be3
root=/dev/mapper/luks-a566765b-d961-42f0-8993-e5516f206be3 splash
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: light-locker,xfce4-screensaver dm: LightDM v: 1.32.0
Type: Desktop
Mobo: ASUSTeK model: PRIME TRX40-PRO
UEFI: American Megatrends v: 2102 date: 02/16/2024
System RAM: total: 128 GiB available: 125.66 GiB used: 14.06 GiB (11.2%)
Slot: 0 type: PCIe status: in use length: long volts: 3.3 bus-ID: 00:00.0
Slot: 1 type: PCIe status: in use length: long volts: 3.3 bus-ID: 00:00.0
Slot: 2 type: PCIe status: in use length: long volts: 3.3 bus-ID: 00:00.0
Slot: 3 type: PCIe status: in use length: short volts: 3.3 bus-ID: 00:00.0
Info: model: AMD Ryzen Threadripper 3970X socket: SP3r2 (sTRX4)
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
Device-1: NVIDIA TU104GL [Quadro RTX 4000] driver: nvidia v: 470.256.02
alternate: nouveau,nvidia_drm non-free: 550/565.xx+ status: current (as of
2025-01; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
off: DP-2 empty: DP-1,DP-3,Unknown-2 bus-ID: 01:00.0 chip-ID: 10de:1eb1
class-ID: 0300
Display: x11 server: X.org v: 1.21.1.16 compositor: xfwm4 v: 4.20.0 driver:
X: loaded: N/A failed: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-size: <missing: xdpyinfo>
Monitor-1: DP-2 res: N/A size: 600x340mm (23.62x13.39") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
drv: kms_swrast surfaceless: drv: swrast x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia v: 470.256.02 glx-v: 1.4
direct-render: yes renderer: Quadro RTX 4000/PCIe/SSE2 memory: 7.81 GiB
API: Vulkan v: 1.4.304 layers: 1 device: 0 type: discrete-gpu
name: Quadro RTX 4000 driver: N/A device-ID: 10de:1eb1 surfaces: xcb,xlib
Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
gpu: nvidia-settings,nvidia-smi x11: xprop,xrandr
Local Storage: total: 4.36 TiB used: 1.17 TiB (26.8%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Intel model: SSDPEKNW020T8
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 40.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QJXD7 temp: 44.9 C
scheme: MBR
ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT750MX300SSD1
size: 698.64 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: R011 scheme: MBR
System Temperatures: cpu: 43.2 C mobo: N/A gpu: nvidia temp: 64 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 37%
Packages: 2114 pm: dpkg pkgs: 0 pm: pacman pkgs: 2095 libs: 430
tools: pacseek,pamac,paru,yay pm: rpm pkgs: 0 tools: dnf pm: flatpak pkgs: 13
pm: snap pkgs: 6
Active pacman repo servers in: /etc/pacman.conf
1: https://download.opensuse.org/repositories/home:/ungoogled_chromium/Arch/$arch
1: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
2: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
5: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
6: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
7: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
8: https://mirror.zetup.net/manjaro/stable/$repo/$arch
9: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
10: https://mirrors.manjaro.org/repo/stable/$repo/$arch
11: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
12: https://mirror.init7.net/manjaro/stable/$repo/$arch
13: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
14: https://mirror.koddos.net/manjaro/stable/$repo/$arch
15: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
16: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
17: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
18: https://mirrors2.manjaro.org/stable/$repo/$arch
19: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
20: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
21: https://mirror.easyname.at/manjaro/stable/$repo/$arch
22: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
23: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
24: https://manjaro.kurdy.org/stable/$repo/$arch
25: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
26: https://manjaro.ynh.ovh/stable/$repo/$arch
27: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
28: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
No active dnf repos in: /etc/dnf/dnf.conf
Processes:
CPU top: 5 of 924
1: cpu: 22.7% command: brave pid: 20947 mem: 305.8 MiB (0.2%)
2: cpu: 22.5% command: brave pid: 8057 mem: 155.1 MiB (0.1%)
3: cpu: 17.4% command: electron pid: 9786 mem: 788.0 MiB (0.6%)
4: cpu: 13.0% command: electron pid: 9766 mem: 207.8 MiB (0.1%)
5: cpu: 11.7% command: brave pid: 7657 mem: 879.3 MiB (0.6%)
Memory top: 5 of 924
1: mem: 1049.8 MiB (0.8%) command: electron-mail pid: 3839 cpu: 0.2%
2: mem: 879.3 MiB (0.6%) command: brave pid: 7657 cpu: 11.7%
3: mem: 829.8 MiB (0.6%) command: electron-mail pid: 3936 cpu: 0.4%
4: mem: 829.4 MiB (0.6%) command: electron-mail pid: 3857 cpu: 0.5%
5: mem: 808.5 MiB (0.6%) command: electron-mail pid: 3917 cpu: 0.4%
Processes: 924 Power: uptime: 3h 36m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 50.24 GiB services: upowerd,xfce4-power-manager
Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: Sudo (sudo) v: 1.9.16p2
default: Bash v: 5.2.37 running-in: xfce4-terminal inxi: 3.3.37
