Version info:
kernel 5.12.2, 5.11.19,
systemd 248.2-1.1
I ran into a trouble with cgroupfs which I currently can not solve myself. So far all materials I found miss my case, which is - I do have /proc/sys/fs/cgroup, but not ‘cpuset’ and other nodes. This causes k3d/k3s to fail while launching their containers. Docker itself still works.
I did compare results between xps laptop and desktop. My desktop has only
$ mount|grep cgr
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
$ k3s check-config
Generally Necessary:
- cgroup hierarchy: **nonexistent??** (fail)
(see https://github.com/tianon/cgroupfs-mount)
My laptop brings more, and k3s works there flawlessly:
$ mount|grep cgr
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,size=4096k,nr_inodes=1024,mode=755,inode64)
cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/rdma type cgroup (rw,nosuid,nodev,noexec,relatime,rdma)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
I suspect troubles with some systemd or kernel options, but from quick look at units which are running on both nodes I don’t see any indicator which should or could affect cgroups handling.
From arch wiki materials I know there are troubles with different modes of cgroups handling, however I am not willing to tinker this unless I get proper mounts.
Can anyone share any tips how to force cpuset mounts? Systemd docs focuses mainly on settings for units, but not mounts itself.
