I have a feeling that this is a long standing issue with the parted command but I would be very grateful if someone could verify on their Manjaro too?
I am also having this bug reported in 2017.
$ parted -v
parted (GNU parted) 3.6
Copyright (C) 2023 Free Software Foundation, Inc.
License GPLv3+
Written by http://git.debian.org/?p=parted/parted.git;a=blob_plain;f=AUTHORS.
$ cat /etc/lsb-release
DISTRIB_ID=“ManjaroLinux”
DISTRIB_RELEASE=“24.0.2”
DISTRIB_CODENAME=“Wynsdey”
If increasing the size of a partition the following command works but if shrinking a partition it gives a warning “Warning: Shrinking a partition can cause data loss, are you sure you want to continue?” and the command just exits back to the command prompt and no changes are made to the partition.
sudo parted -s /dev/loop0 resizepart 1 46280703s
I assumed that parted -s would automatically supply a default value of ‘Yes’ in this instance?
According to the parted Man page:
-s, --script
never prompts for user intervention
Is this a bug or am I misunderstanding something?
From researching the interweb this might be a bug that for many years has never been addressed.
Previous parted versions apparently allowed for something like:
sudo parted -s /dev/loop0 resizepart 1 yes 46280703s
or
sudo parted -s /dev/loop0 resizepart 1 46280703s yes
But in parted 3.6 there appears to be no way to make this work with parted -s. The only option is to resort to the undocumented —pretend-input-tty ← But is this safe to keep using if not documented?
Example that will work whether increasing or reducing the partition size:
echo -e "resizepart 1 46280703s\nyes\nunit s\nprint\nquit" | sudo parted /dev/loop0 ---pretend-input-tty
My question is not so much “how” do I make this work but can you please try this on your system and does it also not work for you in which case it must be a bug I guess?
To try this out on your Manjaro machine, make a .img file and use parted to put a partition on it and then try to shrink that partition with parted in non-interactive mode:
dd if=/dev/zero of=myfs.img count=204800
sudo parted myfs.img mktable gpt
sudo parted myfs.img mkpart primary ext4 2048s 100%
sudo parted myfs.img align-check optimal 1
You will see that partition 1 has an end sector of 204766.
Try using parted in script mode (non-interactive mode) to shrink the partition by just one sector (204765s)
sudo parted -s -a opt myfs.img "resizepart 1 204765s"
Did you get the user prompt: “Warning: Shrinking a partition can cause data loss, are you sure you want to continue?” and the command just exits back to the command line prompt?
If so, I guess this is a bug or any ideas what I’m doing wrong?
Any help much appreciated,
Flex
