According to Arch Wiki partclone supports compression. How do I use it though? Project’s website doesn’t even mention it.
Hi @Myrtle,
I’ve never heard of partclone before, but accoring to the Arch wiki:
With compression
To backup with compression:
$ partclone.ext4 -c -s /dev/sda1 | gzip -c > ~/image_sda1.pcl.gz
Note: For maximum compression use
gzip -c9
To restore it:
zcat ~/image_sda1.pcl.gz | partclone.ext4 -r -o /dev/sda1
Thanks, I didn’t see this.
It can also be used with zstd if anyone’s interested. Just replace gzip and zcat with zstd and zstdcat.
You’re welcome!
A pipe is not needed:
partclone.vfat -a1 -cs /dev/sda1 -o /media/space/sda1.partclone.zst -x 'zstd -v -T0 --adapt --long' -L /tmp/partclone
This uses multi-threaded, adaptive compression to maximise bandwidth.
Thank you!
