Hola, i would like to use Parley Vocabulary Trainer but it does not work yet.
I installed it by Add/Remove Software under Manjaro XFCE.
If i start it by the menu it starts but the background is black, and it is not possible to save a new vocabulary stack.
I tried to open it over terminal and the terminal said that the Icon theme “breeze” was not found.
So i installed the theme pack “breeze” over terminal. But Parley still has some trouble.
Here the output from the terminal
parley
Expired words dropped their confidence: 0
Attempting to load .desktop at "/usr/share/parley/themes/theme_reference.desktop"
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 652, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 657, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 673, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 698, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 703, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 723, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 734, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 739, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 763, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 768, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 785, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 799, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 800, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 801, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 802, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 807, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 808, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 809, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 810, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 824, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 829, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 858, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 863, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 890, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 895, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 898, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 909, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 914, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 935, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 940, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 951, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 956, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 969, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 974, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 985, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 990, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1007, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1012, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1039, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1044, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1047, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1058, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1063, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1085, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1090, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1117, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1122, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1125, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1136, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1141, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1257, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1262, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1717, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1722, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1868, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 1873, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2311, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2316, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2337, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2342, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2353, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2358, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2373, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2378, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2389, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2394, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2406, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2411, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2427, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2432, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2443, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2448, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2459, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2464, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2475, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2480, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2491, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2496, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2507, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2512, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2533, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2538, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2549, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2554, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2565, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2570, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2581, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2586, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2602, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2607, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2627, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2632, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2643, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2648, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2659, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2664, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2675, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2680, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2691, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2696, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2743, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 2748, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 3159, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 3164, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 3213, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 3218, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4098, resource id: 10749838, major code: 40 (TranslateCoords), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 4122, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 4127, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 4177, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 4182, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 4519, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 4524, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 4577, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 4582, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 4641, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 4646, resource id: 79691802, major code: 130 (Unknown), minor code: 3
Open success.
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4787, resource id: 10751605, major code: 40 (TranslateCoords), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 4975, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 4976, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 4977, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 4978, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 4983, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5019, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5024, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5025, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5026, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5027, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5048, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5070, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5075, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5105, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5110, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5125, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5126, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5127, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5128, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5129, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5134, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5135, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5136, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5137, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5138, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5164, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5169, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5180, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5185, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5196, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5201, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5212, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5217, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5225, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5234, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5235, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5244, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5253, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5254, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5263, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5272, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5281, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5282, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5291, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5300, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5309, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5314, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5587, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 5592, resource id: 79691802, major code: 130 (Unknown), minor code: 3
kf.coreaddons: Could not lock file: "/home/ash/.local/share/stalefiles/parley/169970-Deutsch_Spanisch.kvtmlAwCfile_%2Fhome%2Fash%2F.local%2Fshare%2FkvtmliMLtcAwC"
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6128, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6133, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6165, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6170, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6171, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6172, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6173, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6204, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6209, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6220, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6225, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6236, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6241, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6249, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6260, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6265, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6273, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6284, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6289, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6297, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6306, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6315, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6324, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6333, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6342, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6351, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6360, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6369, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6374, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6387, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6392, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6403, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6408, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6589, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6594, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6915, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 6920, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 7043, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 7048, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 7049, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 7050, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 7051, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 7141, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 7146, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 7243, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 7248, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 7303, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 7308, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 7386, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 7391, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 7402, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 7407, resource id: 79691802, major code: 130 (Unknown), minor code: 3
Couldn't start kuiserver from org.kde.kuiserver.service: QDBusError("org.freedesktop.DBus.Error.ServiceUnknown", "The name org.kde.kuiserver was not provided by any .service files")
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16238, resource id: 10753700, major code: 40 (TranslateCoords), minor code: 0
kf.dbusaddons: Can not find 'kdeinit5' executable at "/home/ash/.local/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl" "/usr/bin, /usr/bin"
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16303, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16308, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16309, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16310, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16311, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16342, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16347, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16358, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16363, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16374, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16379, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16390, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16395, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16406, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16411, resource id: 79691802, major code: 130 (Unknown), minor code: 3
kxkb dbus error
kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so: (libaspell.so.15: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden)"
kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so: (libhspell.so.0: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden)"
kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so: (libvoikko.so.1: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden)"
kf.sonnet.core: No language dictionaries for the language: "de_DE" trying to load en_US as default
kf.sonnet.core: No language dictionaries for the language: "en_US"
kxkb dbus error
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16761, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16766, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16767, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16768, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16769, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16812, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16817, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16855, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16860, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16876, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16881, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16898, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16903, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16920, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 16925, resource id: 79691802, major code: 130 (Unknown), minor code: 3
Create word type model for summary view
Clear summary widget
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17130, resource id: 10766332, major code: 40 (TranslateCoords), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17380, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17381, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17382, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17383, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17384, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17385, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17386, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17387, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17388, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17393, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17427, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17432, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17433, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17434, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17435, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17436, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17437, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17438, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17439, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17440, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17468, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17478, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17501, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17517, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17518, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17523, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17524, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17535, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17536, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17541, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17542, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17582, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17583, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17584, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17585, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17586, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17587, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17588, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17589, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17590, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17591, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17592, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17593, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17594, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17595, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17596, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17597, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17598, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17599, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17600, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17601, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17602, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17603, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17604, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17605, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17606, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17611, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17612, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17613, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17614, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17615, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17616, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17617, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17618, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17619, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17620, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17621, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17622, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17623, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17624, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17625, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17626, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17627, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17628, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17629, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17630, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17631, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17632, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17633, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17634, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17635, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17670, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17671, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17676, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17677, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17688, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17689, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17694, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17695, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17707, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17708, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17713, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17714, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17726, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17727, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17732, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17733, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17745, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17746, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17751, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17752, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17762, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17767, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17778, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17783, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17794, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17799, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17810, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17815, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17826, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17831, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17842, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17847, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17858, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17863, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17874, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17879, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17890, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17895, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17906, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17911, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17914, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17925, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17930, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17933, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17934, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17945, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17950, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17953, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17954, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17958, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17959, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17963, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17964, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17974, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17979, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17983, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17984, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17988, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17989, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 17999, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18004, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18008, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18009, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18019, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18024, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18028, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18029, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18051, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18056, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18083, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18084, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18085, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18086, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18087, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18088, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18089, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18090, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18095, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18096, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18097, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18098, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18099, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18100, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18101, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18102, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18103, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18104, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18105, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18106, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18107, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18108, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18109, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18118, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18127, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18132, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18148, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18149, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18150, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18151, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18156, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18157, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18158, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18159, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18379, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18384, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18385, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18964, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18969, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 18970, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19032, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19037, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19038, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19039, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19040, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19041, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19042, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19043, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19044, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19045, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19087, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19088, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19093, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19094, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19112, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19113, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19118, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19119, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19135, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19136, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19141, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19142, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19158, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19159, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19164, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19165, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19181, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19182, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19187, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19188, resource id: 79691802, major code: 130 (Unknown), minor code: 3
SaveAs failed for ""
why "Unbekannter Dateityp."
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19660, resource id: 10768078, major code: 40 (TranslateCoords), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19900, resource id: 10771681, major code: 40 (TranslateCoords), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19933, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19938, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19939, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19940, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19941, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19942, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19943, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19944, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19945, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19946, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19978, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19979, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19984, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19985, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19997, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 19998, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20003, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20004, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20016, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20017, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20022, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20023, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20035, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20036, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20041, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20042, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20054, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20055, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20060, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20061, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20082, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20083, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20084, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20085, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20090, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20102, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20107, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20121, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20126, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20228, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20233, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20234, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20235, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20236, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20237, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20238, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20239, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20240, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20241, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20266, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20267, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20272, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20273, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20294, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20295, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20300, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20301, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20313, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20314, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20319, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20320, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20332, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20333, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20338, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20339, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20351, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20352, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20357, resource id: 79691802, major code: 130 (Unknown), minor code: 3
qt.qpa.xcb: QXcbConnection: XCB error: 8 (BadMatch), sequence: 20358, resource id: 79691802, major code: 130 (Unknown), minor code: 3
Set invalid document
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20432, resource id: 10774507, major code: 40 (TranslateCoords), minor code: 0
If i start Parley by sudo it works
I did some screenshots but could not insert here.
I think it has some thing to do with rights or groups because if i start it by sudo it works
or it has something to do with KDE because i use xfce or something else.
This is my first Forum Topic and I hope i did everything well
I enjoy Manjaro over years and it is a great System and easy to use
Thank you for all your Help
So i can improve my language skills
Alex
