La pantalla del laptop parpadea. Despues de unas tres horas se calma un poco el parpadeo pero queda una linea en la parte de abajo. Sera problema de software o hardaware?
[mans@mans-pc ~]$ inxi --full --verbosity=7 --filter --no-host
System: Kernel: 5.8.0-2-MANJARO x86_64 bits: 64 compiler: N/A Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: TOSHIBA product: Satellite M305 v: PSMD8U-023013 serial: Chassis: type: 10
serial:
Mobo: TOSHIBA model: Satellite M305 serial: BIOS: TOSHIBA v: 3.20 date: 01/08/2009
Battery: ID-1: BAT1 charge: 13.1 Wh condition: 29.9/89.3 Wh (34%) volts: 11.9/12.4 model: SANYO NS2P3SZNJ5WR type: Li-ion
serial: status: Charging
Memory: RAM: total: 3.71 GiB used: 2.80 GiB (75.3%)
CPU: Topology: Dual Core model: Intel Core2 Duo T6400 bits: 64 type: MCP arch: Penryn rev: A L2 cache: 2048 KiB
bogomips: 7982
Speed: 1383 MHz min/max: 1200/2000 MHz Core speeds (MHz): 1: 1323 2: 1294
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts
est fpu fxsr ht lahf_lm lm mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse pse36 pti
rep_good sep sse sse2 sse4_1 ssse3 syscall tm tm2 tsc vme xsave xtpr
Graphics: Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Toshiba driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:2a42
Device-2: Chicony Camera type: USB driver: uvcvideo bus ID: 2-4:2 chip ID: 04f2:b070 serial:
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel unloaded: modesetting alternate: fbdev,vesa
resolution: 1280x800~60Hz s-dpi: 96
OpenGL: renderer: Mesa DRI Mobile Intel GM45 Express (CTG) v: 2.1 Mesa 20.1.5 direct render: Yes
Audio: Device-1: Intel 82801I HD Audio vendor: Toshiba driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:293e
Sound Server: ALSA v: k5.8.0-2-MANJARO
Network: Device-1: Marvell 88E8040T PCI-E Fast Ethernet vendor: Toshiba Satellite P305D-S8995E driver: sky2 v: 1.30
port: 3000 bus ID: 07:00.0 chip ID: 11ab:4355
IF: enp7s0 state: down mac:
Device-2: Intel WiFi Link 5100 driver: iwlwifi v: kernel port: 3000 bus ID: 08:00.0 chip ID: 8086:4232
IF: wlp8s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Drives: Local Storage: total: 298.09 GiB used: 38.16 GiB (12.8%)
ID-1: /dev/sda vendor: Toshiba model: MK3252GSX size: 298.09 GiB speed: 1.5 Gb/s serial: rev: 0M
scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW TS-L633P rev: TO01 dev-links: cdrom
Features: speed: 24 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
RAID: Message: No RAID data was found.
Partition: ID-1: / size: 282.97 GiB used: 38.16 GiB (13.5%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: 76032975-a0b2-45a1-a13c-bedb0a967e42
Swap: Alert: No Swap data was found.
Unmounted: ID-1: /dev/sda1 size: 1.46 GiB fs: ntfs label: TOSHIBA SYSTEM VOLUME uuid: 58DE8F0CDE8EE19C
ID-2: /dev/sda3 size: 8.12 GiB fs: ntfs label: HDDRECOVERY uuid: 2E88E4AC88E4742D
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 2-4:2 info: Chicony Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip ID: 1d6b:0001
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip ID: 1d6b:0001
Hub: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip ID: 1d6b:0001
Hub: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip ID: 1d6b:0001
Hub: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip ID: 1d6b:0001
Hub: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip ID: 1d6b:0001
Sensors: System Temperatures: cpu: 53.0 C mobo: N/A
Info: Processes: 169 Uptime: 2h 44m Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1365 Shell: Bash
v: 5.0.18 running in: konsole inxi: 3.1.05
