Use Brezee theme, log out, back in and reduce the size manually (specify the pixels), and apply back your theme. If that doesn’t work you might have to ask the developer of your theme to update it.
You can also try manually editing ~/.config/plasmashellrc
in order to set the thickness in pixels there, but…
- You must do that with
nano
from atty
while completely logged out of Plasma; and - You better make a backup of the file before editing its contents.
- The warranty on the above advice expired from the moment you started reading this post.
