Pamac upgrade -a and package manager: authentication failed without even typing my password
Hi forum,
I was trying to update and both options: pamac upgrade -a as well as the package manager give me an authentication failed window without typing my password.
pamac upgrade -a
Vorbereitung...
Authentifizierung wird zur Installation, Aktualisierung oder Entfernung von Paketen benötigt
Authenticating as: euki
==== AUTHENTICATION FAILED ====
Fehler: Authentifizierung fehlgeschlagen
What can I Do?
Thank You Very Much
It’s a transitory polkit problem. :backhand_index_pointing_down:
Thank You Very Much.
Unfortunately it still does not work.
sudo chmod 644 /usr/lib/polkit-1/rules.d/\*
zsh: no matches found: /usr/lib/polkit-1/rules.d/\*
chmod: Zugriff auf '/usr/lib/polkit-1/rules.d/' nicht möglich: Datei oder Verzeichnis nicht gefunden
What did I do wrong?
Thank You Very Much
This simply means there were no rules defined in that directory – so it found no matches – we presume the other parts of the command were successful, as no warnings to the contrary were issued.
Nothing wrong – except for formatting :wink:
:point_right: All code or command output should be placed within a scrollable pre-formatted text enclosure according to forum guidelines, and not a quote box. :eyes:
Please see:
[MiniHowTo] Present code or command output
What is a Quark?
ok, Thank You.. I got that with formatting…please excuse me.
But why does authentification still fails without even typing my password?
I have done all steps mentioned and it still does not work…
Thank You Very Much
I solved the problem by changing Kernel Linux 6.1.159-1 to Linux 6.6.119-1.
Thank You Very Much!
