Hi, I’m using pamac to update, but getting following message…
Transaction Summary To remove: pamac-common 10.0.6-2 (Conflicts With libpamac)
not sure if it is ok to click Apply to continue, I tried to google for answer but couldn’t find an exact match, I think it is ok to continue, but don’t want to risk breaking my system.
thanks for quick reply, I ran the command and was prompted with a warning/error, here is the terminal output…
[hugh@DELL-INSP-MANJARO ~]$ sudo pacman -Syu
[sudo] password for hugh:
:: Synchronising package databases...
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Replace pamac-common with extra/libpamac? [Y/n] y
warning: sndio: local (20180120-1) is newer than community (1.7.0-3)
resolving dependencies...
:: installing pacman (6.0.0-1) breaks dependency 'pacman<5.3' required by package-query
not sure what to do here, but I tried google and found a post on axel-hahn website but can’t enter the url here unfortunately
What I meant with follow the prompts was like - remove conflicting packages - they can be reinstalled after the update sync.
So start with
sudo pacman -R package-query
If you get other dependency errors - add the package to the removal list and when removal succeeds you run the update sync - then when update-sync is successful you reinstall packages - that is - if you need them.
I am sorry if you thought my question was stupid. but I honestly wasn’t aware yaourt was removed. I only asked the question because I wasn’t sure if yaourt or it’s dependencies might be needed for something else in the system.
I try to learn as much as I can but I’m not as sharp as I used to be (74 years old). I was very hurt by your last remark tbh.
this forum has always been most helpful to me over the last few years, so I thank you all for your support.
Best Regards, Hugh
EDIT: I now realise that if I did reinstall yaourt perhaps it would cause same error at the next update . So on hindsight my question was a bit stupid tbh.
