Pamac update icon with at least two colors
Everyday, I’ve the red icon present in my taskbar.
Red is important so, everyday I’ve to click on it, for these kinds of minor updates :
I think it would really help users (especially those who are using Manjaro like me, for office job) to have yellow, orange and red colors to help to decide if it’s urgent or not.
Something based on kernel or core component update (red), software like LibreOffice in orange et other in a yellow color.
It doesn’t mean users have to delay an important update, but help them to know when it’s important to do it.
Learn the difference between pacman and pamac.
As far as I know:
there are only two states
  • there are updates available
  • there are no updates available
You can also adjust the interval in which the checks for new updates are done.
Weekly, for instance.
Then you’d only be bothered every week and can ignore it to be bothered again the next week :wink:
If flatpak is something you use: just update and be done with it.
Or disable the plugin
and/or remove the whole thing altogether?
And: it is the pamac GUI you are talking about, not pacman.
I’ve tried few months ago but can’t memorize it because pacman, pamca pamac, paamc pacamn are too similar (it could be like a joke, but it’s really not).
But i know one is able to manage aur and other repository (flatpak);
Oh, maybe, one is a packet manager, one is a yellow circle eating ghosts (here is the joke :wink: , please take it with no offense)
That’s a solution…
Another solution is to use an icon’s theme with white and black only.
I will use your solution that, because I feel the problem isn’t easy to manage (I was hoping the status was less binary). Thanks.
In that case, could we ask you to mark the post which provided the solution as the Solution? It is customary to do so.
Cheers! :wink:
Whoever came up with the name “pamac” for the Manjaro specific package manager -
it is the name of the thing and we are stuck with it.
The icon in the tray is the update notifier.
It’s start can be disabled entirely.
That is what I do.
… somewhere in “Startup Applications”
but then you’d have to check for updates yourself
another way to look at it is:
you can then decide yourself at which time you want to look and check for updates, instead of being reminded through the icon …
As you discovered yourself, the colors are theme-dependent. For example Papirus-Dark-Maia is black and white only.
The suggestion to have more than 2 icon states is not doable, because it is kind of against the whole arch/manjaro philosophy. It is a hands-on distro and YOU decide what is important and what not. It is not windows which decides for you and gives you no choice.
The image posted indicates supporting files for flatpak.
Information only:
The flatpak update command should ideally clear Flatpak related notifications, once it completes.
