Hello - sorry if this has been answered, I’ve looked around and couldn’t find anything.
Since the last stable update - the pamac system tray widget is missing entirely. It’s not even in the System Tray Settings dialog as an option to enable. I have tried uninstalling and reinstalling pamac-tray-icon-plasma with no effect.
Grateful for any insight!
UPDATE: after several relogs and restarts, it has oddly re-appeared on its own. I still don’t know why this happened.
No. I checked. It is entirely absent. “Always show all entries” simply displays every entry present in that list. The updates one does not appear when this happens.
Reading what @maycne.sonahoz says in this post about stopping Update Manager:
Can you test if app-msm_kde_notifier@autostart.service and app-pamac\x2dtray\x2dplasma@autostart.service are both in “loaded active plugged” status? An easy way to do it:
