Pamac slow, connection errors, sometimes failing
Hi, Sorry if this post doesn’t belong here. Recently I have installed Manjaro, and seemingly out of nowhere Pamac has started throwing out a ton of network unreachable errors to mirror.dacentec .com Some packages install, but some get stuck on that error repeating. I would send a log, but unfortunately I cannot, as it includes links.
click this icon in editor: </> and put the logs there
Preparing...
unable to lock database
Failed to synchronize databases
Resolving dependencies...
Checking inter-conflicts...
http://mirror.dacentec.com/manjaro/stable/community/x86_64/virtualbox-6.1.34-4-x86_64.pkg.tar.zst: Could not connect: Network is unreachable
http://mirror.dacentec.com/manjaro/stable/extra/x86_64/linux515-virtualbox-host-modules-6.1.34-18-x86_64.pkg.tar.zst: Could not connect: Network is unreachable
Download of virtualbox (6.1.34-4) started
Download of linux515-virtualbox-host-modules (6.1.34-18) started
Download of linux515-virtualbox-host-modules (6.1.34-18) finished
Download of virtualbox (6.1.34-4) finished
http://mirror.dacentec.com/manjaro/stable/community/x86_64/virtualbox-guest-iso-6.1.34-1-any.pkg.tar.zst: Could not connect: Network is unreachable
Download of virtualbox-guest-iso (6.1.34-1) started
Download of virtualbox-guest-iso (6.1.34-1) finished
try this:
sudo pacman-mirrors -g
sudo pacman -Syyu
That appears to have fixed it, but it still says
every time I start a transaction. Do I need to worry about this or can I just ignore it?
try this, and see if it helped:
sudo rm /var/lib/pacman/db.lck
sudo pacman -Syyu
Sorry for the late response, it says that no file was found.
Nevermind, it appears to have went away after a restart.
