with the default manjaro themes for manjaro Sway the pamac application has a problem showing the toggle icons for its settings:
using dacula theme it shows normally:
i wonder whats the problem
all themes:
all themes:
are there other gtk/gnome apps you could test with if this is a general problem? Guess we have to determine if there’s an issue with pamac or with the matcha-dark theme. Also you could go with pamac-gtk3, which surely will have different issues.
