I installed manjaro yesterday, and i was able to enable AUR in pamac but today there is no option to enable AUR only have flatpack.
Is support of AUR is permanently removed ? if that’s the case i have to move to different distro ![]()
Close that window, go to your right and click on the … button and disable Software Mode from the dropdown menu.
Turn off Software Mode. [edit: I’m too slow]
To check If AUR is still enabled:
grep EnableAUR /etc/pamac.conf
If response is #EnableAUR AUR is not enabled
If response is EnableAUR AUR is enabled
pamac commands can access AUR with -a / --aur option if AUR is not enabled in pamac-manager GUI
