Pamac related errors in journalctl
When I launch pamac using the icon in the system tray, I get
pamac-manager[3449]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
When I click on the same pamac icon while the windows is open but not in focus, hidden beneath another active windows (in this case Firefox), the window doesn’t come on top. the tab in the taskbar relative to pamac gets highlighted, though, and I get the following :
kwin_core: Cannot grant a token to KWin::ClientConnection(0x5d4504283860)
When I select the Preferences in the pamac window and I’m prompted to enter the password, I get :
kwin_wayland[1028]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x5d45042258c0)
This one is a little more crooked, please bear with me. When I open the preferences, and am prompted for the password, then minimize the popup window prompting for the password, minimize the pamac window, then try again opening the pamac window using the icon in the system tray, the already opened pamac window tab in the tack bar gets highlighted, I open it, select for the same preference that triggers another password prompt window, a windows appears to inform me Authentication failed ; I then close it, go back to the fist one that I had minimized in the beginning and I select cancel. I get a core dump, and the pamac window closes, :
polkit-kde-authentication-agent-1[1349]: Finish obtain authorization: false
kernel: pamac-manager[6034]: segfault at 98 ip 0000726737746e68 sp 00007ffcd4dffcc0 error 4 in libpamac.so.11.7[6ae68,7267376f2000+76000] likely on CPU 9 (core 1, socket 0)
kernel: Code: 00 00 f3 0f 1e fa 55 48 89 e5 53 48 89 fb 48 83 ec 08 8b 07 85 c0 74 7a 83 f8 01 0f 85 30 01 00 00 48 8b 47 20 31 d2 48 89 de <48> 8b 40 18 8b 40 60 89 47 28 48 8b 7f 18 ff 15 8c 7e 04 00 8b 03
systemd-coredump[6137]: Process 6034 (pamac-manager) of user 1000 terminated abnormally with signal 11/SEGV, processing...
systemd[1]: Started Process Core Dump (PID 6137/UID 0).
systemd-coredump[6138]: [🡕] Process 6034 (pamac-manager) of user 1000 dumped core.
                                                      Stack trace of thread 6034:
                                                      #0  0x0000726737746e68 n/a (libpamac.so.11 + 0x6ae68)
                                                      #1  0x000072673773b38d n/a (libpamac.so.11 + 0x5f38d)
                                                      #2  0x0000726737845812 g_closure_invoke (libgobject-2.0.so.0 + 0x11812)
                                                      #3  0x0000726737875f85 n/a (libgobject-2.0.so.0 + 0x41f85)
                                                      #4  0x0000726737866ce9 n/a (libgobject-2.0.so.0 + 0x32ce9)
                                                      #5  0x0000726737867252 g_signal_emit_by_name (libgobject-2.0.so.0 + 0x33252)
                                                      #6  0x000072673772f19b n/a (libpamac.so.11 + 0x5319b)
                                                      #7  0x0000726737845812 g_closure_invoke (libgobject-2.0.so.0 + 0x11812)
                                                      #8  0x0000726737876582 n/a (libgobject-2.0.so.0 + 0x42582)
                                                      #9  0x0000726737866ce9 n/a (libgobject-2.0.so.0 + 0x32ce9)
                                                      #10 0x0000726737866f72 g_signal_emit_valist (libgobject-2.0.so.0 + 0x32f72)
                                                      #11 0x0000726737867034 g_signal_emit (libgobject-2.0.so.0 + 0x33034)
                                                      #12 0x0000726737b045ac n/a (libgio-2.0.so.0 + 0x1195ac)
                                                      #13 0x0000726737aed4f9 n/a (libgio-2.0.so.0 + 0x1024f9)
                                                      #14 0x00007267378f11e4 n/a (libglib-2.0.so.0 + 0x5e1e4)
                                                      #15 0x0000726737954e97 n/a (libglib-2.0.so.0 + 0xc1e97)
                                                      #16 0x00007267378f0615 g_main_context_iteration (libglib-2.0.so.0 + 0x5d615)
                                                      #17 0x0000726737aca7d6 g_application_run (libgio-2.0.so.0 + 0xdf7d6)
                                                      #18 0x000061bfdfbf641d n/a (/usr/bin/pamac-manager + 0xc41d)
                                                      #19 0x0000726737511488 n/a (libc.so.6 + 0x27488)
                                                      #20 0x000072673751154c __libc_start_main (libc.so.6 + 0x2754c)
                                                      #21 0x000061bfdfbf6545 n/a (/usr/bin/pamac-manager + 0xc545)
                                                      Stack trace of thread 6037:
                                                      #0  0x0000726737587be2 n/a (libc.so.6 + 0x9dbe2)
                                                      #1  0x000072673757be33 n/a (libc.so.6 + 0x91e33)
                                                      #2  0x000072673757be74 n/a (libc.so.6 + 0x91e74)
                                                      #3  0x00007267375f6a06 ppoll (libc.so.6 + 0x10ca06)
                                                      #4  0x0000726737954f67 n/a (libglib-2.0.so.0 + 0xc1f67)
                                                      #5  0x00007267378f1ee7 g_main_loop_run (libglib-2.0.so.0 + 0x5eee7)
                                                      #6  0x0000726737affa84 n/a (libgio-2.0.so.0 + 0x114a84)
                                                      #7  0x0000726737928b3e n/a (libglib-2.0.so.0 + 0x95b3e)
                                                      #8  0x000072673757f70a n/a (libc.so.6 + 0x9570a)
                                                      #9  0x0000726737603aac n/a (libc.so.6 + 0x119aac)
                                                      Stack trace of thread 6035:
                                                      #0  0x000072673760188d syscall (libc.so.6 + 0x11788d)
                                                      #1  0x0000726737923450 g_cond_wait (libglib-2.0.so.0 + 0x90450)
                                                      #2  0x00007267378b8dac n/a (libglib-2.0.so.0 + 0x25dac)
                                                      #3  0x0000726737929ad2 n/a (libglib-2.0.so.0 + 0x96ad2)
                                                      #4  0x0000726737928b3e n/a (libglib-2.0.so.0 + 0x95b3e)
                                                      #5  0x000072673757f70a n/a (libc.so.6 + 0x9570a)
                                                      #6  0x0000726737603aac n/a (libc.so.6 + 0x119aac)
                                                      Stack trace of thread 6040:
                                                      #3  0x00007267378b8e1d g_async_queue_pop (libglib-2.0.so.0 + 0x25e1d)
                                                      #4  0x00007267371f492c n/a (libpangoft2-1.0.so.0 + 0xd92c)
                                                      #5  0x0000726737928b3e n/a (libglib-2.0.so.0 + 0x95b3e)
                                                      #6  0x000072673757f70a n/a (libc.so.6 + 0x9570a)
                                                      #7  0x0000726737603aac n/a (libc.so.6 + 0x119aac)
                                                      Stack trace of thread 6036:
                                                      #5  0x00007267378f0615 g_main_context_iteration (libglib-2.0.so.0 + 0x5d615)
                                                      #6  0x00007267378f0672 n/a (libglib-2.0.so.0 + 0x5d672)
                                                      Stack trace of thread 6039:
                                                      #6  0x00007267307952fe n/a (libdconfsettings.so + 0x62fe)
When I have flatpak enabled in the preferences, I get this line, each time I click on the system tray icon, even if the check for update option is not enabled :
pamac-manager[3449]: manager_window.vala:2436: /var/lib/flatpak/appstream/flathub/x86_64/active/icons/64x64/com.skype.Client.desktop.png: Failed to open file “/var/lib/flatpak/appstream/flathub/x86_64/active/icons/64x64/com.skype.Client.desktop.png”: No such file or directory
Which is strange, because I do not have any flatpak package installed, and I do not use skype - perhaps I installed it a long time ago, and uninstalled it, but still, it seems pamac still checks it. I’ve tried to disable and re-enable flatpack in the Preferences, but the error always comes back when it’s enabled.
I’d like to correct what triggers flatpak’s skype thing ; for the rest, it’s there to give feedback.
