I used to install AUR packages with pamac (either pamac-gtk or pamac-cli), and I was able to edit the PKGBUILD for the AUR packages with them. In my case it is zoom that I need to remove the ibus dependency to make it install on my system. This feature suddenly stops working maybe since the last update. I tried to manually edit the PKGBUILD before upgrading zoom today to remove ibus as a dependency. However, after editing, it kept asking me if I agree to install ibus as a dependency. This behaviour happened on both pamac-gtk and pamac-cli, so I think it may be a libpamac problem.
Eventually I just downloaded the PKGBUILD, edited it, and then use makepkg to create the zst and use pacman -U to install it. I hope the devs can investigate if this is a pamac’s issue.
Here’s my system information:
摘要
Kernel: 5.10.63-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: initrd=\amd-ucode.img initrd=\intel-ucode.img
initrd=\initramfs-5.10-x86_64.img zfs=zroot/manjaro/root rw
bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7C37 v: 3.0 serial: <filter>
Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0 serial: <filter>
UEFI: American Megatrends LLC. v: H.D4 date: 04/09/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
Info: 8-Core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201009 cache:
L2: 4 MiB
bogomips: 121658
Speed: 3624 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
1: 3624 2: 3372 3: 2882 4: 3601 5: 2886 6: 2887 7: 3870 8: 3870 9: 3210
10: 3607 11: 2884 12: 2891 13: 2886 14: 2901 15: 3457 16: 2904
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: NVIDIA TU104 [GeForce RTX 2080] vendor: Gigabyte driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 2d:00.0
chip-ID: 10de:1e82 class-ID: 0300
Device-2: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2:3 chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 3840x2160 s-dpi: 159 s-size: 613x352mm (24.1x13.9")
s-diag: 707mm (27.8")
Monitor-1: DP-0 res: 3840x2160 hz: 60 dpi: 161 size: 607x345mm (23.9x13.6")
diag: 698mm (27.5")
OpenGL: renderer: NVIDIA GeForce RTX 2080/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 2d:00.1 chip-ID: 10de:10f8 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI X570-A PRO
driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.10.63-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel port: d000
bus-ID: 27:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp39s0 state: down mac: <filter>
Device-2: Edimax Edimax AC1750 USB type: USB driver: 8814au bus-ID: 1-1:2
chip-ID: 7392:a833 class-ID: 0000 serial: <filter>
IF: wlp42s0f1u1 state: up mac: <filter>
Supported mdraid levels: raid1
Device-1: md127 maj-min: 9:127 type: mdraid level: mirror status: active
Info: report: 2/2 UU blocks: 526272 chunk-size: N/A super-blocks: 1.0
Components: Online:
0: nvme0n1p1 maj-min: 259:2 size: 514 MiB
1: nvme1n1p1 maj-min: 259:5 size: 514 MiB
Device-2: zbigdata type: zfs status: ONLINE level: linear raw:
size: 1.81 TiB free: 1.08 TiB allocated: 750 GiB zfs-fs: size: 1.76 TiB
free: 1.02 TiB
Components: Online:
1: sdb maj-min: 8:16 size: 1.82 TiB
Device-3: zhome type: zfs status: ONLINE level: linear raw: size: 464 GiB
free: 316 GiB allocated: 148 GiB zfs-fs: size: 449.62 GiB free: 301.25 GiB
Components: Online:
1: sda maj-min: 8:0 size: 465.76 GiB
Device-4: zroot type: zfs status: ONLINE level: mirror raw: size: 920 GiB
free: 625 GiB allocated: 295 GiB zfs-fs: size: 891.5 GiB free: 596.03 GiB
Components: Online:
1: nvme0n1p3 maj-min: 259:4 size: 921.01 GiB
2: nvme1n1p3 maj-min: 259:7 size: 921.01 GiB
Local Storage: total: raw: 4.09 TiB usable: 5.35 TiB used: 1.12 TiB (20.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP600
lanes: 4 type: SSD serial: <filter> rev: EGFM13.0 temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Corsair model: Force MP600
lanes: 4 type: SSD serial: <filter> rev: EGFM13.0 temp: 33.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DX002-2DV164
type: HDD rpm: 7200 serial: <filter> rev: CC41 scheme: GPT
ID-1: / raw-size: N/A size: 859.92 GiB used: 263.89 GiB (30.7%) fs: zfs
logical: zroot/manjaro/root
ID-2: /boot raw-size: 512.9 MiB size: 511.9 MiB (99.80%)
used: 122.8 MiB (24.0%) fs: vfat dev: /dev/md127p1 maj-min: 259:8
ID-3: /home raw-size: N/A size: 432.37 GiB used: 131.12 GiB (30.3%) fs: zfs
logical: zhome/manjaro/home
ID-1: swap-1 type: partition size: 10 GiB used: 16.7 MiB (0.2%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:3
ID-2: swap-2 type: partition size: 10 GiB used: 16.8 MiB (0.2%) priority: -3
dev: /dev/nvme1n1p2 maj-min: 259:6
System Temperatures: cpu: 48.4 C mobo: 34.0 C gpu: nvidia temp: 48 C
Fan Speeds (RPM): fan-1: 1254 fan-2: 2360 fan-3: 825 fan-4: 591 fan-5: 0
fan-6: 0 fan-7: 1373 gpu: nvidia fan: 0%
Processes: 561 Uptime: 13h 34m wakeups: 121 Memory: 15.61 GiB
used: 11.82 GiB (75.7%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1624 lib: 376 Shell: Bash
v: 5.1.8 running-in: yakuake inxi: 3.3.06
