For some reason, I cannot find pamac or octopi. I tried to to load apper but no luck. Consequently I have no package manager.
I’m a newbie so please be kind. Would be grateful for some
general advice.
What iso did you install? I am pretty sure they all come with pamac.
But the old Arch standard is pacman.
pacman -Qs pamac
The above command will search installed packages for pamac.
And heres the wiki section for how to manage software with manjaro:
https://wiki.manjaro.org/index.php/Main_Page#Software_Management
Hi,
Thank you for your help. I have now installed pamac.
The iso used was MANJARO_XFCE_212RC1.
Think I must have lost pamac but not sure how!
Are you really sure Pamac was missing? Pamac is the default package manager of Manjaro and it comes pre-installed with Manjaro’s Xfce edition. But, you won’t find the menu item Pamac, because in the menu Pamac is called Add/Remove Software. So maybe there is just a little misunderstanding.
