What’s the output to
lsb_release --all
lsb_release --all
So after
Alkaris still did not that?
I though that we went further, and the getting all of updates is already in the past.
Try to re-install all packages, including pamac
(cause pamac
has several dependencies of packages) with re-configuring the pamac
(case of config files is bad and pamac uses a wrongly read value at some point (that 95%) and than segfauls while trying to use that faulty value):
rm -rf ~/.config/pamac
sudo pacman -Scc
(Y
everywhere)pacman
: pacman/Tips and tricks - ArchWiki$ su
enter root’s password (not your user’s one; that password you already entered at least at the OS installation stage) and than
# pacman -Qqn | pacman -S -
and after
# exit
Reboot the PC and re-check the db update via terminal
$ pamac update --force-refresh
if still segfaults, re-initialize other pamac
dependencies like re-installation DBs and keys: Update archive corrupted - #10 by linux-aarhus
If you want you can report your case in order to get developers support, if you believe that it is the app problem and not your environment case: Issues · Applications / pamac · GitLab
But all participants/poster of that thread don’t have that issue, otherwise they would tell about that problem too. I think most probably it is your environment issue (other software around pamac or hardware).
There’s no mention of a bad or corrupted DB at all, also I don’t know what version of pamac you’re using, but Pamac does not have the flag option --force-refresh
, the list of available option flags are as follows;
$ pamac --force-refresh
Available actions:
pamac --version
pamac --help, -h [action]
pamac search [options] <package(s)>
pamac list [options] <package(s)>
pamac info [options] <package(s)>
pamac install [options] <package(s)>
pamac reinstall [options] <package(s)>
pamac remove [options] [package(s)]
pamac checkupdates [options]
pamac update,upgrade [options]
pamac clone [options] <package(s)>
pamac build [options] [package(s)]
pamac clean [options]
Ok now you’re just running off into the deep end and assuming things now.
this is what I get;
LSB Version: n/a
Distributor ID: ManjaroLinux
Description: Manjaro Linux
Release: 21.1.4
Codename: Pahvo
pamac update -h
we can also use:
man pamac
Because you think anyone here knows what is causing your issue?
Try things. It doesn’t hurt.
If to look into the [Stable Update] 2021-09-24 - Kernels, LibreOffice, Browsers, Pipewire, RHVoice, KDE Frameworks, Mesa - #3 by philm
then we can see that possible correlation with suggestion to re-install all packages:
I suggested to re-install all packages at once (and pamac’s config also: how many time you will re-configure the pamac settings? 30 or 40 seconds?) cause you may have another packages and software libraries damaged on storage, so that possible solution covers more cases at once, but download and installation of all that stuff (about 1.5 GB) will take some time.
Or may be you already tried to re-install pamac with all of if dependencies.
Also, do you know how pamac or an app works on try to read a file with a bad block? What if pamac segfaults while read that corrupted DB? Or may be you know for sure that it can’t be?
I think you waste more time to resist to the idea of a possible solution (only possible, not exactly 100% warranty of fix) than to get it tried already. It is your choice to be a new posts writer or to came a bit closer or even solve the issue.
Even more: may be pamac segfaults on try to show you a note that a DB is corrupted. But somehow you judges by yourself that there is no correlation.
Pamac Segmentation Fault: Pamac Segmentation Fault - #6 by The_Quantum_Alpha
The
reinstall
accepted as solution.
@Alkaris forgot to read manual of pamac
(--force-refresh
), forgot to search the forum? What comfort you get using somewhat without tries to learn it more? Less knowledge brings less abilities, less choice options, so less comfort.
False, and you just assumed, yet again.
Yet you assume again, and throw out more useless information. Enough already.
This topics dead, no point telling me more useless information thats not going to help me here.
CASE CLOSED!
Closed as per OP’s request. As no solution was posted, solution was removed.
