Pamac not dark after update
Hello,
I use the matcha-dark-aliz style for my installs. Today I updated via pamac. When I rebooted and opened pamac, it was in light mode. Not sure how to change it back to dark while using the matcha theme. If I use the adwaita-dark theme pamac returns to being dark. This happened on both my laptops which run very similar styles.
Looking for suggestions on how I could fix it. I appreciate it, thank you.
Here are some examples.
sudo pacman -R pamac-gtk && sudo pacman -S pamac-gtk3
Edit: Corrected the typo.
target not found: pamac-gtk4
I have pamac-gtk package installed. Should it be that one?
I had made a(n important) typo in my previous post, but I’ve corrected that now. Please see the edited version. :wink:
I tried the updated command. However now I get something about dependencies.
checking dependencies...
:: removing pamac-gtk breaks dependency 'pamac-gtk' required by manjaro-application-utility
Try this then… :arrow_down:
sudo pacman -Rdd pamac-gtk && sudo pacman -S pamac-gtk3
Awesome thank you. That worked.
