On doing pamac upgrade, I am getting this error:
Warning: multilib.db: lock file missing /var/tmp/pamac/dbs/db.lck
https://aur.manjaro.org/packages-meta-ext-v1.json.gz: Error opening file “/var/tmp/pamac-build-pyrole/packages-meta-ext-v1.json.gz.part”: File exists
Failed to synchronize AUR database
How to fix this?
This is a recurring issue with the CDN77 - something goes haywire in the certificate chain.
It seems the file is only partially downloaded and permissions is wrong - I have seen this form time to time.
sudo rm -rf /var/tmp/pamac*
Disable the check for AUR updates in Pamac preferences - or edit the file /etc/pamac.conf and comment the setting.
$ cat /etc/pamac.conf
## When AUR support is enabled check for updates from AUR:
#CheckAURUpdates
Well I just ran pamac upgrade again and it works now without doing anything. Will keep the above in mind just for future.
