Pamac Manager takes long delay to start
The reason is this, (from the console):
pamac-manager
** Message: 08:57:49.105: flatpak_plugin.vala:393: refreshing flathub appstream data
** (process:5499): WARNING **: 09:00:49.507: flatpak_plugin.vala:398: While pulling appstream2/x86_64 from remote flathub: While fetching https://dl.flathub.org/repo/delta-indexes/1g/rdmbJOYEewnufEmj+llieQH9y7cwYAbiNM3gsAyq8.index: [28] Timeout was reached
** Message: 09:00:51.335: flatpak_plugin.vala:393: refreshing flathub appstream data
** (pamac-manager:5499): WARNING **: 09:03:51.713: flatpak_plugin.vala:398: Enquanto executava pull de appstream2/x86_64 a partir do remoto flathub: While fetching https://dl.flathub.org/repo/delta-indexes/1g/rdmbJOYEewnufEmj+llieQH9y7cwYAbiNM3gsAyq8.index: [28] Timeout was reached
(pamac-manager:5499): Gdk-CRITICAL **: 09:03:51.763: gdk_window_set_cursor: assertion ‘GDK_IS_WINDOW (window)’ failed
Is it my network? ( 404 Not Found )
Yes it is.
Thanks!, now it’s working :grinning_face:
Could also be the Flathub. They did some update of the webserver several days ago and the site was broken for 1-2 days, but now seems normal again.
I am having the same problem on 6 computers running manjaro. It takes a really long time to launch via terminal (6 mins and 4 seconds), and times out via the application launcher shortcut.
Edit: Disabling flatpak support in pamac gui seems to have it launching normally now.
About 7-8 hours ago i couldn’t check for updates for flatpaks from the terminal with the flatpak command (i do not use pamac for that). And i was happily streaming video and browsing so i guess they have intermittent infrastructure problems.
