Pamac manager > settings not working
Hi,
Running Zetar XFCE.
When I strat pamac manager (gui) I can update, upgrade no matters.
But when I start the screen “Settings” the window appears 1 second and pamac closes.
I restarted it via the console:
$ pamac-manager
(pamac-manager:2301): Gdk-CRITICAL **: 09:51:45.532: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Erreur de segmentation (core dumped)
The last updates :
[2025-05-03T09:23:53+0200] [ALPM] upgraded nvidia-driver-assistant (0.20.124.06-1 -> 0.21.51.03-1)
[2025-05-03T09:23:38+0200] [ALPM] upgraded archlinux-keyring (20250123-1 -> 20250430.1-1)
[2025-05-02T09:57:51+0200] [ALPM] installed wmctrl (1.07-6)
Sys:
$ uname -a
Linux SysMan 6.12.21-4-MANJARO #1 SMP PREEMPT_DYNAMIC Tue, 01 Apr 2025 18:45:30 +0000 x86_64 GNU/Linux
$ xfce4-about -V
xfce4-about 4.20.1 (Xfce 4.20)
Thx for help
First, check what Pamac version you are running.
  • pamac-gtk (gtk4) was developed for Gnome.
  • pamac-gtk3 was created for gtk desktops without gtk4 support like Xfce, Cinnamon, Mate etc.
Same happens when starting like this?
G_MESSAGES_DEBUG=all GSK_RENDERER=opengl LC_ALL=C pamac-manager
$ G_MESSAGES_DEBUG=all GSK_RENDERER=opengl LC_ALL=C pamac-manager
(process:6348): GLib-GIO-DEBUG: 11:54:01.801: _g_io_module_get_default: Found default implementation gvfs (GDaemonVfs) for ?gio-vfs?
(process:6348): GLib-DEBUG: 11:54:01.808: setenv()/putenv() are not thread-safe and should not be used after threads are created
(process:6348): GLib-DEBUG: 11:54:01.809: setenv()/putenv() are not thread-safe and should not be used after threads are created
(process:6348): OSTree-DEBUG: 11:54:02.349: using fuse: 0
(process:6348): GLib-DEBUG: 11:54:02.350: unsetenv() is not thread-safe and should not be used after threads are created
(pamac-manager:6348): GLib-DEBUG: 11:54:02.388: unsetenv() is not thread-safe and should not be used after threads are created
(pamac-manager:6348): Gtk-DEBUG: 11:54:02.388: Connecting to session manager
(pamac-manager:6348): Gtk-DEBUG: 11:54:02.389: Failed to get the GNOME session proxy: The name org.gnome.SessionManager is not owned
(pamac-manager:6348): Gdk-CRITICAL **: 11:54:02.643: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Same error.
Pamac 10.7.0
I just realized that pamac doesn’t work anymore here is an update in debug mode:
$  sudo pacman -Syu --debug
debug: pacman v7.0.0 - libalpm v15.0.0
debug: config: new section 'options'
debug: config: CacheDir: /var/cache/pacman/pkg/
debug: config: HoldPkg: pacman
debug: config: HoldPkg: glibc
debug: config: HoldPkg: manjaro-system
debug: config: Architecture: auto
debug: config: arch: x86_64
debug: config: SigLevel: Required
debug: config: SigLevel: DatabaseOptional
debug: config: LocalFileSigLevel: Optional
debug: config: new section 'core'
debug: config: SigLevel: PackageRequired
debug: config file /etc/pacman.conf, line 76: including /etc/pacman.d/mirrorlist
debug: config: new section 'extra'
debug: config file /etc/pacman.conf, line 80: including /etc/pacman.d/mirrorlist
debug: config: new section 'multilib'
debug: config file /etc/pacman.conf, line 87: including /etc/pacman.d/mirrorlist
debug: config: finished parsing /etc/pacman.conf
debug: setup_libalpm called
debug: option 'logfile' = /var/log/pacman.log
debug: option 'gpgdir' = /etc/pacman.d/gnupg/
debug: option 'hookdir' = /etc/pacman.d/hooks/
debug: option 'cachedir' = /var/cache/pacman/pkg/
debug: registering sync database 'core'
debug: database path for tree core set to /var/lib/pacman/sync/core.db
debug: "/var/lib/pacman/sync/core.db.sig" is not readable: Aucun fichier ou dossier de ce nom
debug: sig path /var/lib/pacman/sync/core.db.sig could not be opened
debug: got error 43 at _alpm_gpgme_checksig (../lib/libalpm/signing.c: 599) : signature PGP manquante
debug: missing optional signature
debug: setting usage of 15 for core repository
debug: adding new server URL to database 'core': https://manjaro.kurdy.org/stable/core/x86_64
debug: adding new server URL to database 'core': https://mirrors2.manjaro.org/stable/core/x86_64
debug: adding new server URL to database 'core': http://ftp.belnet.be/mirrors/manjaro/repos/stable/core/x86_64
debug: adding new server URL to database 'core': http://ftp.uni-kl.de/pub/linux/manjaro/stable/core/x86_64
debug: adding new server URL to database 'core': https://mirror.alwyzon.net/manjaro/stable/core/x86_64
debug: adding new server URL to database 'core': https://mirror.alpix.eu/manjaro/stable/core/x86_64
debug: adding new server URL to database 'core': https://mirrors.dotsrc.org/manjaro/stable/core/x86_64
debug: adding new server URL to database 'core': https://mirror.aarnet.edu.au/pub/manjaro/stable/core/x86_64
debug: registering sync database 'extra'
debug: database path for tree extra set to /var/lib/pacman/sync/extra.db
debug: "/var/lib/pacman/sync/extra.db.sig" is not readable: Aucun fichier ou dossier de ce nom
debug: sig path /var/lib/pacman/sync/extra.db.sig could not be opened
debug: setting usage of 15 for extra repository
debug: adding new server URL to database 'extra': https://manjaro.kurdy.org/stable/extra/x86_64
debug: adding new server URL to database 'extra': https://mirrors2.manjaro.org/stable/extra/x86_64
debug: adding new server URL to database 'extra': http://ftp.belnet.be/mirrors/manjaro/repos/stable/extra/x86_64
debug: adding new server URL to database 'extra': http://ftp.uni-kl.de/pub/linux/manjaro/stable/extra/x86_64
debug: adding new server URL to database 'extra': https://mirror.alwyzon.net/manjaro/stable/extra/x86_64
debug: adding new server URL to database 'extra': https://mirror.alpix.eu/manjaro/stable/extra/x86_64
debug: adding new server URL to database 'extra': https://mirrors.dotsrc.org/manjaro/stable/extra/x86_64
debug: adding new server URL to database 'extra': https://mirror.aarnet.edu.au/pub/manjaro/stable/extra/x86_64
debug: registering sync database 'multilib'
debug: database path for tree multilib set to /var/lib/pacman/sync/multilib.db
debug: "/var/lib/pacman/sync/multilib.db.sig" is not readable: Aucun fichier ou dossier de ce nom
debug: sig path /var/lib/pacman/sync/multilib.db.sig could not be opened
debug: setting usage of 15 for multilib repository
debug: adding new server URL to database 'multilib': https://manjaro.kurdy.org/stable/multilib/x86_64
debug: adding new server URL to database 'multilib': https://mirrors2.manjaro.org/stable/multilib/x86_64
debug: adding new server URL to database 'multilib': http://ftp.belnet.be/mirrors/manjaro/repos/stable/multilib/x86_64
debug: adding new server URL to database 'multilib': http://ftp.uni-kl.de/pub/linux/manjaro/stable/multilib/x86_64
debug: adding new server URL to database 'multilib': https://mirror.alwyzon.net/manjaro/stable/multilib/x86_64
debug: adding new server URL to database 'multilib': https://mirror.alpix.eu/manjaro/stable/multilib/x86_64
debug: adding new server URL to database 'multilib': https://mirrors.dotsrc.org/manjaro/stable/multilib/x86_64
debug: adding new server URL to database 'multilib': https://mirror.aarnet.edu.au/pub/manjaro/stable/multilib/x86_64
debug: option 'sandboxuser' = (null)
:: Synchronisation des bases de données de paquets…
debug: got error 10 at alpm_db_update (../lib/libalpm/be_sync.c: 164) : verrouillage de la base de données impossible
debug: failed to sync dbs: verrouillage de la base de données impossible
erreur : la synchronisation de toutes les bases de données a échoué (verrouillage de la base de données impossible)
debug: unregistering database 'local'
debug: unregistering database 'core'
debug: unregistering database 'extra'
debug: unregistering database 'multilib'
I reboot the system, everything is fine :face_with_raised_eyebrow:
