when trying to start pamac (gui) from the KDE menu, I get quite often this (journalctl --boot=0 -f output while starting pamac from menu):
jaan 01 20:11:54 Zen systemd[1690]: Created slice Slice /app/dbus-:1.2-org.manjaro.pamac.manager.
jaan 01 20:11:54 Zen systemd[1690]: Started dbus-:1.2-org.manjaro.pamac.manager@0.service.
jaan 01 20:11:55 Zen systemd[1]: Starting Pamac Daemon...
jaan 01 20:11:55 Zen systemd[1]: Started Pamac Daemon.
jaan 01 20:11:55 Zen pamac-manager[8029]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
jaan 01 20:11:55 Zen kernel: show_signal_msg: 156 callbacks suppressed
jaan 01 20:11:55 Zen kernel: pamac-manager[8046]: segfault at 90 ip 00007f09a5fec38c sp 00007f0998c24b78 error 4 in libpamac.so.11.7[7f09a5f9f000+76000] likely on CPU 0 (core 0, socket 0)
jaan 01 20:11:55 Zen kernel: Code: 35 e9 48 03 00 31 ff 48 89 e5 ff 15 5e ef 04 00 31 c0 5d c3 66 2e 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 48 85 ff 74 1f 48 8b 07 <48> 8b 80 90 00 00 00 48 85 c0 74 08 ff e0 66 0f 1f 44 00 00 31 c0
jaan 01 20:11:55 Zen systemd-coredump[8047]: Process 8029 (pamac-manager) of user 1000 terminated abnormally with signal 11/SEGV, processing...
jaan 01 20:11:55 Zen systemd[1]: Created slice Slice /system/drkonqi-coredump-processor.
jaan 01 20:11:55 Zen systemd[1]: Created slice Slice /system/systemd-coredump.
jaan 01 20:11:55 Zen systemd[1]: Started Process Core Dump (PID 8047/UID 0).
jaan 01 20:11:55 Zen systemd[1]: Started Pass systemd-coredump journal entries to relevant user for potential DrKonqi handling.
jaan 01 20:11:56 Zen systemd-coredump[8048]: [🡕] Process 8029 (pamac-manager) of user 1000 dumped core.
Stack trace of thread 8046:
#0 0x00007f09a5fec38c pamac_app_get_id (libpamac.so.11 + 0x6338c)
#1 0x00007f09a3a7f524 n/a (libpamac-appstream.so + 0x4524)
#2 0x00007f09a5fbf3b2 n/a (libpamac.so.11 + 0x363b2)
#3 0x00007f09a6173be6 n/a (libglib-2.0.so.0 + 0x92be6)
#4 0x00007f09a5e2c39d n/a (libc.so.6 + 0x9439d)
#5 0x00007f09a5eb149c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 8029:
#0 0x00007f09a5e3941b n/a (libc.so.6 + 0xa141b)
#1 0x00007f09a5e3bc60 n/a (libc.so.6 + 0xa3c60)
#2 0x00007f09a5e3dfae __libc_calloc (libc.so.6 + 0xa5fae)
#3 0x00007f09a6144e63 g_malloc0 (libglib-2.0.so.0 + 0x63e63)
#4 0x00007f09a6532231 n/a (libgtk-3.so.0 + 0x132231)
#5 0x00007f09a651b05b n/a (libgtk-3.so.0 + 0x11b05b)
#6 0x00007f09a6515c2b n/a (libgtk-3.so.0 + 0x115c2b)
#7 0x00007f09a6515ec8 n/a (libgtk-3.so.0 + 0x115ec8)
#8 0x00007f09a676a947 n/a (libgtk-3.so.0 + 0x36a947)
#9 0x00007f09a6c0c82a g_closure_invoke (libgobject-2.0.so.0 + 0x1182a)
#10 0x00007f09a6c3d6a2 n/a (libgobject-2.0.so.0 + 0x426a2)
#11 0x00007f09a6c2dca9 n/a (libgobject-2.0.so.0 + 0x32ca9)
#12 0x00007f09a6c2df32 g_signal_emit_valist (libgobject-2.0.so.0 + 0x32f32)
#13 0x00007f09a6c2dff4 g_signal_emit (libgobject-2.0.so.0 + 0x32ff4)
#14 0x00007f09a6749293 gtk_widget_show (libgtk-3.so.0 + 0x349293)
#15 0x00007f09a676be10 gtk_window_present_with_time (libgtk-3.so.0 + 0x36be10)
#16 0x0000556e8f7c8f59 n/a (pamac-manager + 0x2bf59)
#17 0x00007f09a6c2de1c n/a (libgobject-2.0.so.0 + 0x32e1c)
#18 0x00007f09a6c2e212 g_signal_emit_by_name (libgobject-2.0.so.0 + 0x33212)
#19 0x00007f09a630e104 n/a (libgio-2.0.so.0 + 0xdd104)
#20 0x00007f09a6338ed2 n/a (libgio-2.0.so.0 + 0x107ed2)
#21 0x00007f09a613e559 n/a (libglib-2.0.so.0 + 0x5d559)
#22 0x00007f09a61a1257 n/a (libglib-2.0.so.0 + 0xc0257)
#23 0x00007f09a613da55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
#24 0x00007f09a630fcb6 g_application_run (libgio-2.0.so.0 + 0xdecb6)
#25 0x0000556e8f7a941d n/a (pamac-manager + 0xc41d)
#26 0x00007f09a5dbde08 n/a (libc.so.6 + 0x25e08)
#27 0x00007f09a5dbdecc __libc_start_main (libc.so.6 + 0x25ecc)
#28 0x0000556e8f7a9545 n/a (pamac-manager + 0xc545)
Stack trace of thread 8032:
#0 0x00007f09a5ea3bb0 ppoll (libc.so.6 + 0x10bbb0)
#1 0x00007f09a61a1327 n/a (libglib-2.0.so.0 + 0xc0327)
#2 0x00007f09a613f287 g_main_loop_run (libglib-2.0.so.0 + 0x5e287)
#3 0x00007f09a6344bc4 n/a (libgio-2.0.so.0 + 0x113bc4)
#4 0x00007f09a6173be6 n/a (libglib-2.0.so.0 + 0x92be6)
#5 0x00007f09a5e2c39d n/a (libc.so.6 + 0x9439d)
#6 0x00007f09a5eb149c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 8033:
#0 0x00007f09a5eaf1fd syscall (libc.so.6 + 0x1171fd)
#1 0x00007f09a61708f7 g_cond_wait_until (libglib-2.0.so.0 + 0x8f8f7)
#2 0x00007f09a6106955 n/a (libglib-2.0.so.0 + 0x25955)
#3 0x00007f09a6106ac8 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x25ac8)
#4 0x00007f09a6176b30 n/a (libglib-2.0.so.0 + 0x95b30)
#5 0x00007f09a6173be6 n/a (libglib-2.0.so.0 + 0x92be6)
#6 0x00007f09a5e2c39d n/a (libc.so.6 + 0x9439d)
#7 0x00007f09a5eb149c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 8031:
#2 0x00007f09a613da55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
#3 0x00007f09a613dab2 n/a (libglib-2.0.so.0 + 0x5cab2)
Stack trace of thread 8030:
#1 0x00007f09a616fbe0 g_cond_wait (libglib-2.0.so.0 + 0x8ebe0)
#2 0x00007f09a610698c n/a (libglib-2.0.so.0 + 0x2598c)
#3 0x00007f09a6176237 n/a (libglib-2.0.so.0 + 0x95237)
Stack trace of thread 8034:
#3 0x00007f09a396d2fe n/a (libdconfsettings.so + 0x62fe)
Stack trace of thread 8035:
#3 0x00007f09a61069fd g_async_queue_pop (libglib-2.0.so.0 + 0x259fd)
#4 0x00007f09a6bd25fc n/a (libpangoft2-1.0.so.0 + 0xc5fc)
jaan 01 20:11:56 Zen systemd[1]: systemd-coredump@0-8047-0.service: Deactivated successfully.
jaan 01 20:11:56 Zen systemd[1690]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Main process exited, code=dumped, status=11/SEGV
jaan 01 20:11:56 Zen systemd[1690]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Failed with result 'core-dump'.
jaan 01 20:11:56 Zen systemd[1690]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Consumed 809ms CPU time, 199.1M memory peak.
jaan 01 20:11:56 Zen systemd[1]: systemd-coredump@0-8047-0.service: Consumed 661ms CPU time, 241.8M memory peak.
jaan 01 20:11:56 Zen drkonqi-coredump-processor[8049]: "/usr/bin/pamac-manager" 8029 "/var/lib/systemd/coredump/core.pamac-manager.1000.03db876c7ba94c7f897b0a3d0b333add.8029.1735755115000000.zst"
jaan 01 20:11:56 Zen systemd[1690]: Started Launch DrKonqi for a systemd-coredump crash (PID 8049/UID 0).
jaan 01 20:11:57 Zen systemd[1]: drkonqi-coredump-processor@0-8047-0.service: Deactivated successfully.
jaan 01 20:12:04 Zen systemd[1690]: Started dbus-:1.2-org.manjaro.pamac.manager@1.service.
jaan 01 20:12:04 Zen pamac-manager[8094]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
jaan 01 20:12:04 Zen kernel: pamac-manager[8101]: segfault at 90 ip 00007fee1198c38c sp 00007fedf3ffeb78 error 4 in libpamac.so.11.7[7fee1193f000+76000] likely on CPU 3 (core 3, socket 0)
jaan 01 20:12:04 Zen kernel: Code: 35 e9 48 03 00 31 ff 48 89 e5 ff 15 5e ef 04 00 31 c0 5d c3 66 2e 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 48 85 ff 74 1f 48 8b 07 <48> 8b 80 90 00 00 00 48 85 c0 74 08 ff e0 66 0f 1f 44 00 00 31 c0
jaan 01 20:12:04 Zen systemd-coredump[8102]: Process 8094 (pamac-manager) of user 1000 terminated abnormally with signal 11/SEGV, processing...
jaan 01 20:12:04 Zen systemd[1]: Started Process Core Dump (PID 8102/UID 0).
jaan 01 20:12:04 Zen systemd[1]: Started Pass systemd-coredump journal entries to relevant user for potential DrKonqi handling.
jaan 01 20:12:05 Zen systemd-coredump[8103]: [🡕] Process 8094 (pamac-manager) of user 1000 dumped core.
Stack trace of thread 8101:
#0 0x00007fee1198c38c pamac_app_get_id (libpamac.so.11 + 0x6338c)
#1 0x00007fee0f40b524 n/a (libpamac-appstream.so + 0x4524)
#2 0x00007fee1195f3b2 n/a (libpamac.so.11 + 0x363b2)
#3 0x00007fee11b73be6 n/a (libglib-2.0.so.0 + 0x92be6)
#4 0x00007fee117cc39d n/a (libc.so.6 + 0x9439d)
#5 0x00007fee1185149c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 8094:
#0 0x00007fee11f15313 n/a (libgtk-3.so.0 + 0x115313)
#1 0x00007fee12096ecf n/a (libgtk-3.so.0 + 0x296ecf)
#2 0x00007fee11f32308 n/a (libgtk-3.so.0 + 0x132308)
#3 0x00007fee11f1b05b n/a (libgtk-3.so.0 + 0x11b05b)
#4 0x00007fee11f15c2b n/a (libgtk-3.so.0 + 0x115c2b)
#5 0x00007fee11f15ec8 n/a (libgtk-3.so.0 + 0x115ec8)
#6 0x00007fee1216a947 n/a (libgtk-3.so.0 + 0x36a947)
#7 0x00007fee11a9282a g_closure_invoke (libgobject-2.0.so.0 + 0x1182a)
#8 0x00007fee11ac36a2 n/a (libgobject-2.0.so.0 + 0x426a2)
#9 0x00007fee11ab3ca9 n/a (libgobject-2.0.so.0 + 0x32ca9)
#10 0x00007fee11ab3f32 g_signal_emit_valist (libgobject-2.0.so.0 + 0x32f32)
#11 0x00007fee11ab3ff4 g_signal_emit (libgobject-2.0.so.0 + 0x32ff4)
#12 0x00007fee12149293 gtk_widget_show (libgtk-3.so.0 + 0x349293)
#13 0x00007fee1216be10 gtk_window_present_with_time (libgtk-3.so.0 + 0x36be10)
#14 0x00005646ffee0f59 n/a (pamac-manager + 0x2bf59)
#15 0x00007fee11ab3e1c n/a (libgobject-2.0.so.0 + 0x32e1c)
#16 0x00007fee11ab4212 g_signal_emit_by_name (libgobject-2.0.so.0 + 0x33212)
#17 0x00007fee11d0e104 n/a (libgio-2.0.so.0 + 0xdd104)
#18 0x00007fee11d38ed2 n/a (libgio-2.0.so.0 + 0x107ed2)
#19 0x00007fee11b3e559 n/a (libglib-2.0.so.0 + 0x5d559)
#20 0x00007fee11ba1257 n/a (libglib-2.0.so.0 + 0xc0257)
#21 0x00007fee11b3da55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
#22 0x00007fee11d0fcb6 g_application_run (libgio-2.0.so.0 + 0xdecb6)
#23 0x00005646ffec141d n/a (pamac-manager + 0xc41d)
#24 0x00007fee1175de08 n/a (libc.so.6 + 0x25e08)
#25 0x00007fee1175decc __libc_start_main (libc.so.6 + 0x25ecc)
#26 0x00005646ffec1545 n/a (pamac-manager + 0xc545)
Stack trace of thread 8097:
#0 0x00007fee11843bb0 ppoll (libc.so.6 + 0x10bbb0)
#1 0x00007fee11ba1327 n/a (libglib-2.0.so.0 + 0xc0327)
#2 0x00007fee11b3f287 g_main_loop_run (libglib-2.0.so.0 + 0x5e287)
#3 0x00007fee11d44bc4 n/a (libgio-2.0.so.0 + 0x113bc4)
#4 0x00007fee11b73be6 n/a (libglib-2.0.so.0 + 0x92be6)
#5 0x00007fee117cc39d n/a (libc.so.6 + 0x9439d)
#6 0x00007fee1185149c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 8095:
#0 0x00007fee1184f1fd syscall (libc.so.6 + 0x1171fd)
#1 0x00007fee11b6fbe0 g_cond_wait (libglib-2.0.so.0 + 0x8ebe0)
#2 0x00007fee11b0698c n/a (libglib-2.0.so.0 + 0x2598c)
#3 0x00007fee11b76237 n/a (libglib-2.0.so.0 + 0x95237)
Stack trace of thread 8099:
#2 0x00007fee11b3da55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
#3 0x00007fee0d4b02fe n/a (libdconfsettings.so + 0x62fe)
Stack trace of thread 8096:
#3 0x00007fee11b3dab2 n/a (libglib-2.0.so.0 + 0x5cab2)
Stack trace of thread 8100:
#3 0x00007fee11b069fd g_async_queue_pop (libglib-2.0.so.0 + 0x259fd)
#4 0x00007fee114695fc n/a (libpangoft2-1.0.so.0 + 0xc5fc)
#5 0x00007fee11b73be6 n/a (libglib-2.0.so.0 + 0x92be6)
#6 0x00007fee117cc39d n/a (libc.so.6 + 0x9439d)
#7 0x00007fee1185149c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 8098:
#1 0x00007fee11b708f7 g_cond_wait_until (libglib-2.0.so.0 + 0x8f8f7)
#2 0x00007fee11b06955 n/a (libglib-2.0.so.0 + 0x25955)
#3 0x00007fee11b76cfb n/a (libglib-2.0.so.0 + 0x95cfb)
jaan 01 20:12:05 Zen systemd[1]: systemd-coredump@1-8102-0.service: Deactivated successfully.
jaan 01 20:12:05 Zen systemd[1690]: dbus-:1.2-org.manjaro.pamac.manager@1.service: Main process exited, code=dumped, status=11/SEGV
jaan 01 20:12:05 Zen systemd[1690]: dbus-:1.2-org.manjaro.pamac.manager@1.service: Failed with result 'core-dump'.
jaan 01 20:12:05 Zen systemd[1690]: dbus-:1.2-org.manjaro.pamac.manager@1.service: Consumed 724ms CPU time, 169M memory peak.
jaan 01 20:12:05 Zen systemd[1]: systemd-coredump@1-8102-0.service: Consumed 679ms CPU time, 241.9M memory peak.
jaan 01 20:12:05 Zen drkonqi-coredump-processor[8104]: "/usr/bin/pamac-manager" 8094 "/var/lib/systemd/coredump/core.pamac-manager.1000.03db876c7ba94c7f897b0a3d0b333add.8094.1735755124000000.zst"
jaan 01 20:12:05 Zen systemd[1690]: Started Launch DrKonqi for a systemd-coredump crash (PID 8104/UID 0).
jaan 01 20:12:05 Zen systemd[1]: drkonqi-coredump-processor@1-8102-0.service: Deactivated successfully.
jaan 01 20:12:08 Zen wireplumber[1813]: wp-event-dispatcher: <WpAsyncEventHook:0x55ce0c68f700> failed: failed to activate item: Object activation aborted: proxy destroyed
jaan 01 20:12:12 Zen systemd[1690]: Started dbus-:1.2-org.manjaro.pamac.manager@2.service.
jaan 01 20:12:12 Zen pamac-manager[8142]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
jaan 01 20:12:12 Zen kernel: pamac-manager[8153]: segfault at 90 ip 00007f345649f38c sp 00007f34410c8b78 error 4 in libpamac.so.11.7[7f3456452000+76000] likely on CPU 6 (core 6, socket 0)
jaan 01 20:12:12 Zen kernel: Code: 35 e9 48 03 00 31 ff 48 89 e5 ff 15 5e ef 04 00 31 c0 5d c3 66 2e 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 48 85 ff 74 1f 48 8b 07 <48> 8b 80 90 00 00 00 48 85 c0 74 08 ff e0 66 0f 1f 44 00 00 31 c0
jaan 01 20:12:12 Zen systemd-coredump[8154]: Process 8142 (pamac-manager) of user 1000 terminated abnormally with signal 11/SEGV, processing...
jaan 01 20:12:12 Zen systemd[1]: Started Process Core Dump (PID 8154/UID 0).
jaan 01 20:12:12 Zen systemd[1]: Started Pass systemd-coredump journal entries to relevant user for potential DrKonqi handling.
jaan 01 20:12:13 Zen systemd-coredump[8155]: [🡕] Process 8142 (pamac-manager) of user 1000 dumped core.
Stack trace of thread 8153:
#0 0x00007f345649f38c pamac_app_get_id (libpamac.so.11 + 0x6338c)
#1 0x00007f34521ae524 n/a (libpamac-appstream.so + 0x4524)
#2 0x00007f34564723b2 n/a (libpamac.so.11 + 0x363b2)
#3 0x00007f3456686be6 n/a (libglib-2.0.so.0 + 0x92be6)
#4 0x00007f34562df39d n/a (libc.so.6 + 0x9439d)
#5 0x00007f345636449c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 8142:
#0 0x00007f3456b23c48 n/a (libgtk-3.so.0 + 0x123c48)
#1 0x00007f3456b23c8e n/a (libgtk-3.so.0 + 0x123c8e)
#2 0x00007f3456b1531e n/a (libgtk-3.so.0 + 0x11531e)
#3 0x00007f3456c96ecf n/a (libgtk-3.so.0 + 0x296ecf)
#4 0x00007f3456b32308 n/a (libgtk-3.so.0 + 0x132308)
#5 0x00007f3456b1b05b n/a (libgtk-3.so.0 + 0x11b05b)
#6 0x00007f3456b15c2b n/a (libgtk-3.so.0 + 0x115c2b)
#7 0x00007f3456b15ec8 n/a (libgtk-3.so.0 + 0x115ec8)
#8 0x00007f3456d6a947 n/a (libgtk-3.so.0 + 0x36a947)
#9 0x00007f34565a582a g_closure_invoke (libgobject-2.0.so.0 + 0x1182a)
#10 0x00007f34565d66a2 n/a (libgobject-2.0.so.0 + 0x426a2)
#11 0x00007f34565c6ca9 n/a (libgobject-2.0.so.0 + 0x32ca9)
#12 0x00007f34565c6f32 g_signal_emit_valist (libgobject-2.0.so.0 + 0x32f32)
#13 0x00007f34565c6ff4 g_signal_emit (libgobject-2.0.so.0 + 0x32ff4)
#14 0x00007f3456d49293 gtk_widget_show (libgtk-3.so.0 + 0x349293)
#15 0x00007f3456d6be10 gtk_window_present_with_time (libgtk-3.so.0 + 0x36be10)
#16 0x000056418fe3cf59 n/a (pamac-manager + 0x2bf59)
#17 0x00007f34565c6e1c n/a (libgobject-2.0.so.0 + 0x32e1c)
#18 0x00007f34565c7212 g_signal_emit_by_name (libgobject-2.0.so.0 + 0x33212)
#19 0x00007f3456821104 n/a (libgio-2.0.so.0 + 0xdd104)
#20 0x00007f345684bed2 n/a (libgio-2.0.so.0 + 0x107ed2)
#21 0x00007f3456651559 n/a (libglib-2.0.so.0 + 0x5d559)
#22 0x00007f34566b4257 n/a (libglib-2.0.so.0 + 0xc0257)
#23 0x00007f3456650a55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
#24 0x00007f3456822cb6 g_application_run (libgio-2.0.so.0 + 0xdecb6)
#25 0x000056418fe1d41d n/a (pamac-manager + 0xc41d)
#26 0x00007f3456270e08 n/a (libc.so.6 + 0x25e08)
#27 0x00007f3456270ecc __libc_start_main (libc.so.6 + 0x25ecc)
#28 0x000056418fe1d545 n/a (pamac-manager + 0xc545)
Stack trace of thread 8145:
#0 0x00007f3456356bb0 ppoll (libc.so.6 + 0x10bbb0)
#1 0x00007f34566b4327 n/a (libglib-2.0.so.0 + 0xc0327)
#2 0x00007f3456652287 g_main_loop_run (libglib-2.0.so.0 + 0x5e287)
#3 0x00007f3456857bc4 n/a (libgio-2.0.so.0 + 0x113bc4)
#4 0x00007f3456686be6 n/a (libglib-2.0.so.0 + 0x92be6)
#5 0x00007f34562df39d n/a (libc.so.6 + 0x9439d)
#6 0x00007f345636449c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 8146:
#0 0x00007f34563621fd syscall (libc.so.6 + 0x1171fd)
#1 0x00007f34566838f7 g_cond_wait_until (libglib-2.0.so.0 + 0x8f8f7)
#2 0x00007f3456619955 n/a (libglib-2.0.so.0 + 0x25955)
#3 0x00007f3456689cfb n/a (libglib-2.0.so.0 + 0x95cfb)
Stack trace of thread 8144:
#2 0x00007f3456650a55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
#3 0x00007f3456650ab2 n/a (libglib-2.0.so.0 + 0x5cab2)
Stack trace of thread 8148:
#1 0x00007f3456682be0 g_cond_wait (libglib-2.0.so.0 + 0x8ebe0)
#2 0x00007f345661998c n/a (libglib-2.0.so.0 + 0x2598c)
#3 0x00007f34566199fd g_async_queue_pop (libglib-2.0.so.0 + 0x259fd)
#4 0x00007f3455f6c5fc n/a (libpangoft2-1.0.so.0 + 0xc5fc)
#5 0x00007f3456686be6 n/a (libglib-2.0.so.0 + 0x92be6)
#6 0x00007f34562df39d n/a (libc.so.6 + 0x9439d)
#7 0x00007f345636449c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 8143:
#3 0x00007f3456689237 n/a (libglib-2.0.so.0 + 0x95237)
Stack trace of thread 8147:
#3 0x00007f345209c2fe n/a (libdconfsettings.so + 0x62fe)
jaan 01 20:12:13 Zen systemd[1]: systemd-coredump@2-8154-0.service: Deactivated successfully.
jaan 01 20:12:13 Zen systemd[1690]: dbus-:1.2-org.manjaro.pamac.manager@2.service: Main process exited, code=dumped, status=11/SEGV
jaan 01 20:12:13 Zen systemd[1690]: dbus-:1.2-org.manjaro.pamac.manager@2.service: Failed with result 'core-dump'.
jaan 01 20:12:13 Zen systemd[1690]: dbus-:1.2-org.manjaro.pamac.manager@2.service: Consumed 752ms CPU time, 167.1M memory peak.
jaan 01 20:12:13 Zen systemd[1]: systemd-coredump@2-8154-0.service: Consumed 687ms CPU time, 241.9M memory peak.
jaan 01 20:12:13 Zen drkonqi-coredump-processor[8156]: "/usr/bin/pamac-manager" 8142 "/var/lib/systemd/coredump/core.pamac-manager.1000.03db876c7ba94c7f897b0a3d0b333add.8142.1735755132000000.zst"
jaan 01 20:12:13 Zen systemd[1690]: Started Launch DrKonqi for a systemd-coredump crash (PID 8156/UID 0).
jaan 01 20:12:14 Zen systemd[1]: drkonqi-coredump-processor@2-8154-0.service: Deactivated successfully.
jaan 01 20:12:19 Zen systemd[1690]: Started dbus-:1.2-org.manjaro.pamac.manager@3.service.
jaan 01 20:12:19 Zen pamac-manager[8194]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
jaan 01 20:12:19 Zen kernel: pamac-manager[8201]: segfault at 90 ip 00007f4055c9f38c sp 00007f40488eeb78 error 4 in libpamac.so.11.7[7f4055c52000+76000] likely on CPU 2 (core 2, socket 0)
jaan 01 20:12:19 Zen kernel: Code: 35 e9 48 03 00 31 ff 48 89 e5 ff 15 5e ef 04 00 31 c0 5d c3 66 2e 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 48 85 ff 74 1f 48 8b 07 <48> 8b 80 90 00 00 00 48 85 c0 74 08 ff e0 66 0f 1f 44 00 00 31 c0
jaan 01 20:12:19 Zen systemd-coredump[8202]: Process 8194 (pamac-manager) of user 1000 terminated abnormally with signal 11/SEGV, processing...
jaan 01 20:12:19 Zen systemd[1]: Started Process Core Dump (PID 8202/UID 0).
jaan 01 20:12:19 Zen systemd[1]: Started Pass systemd-coredump journal entries to relevant user for potential DrKonqi handling.
jaan 01 20:12:20 Zen systemd-coredump[8203]: [🡕] Process 8194 (pamac-manager) of user 1000 dumped core.
Stack trace of thread 8201:
#0 0x00007f4055c9f38c pamac_app_get_id (libpamac.so.11 + 0x6338c)
#1 0x00007f4053756524 n/a (libpamac-appstream.so + 0x4524)
#2 0x00007f4055c723b2 n/a (libpamac.so.11 + 0x363b2)
#3 0x00007f4055e86be6 n/a (libglib-2.0.so.0 + 0x92be6)
#4 0x00007f4055adf39d n/a (libc.so.6 + 0x9439d)
#5 0x00007f4055b6449c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 8194:
#0 0x00007f4056332361 n/a (libgtk-3.so.0 + 0x132361)
#1 0x00007f405631b05b n/a (libgtk-3.so.0 + 0x11b05b)
#2 0x00007f4056315c2b n/a (libgtk-3.so.0 + 0x115c2b)
#3 0x00007f4056315ec8 n/a (libgtk-3.so.0 + 0x115ec8)
#4 0x00007f405656a947 n/a (libgtk-3.so.0 + 0x36a947)
#5 0x00007f4055da582a g_closure_invoke (libgobject-2.0.so.0 + 0x1182a)
#6 0x00007f4055dd66a2 n/a (libgobject-2.0.so.0 + 0x426a2)
#7 0x00007f4055dc6ca9 n/a (libgobject-2.0.so.0 + 0x32ca9)
#8 0x00007f4055dc6f32 g_signal_emit_valist (libgobject-2.0.so.0 + 0x32f32)
#9 0x00007f4055dc6ff4 g_signal_emit (libgobject-2.0.so.0 + 0x32ff4)
#10 0x00007f4056549293 gtk_widget_show (libgtk-3.so.0 + 0x349293)
#11 0x00007f405656be10 gtk_window_present_with_time (libgtk-3.so.0 + 0x36be10)
#12 0x0000557d121f1f59 n/a (pamac-manager + 0x2bf59)
#13 0x00007f4055dc6e1c n/a (libgobject-2.0.so.0 + 0x32e1c)
#14 0x00007f4055dc7212 g_signal_emit_by_name (libgobject-2.0.so.0 + 0x33212)
#15 0x00007f4056021104 n/a (libgio-2.0.so.0 + 0xdd104)
#16 0x00007f405604bed2 n/a (libgio-2.0.so.0 + 0x107ed2)
#17 0x00007f4055e51559 n/a (libglib-2.0.so.0 + 0x5d559)
#18 0x00007f4055eb4257 n/a (libglib-2.0.so.0 + 0xc0257)
#19 0x00007f4055e50a55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
#20 0x00007f4056022cb6 g_application_run (libgio-2.0.so.0 + 0xdecb6)
#21 0x0000557d121d241d n/a (pamac-manager + 0xc41d)
#22 0x00007f4055a70e08 n/a (libc.so.6 + 0x25e08)
#23 0x00007f4055a70ecc __libc_start_main (libc.so.6 + 0x25ecc)
#24 0x0000557d121d2545 n/a (pamac-manager + 0xc545)
Stack trace of thread 8197:
#0 0x00007f4055b56bb0 ppoll (libc.so.6 + 0x10bbb0)
#1 0x00007f4055eb4327 n/a (libglib-2.0.so.0 + 0xc0327)
#2 0x00007f4055e52287 g_main_loop_run (libglib-2.0.so.0 + 0x5e287)
#3 0x00007f4056057bc4 n/a (libgio-2.0.so.0 + 0x113bc4)
#4 0x00007f4055e86be6 n/a (libglib-2.0.so.0 + 0x92be6)
#5 0x00007f4055adf39d n/a (libc.so.6 + 0x9439d)
#6 0x00007f4055b6449c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 8195:
#0 0x00007f4055b621fd syscall (libc.so.6 + 0x1171fd)
#1 0x00007f4055e82be0 g_cond_wait (libglib-2.0.so.0 + 0x8ebe0)
#2 0x00007f4055e1998c n/a (libglib-2.0.so.0 + 0x2598c)
#3 0x00007f4055e89237 n/a (libglib-2.0.so.0 + 0x95237)
Stack trace of thread 8196:
#2 0x00007f4055e50a55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
#3 0x00007f4055e50ab2 n/a (libglib-2.0.so.0 + 0x5cab2)
Stack trace of thread 8200:
#3 0x00007f4055e199fd g_async_queue_pop (libglib-2.0.so.0 + 0x259fd)
#4 0x00007f40569e35fc n/a (libpangoft2-1.0.so.0 + 0xc5fc)
#5 0x00007f4055e86be6 n/a (libglib-2.0.so.0 + 0x92be6)
#6 0x00007f4055adf39d n/a (libc.so.6 + 0x9439d)
#7 0x00007f4055b6449c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 8198:
#1 0x00007f4055e838f7 g_cond_wait_until (libglib-2.0.so.0 + 0x8f8f7)
#2 0x00007f4055e19955 n/a (libglib-2.0.so.0 + 0x25955)
#3 0x00007f4055e89cfb n/a (libglib-2.0.so.0 + 0x95cfb)
Stack trace of thread 8199:
#3 0x00007f40518b52fe n/a (libdconfsettings.so + 0x62fe)
jaan 01 20:12:20 Zen systemd[1]: systemd-coredump@3-8202-0.service: Deactivated successfully.
jaan 01 20:12:20 Zen systemd[1690]: dbus-:1.2-org.manjaro.pamac.manager@3.service: Main process exited, code=dumped, status=11/SEGV
jaan 01 20:12:20 Zen systemd[1690]: dbus-:1.2-org.manjaro.pamac.manager@3.service: Failed with result 'core-dump'.
jaan 01 20:12:20 Zen systemd[1690]: dbus-:1.2-org.manjaro.pamac.manager@3.service: Consumed 737ms CPU time, 169.2M memory peak.
jaan 01 20:12:20 Zen systemd[1]: systemd-coredump@3-8202-0.service: Consumed 680ms CPU time, 241.5M memory peak.
jaan 01 20:12:20 Zen drkonqi-coredump-processor[8204]: "/usr/bin/pamac-manager" 8194 "/var/lib/systemd/coredump/core.pamac-manager.1000.03db876c7ba94c7f897b0a3d0b333add.8194.1735755139000000.zst"
jaan 01 20:12:20 Zen systemd[1690]: Started Launch DrKonqi for a systemd-coredump crash (PID 8204/UID 0).
jaan 01 20:12:20 Zen systemd[1]: drkonqi-coredump-processor@3-8202-0.service: Deactivated successfully.
so 4 failed starts… and after a bit on 5th try it actually starts … and works normally.
jaan 01 20:13:30 Zen wireplumber[1813]: wp-event-dispatcher: <WpAsyncEventHook:0x55ce0c683890> failed: <WpSiStandardLink:0x55ce0c731530> link failed: 1 of 1 PipeWire links failed to activate
jaan 01 20:13:33 Zen systemd[1690]: Started dbus-:1.2-org.manjaro.pamac.manager@4.service.
jaan 01 20:13:34 Zen pamac-manager[8373]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
jaan 01 20:14:45 Zen wireplumber[1813]: wp-event-dispatcher: <WpAsyncEventHook:0x55ce0c683890> failed: <WpSiStandardLink:0x55ce0c8f0a20> link failed: some node was destroyed before the link was created
jaan 01 20:15:08 Zen systemd[1]: Starting Cleanup of Temporary Directories...
jaan 01 20:15:08 Zen systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
jaan 01 20:15:08 Zen systemd[1]: Finished Cleanup of Temporary Directories.
jaan 01 20:15:08 Zen systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dclean.service.mount: Deactivated successfully.
