Pamac is not working, however pacman and paru are working
on last update pamac is not working, however pacman and paru are working
Error: Fallo al preparar una operación: base de datos no válida o dañada
since pacman and paru are working as intended without errors, I can say this is pamac specific.
I have already tried the sudo rm -R /var/lib/pacman/sync trick without success.
UPDATE: tried
[alex@alex-b450aoruselite ~]$ sudo pacman -Syyu
:: Sincronizando las bases de datos de los paquetes...
 core                                                        140.3 KiB  2004 KiB/s 00:00 [####################################################] 100%
 extra                                                         8.0 MiB  23.6 MiB/s 00:00 [####################################################] 100%
 multilib                                                    141.2 KiB  9.85 MiB/s 00:00 [####################################################] 100%
:: Iniciando actualización completa del sistema...
 ...el sistema ya está actualizado.
------------------------------------------------------------------------------------------------------------------------------------------- 12:55:09
[alex@alex-b450aoruselite ~]$ pamac upgrade
Preparando...
Sincronización de bases de datos de paquetes...
Actualizando AUR...
Comprobando ckbcomp dependencias...
Comprobando pamac-tray-icon-plasma dependencias...
Clonando visual-studio-code-bin archivos de compilación...
Generando visual-studio-code-bin de información...
Comprobando visual-studio-code-bin dependencias...
Comprobando v86d dependencias...
Comprobando tlpui dependencias...
Comprobando python-pyrsistent dependencias...
Comprobando zsh-theme-powerlevel10k dependencias...
Editar archivos de construcción : [e]
Aplicar transacción ? [e/s/N]
Operación cancelada.
I do not have problems when using pamac only, without unsupperted 3rd party AUR helpers
on my experience, i always have paru as backup, since pamac has failed in the past for me with aur packages. So I only use it in these cases, as pacman doesn’t handle them.
However, the pamac error is for ALL packages, not just aur
Forum Rules - Misplaced Posts
Try to place your posts in the correct forum section for the topic. Our forums have been carefully categorized so that most topics fit in one logical location. Any post that is deemed by the staff to be in the wrong forum will be moved to the correct location without warning
Please, the post was posted in the testing issues post, and indeed this is a testing upgrade issue. I see no missplacement here. The issue starts happening today on the weekly upgrade.
This is not an aur related issue, but a pamac related issue, as no package at all are possible to upgrade with pamac. Aur and paru are totally out of point here.
this means: corrupted database
this has been discussed here many times
… how to solve it - I’m not talking about why it happens
and, just anecdotal:
pamac has failed to build AUR packages quite often for me
whereas yay had no problems at all
so: I use that and am done with it :man_shrugging:
I have seen previous posts from users reporting that “pamac is broken” that do not mention use of other 3rd party AUR helpers and I suspect that the 3rd party helper might be causing the problem with pamac that I cannot replicate
Update announcements are for reporting issues with repository packages. Issues from updating AUR packages with multiple AUR helpers are less relevant for Manjaro Team
I had a discussion with an Arch user (c00ter) on the old forum and he suggested that users should use only one AUR helper for consistent results. He was using yay but suggested that I use pamac so issues could be reported to Manjaro Team
Precisely, I have an issue upgrading my whole system through pamac. AUR packages are not related.
I use only pamac, paru is just for backup (emergency) situations like this one.
I use pamac only to report issues to Manjaro Team that cannot be influenced by use of 3rd party AUR helpers. But there is usually nothing to report
Why did you think that would work for Pamac?
Try this:
pamac update --force-refresh --no-aur
I’ve noticed that there seems to be a common misconception that Pamac is a front end for pacman;
It is not.
Cheers.
Pamac stopped working for AUR - #16 by philm
sudo rm -Rf /var/tmp/pamac/dbs/sync
mkdir -p /var/tmp/pamac/dbs/sync
pamac update -a --force-refresh
sudo rm - to delete pamac sync folder as root
mkdir - to re-create sync folder with Read and Write permissons for $USER
From the logs you posted the error seems to be with building aur. I bet
Will work. For me it looks like AUR issue, even if pamac related, so it does not belong in the update topic.
More examples of packages that have the same name in the repos and the AUR … so when you use pamac, also including the AUR, to upgrade … you can inadvertently receive the AUR packages.
All pacnew files maintained?
A pamac user could inadvertently upgrade a repository package to an AUR package by not paying attention to information shown about packages before they agree to update
This less likely to happen if user updates repository packages before rebuilding AUR packages
pamac update --no-aur
Previous posts show that yay can also be updated inadvertently to AUR version and can update other packages to AUR version. I suspect that paru is also likely to upgrade to AUR packages inadvertently
But If paru works better for OP they should consider using it instead of pamac
This did the trick! Thanks! So pamac is not pacman frontend? Nice to know. I can use pamac again.
pacman does not support AUR packages
Its also just … not a pacman frontend.
Both pacman and pamac are ALPM ‘frontends’ you could say.
And pamac relies on certain pacman things, like the cache and log.
But they are 2 different package managers.
If you do want a graphical frontend for pacman … that would be octopi.
