I do not see the pamac command’s switch it in the man page and in the Pamac - Manjaro
What is the command for that?
Or if not there, why not adding it and explain also how to do it manually when prompted for like 6 optional dependencies and i want all.
UPDATE: it appears that i can select optionals on command line prompt like this for example: 1,2,5
or i install these like: pamac install main optional1 optional2
Optional dependencies are what the word says: optional. This means that they are not actual dependencies, but that the package being installed has support for the package listed as an optional dependency.
It would be a Very Bad Idea™ to blindly and/or automatically install all optional dependencies for everything you’ve already got installed on your system. For starters, these optional dependencies may actually conflict with one another, as well as that they may pull in their own dependencies, which in turn could also cause conflicts.
Thanks. So if i want any particular optional packages, i will install these along with the main package: pamac install main optional1 optional2
but how i select numerous or all optional packages when i am prompted?
