The title of this issue is pretty self-explanatory. For some more context, I am using the Adwaita Icon theme. It seems to work fine when using the papirus-icon-theme. I already did some research, and according to this commit:
,It seems that some symbolic icons were removed. Upon further research, they were removed because applications had already started to include them in their packages.
No, that wasn’t meant to be facetious. I can’t confirm what you have described in a fully updated Gnome instance. It’s likely the issue is local.
Please provide system information as described (below), and any other information when asked. I’m sure someone will help when they are able.
Update Announcements
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly;
Adwaita icon theme isn’t FDO-compatible, so it will cause problems with all other apps that aren’t based on that LibAdwaita library.
That’s why Adwaita icon theme is filtered and excluded in KDE and Mint desktops. Even if those GNOME folks tried to appease non GNOME users and release what they ironically call “Adwaita icon theme legacy” only to abandon it.
