Hi there, nothing special about my Manjaro install, but pamac has been hanging on ‘Preparing’ any time I install a package, refresh databases, or try an update. It needs a sigstop to kill it. Manual system updates with pacman -Syu work fine and all CLI software installs work fine. Saw some other people reporting this issue in the past, but none of those solutions worked for me. I tried to update the mirrorlist as recommended by one of these topics but that didn’t work.
All I have tried was to update the mirrorlist than do a full system update, and try to refresh databases. The first didn’t work and the second hangs as well.
No have not tried pamac from terminal. Will try that.
I don’t need ghostty or rustdesk any more, so I removed those. Not sure where reiserfsprogs came from. When I try to enter pamac preferences it hangs on a spinner.
You could try pactree to check which packages require python312 and trizen pactree -r trizen pactree -r python312
and delete what you don’t really need, to possibly reinstall them later.
Maybe I need to clarify. I’m talking about the window that comes up when you click on the ‘add/remove software’ icon. I thought that was referred to as pamac as well. Sorry if I caused any confusion.
Also, an interesting development. I stopped and disabled my tigervnc session, in case it had something to do with this. I then rebooted the PC. Now I am getting a dialog message saying ‘authentication failed’. Also, now the main window stays on ‘1 pending operation’ but the application doesn’t hang.
Personally, I do not use the GUI App (it is called pamac-manager when you start it via terminal),
so I’m not experienced or qualified to comment on any issues you might have with that.
Sorry!
The command line tool (which you used as per the last post) had no issues at all is what I was saying.
