I can no longer open the Pamac GUI on Manjaro XFCE.
I have read the following topics, but I have not found a working solution:
Starting the application from the terminal gives:
[dragonfox@FoxBox ~]$ pamac-manager %U
Message: 00:26:13.871: flatpak_plugin.vala:330: refreshing flathub appstream data
flatpak:ERROR:common/flatpak-variant-impl-private.h:1197:var_summary_get_metadata: assertion failed: (start <= end)
Bail out! flatpak:ERROR:common/flatpak-variant-impl-private.h:1197:var_summary_get_metadata: assertion failed: (start <= end)
Aborted (core dumped)
[dragonfox@FoxBox ~]$ sudo pacman -R pamac-flatpak-plugin
error: target not found: pamac-flatpak-plugin
I have attempted to install/reinstall the plugin but for some reason it doesn’t help.
Any advice would be much appreciated.
You may not be fully up to date. pamac-flatpak-plugin was replaced by libpamac-flatpak-plugin.
Make sure your mirrors are up to date and do a full update:
sudo pacman-mirrors -f5 && sudo pacman -Syyu
It states that “there is nothing to do”
Maybe try uninstalling old Flatpak packages:
flatpak uninstall --unused
As well as update manually:
flatpak update
“flatpak update” was the solution for me. Thanks.
system
Closed
6
