I just discovered by accident that the Pamac GTK4 GUI (the process pamac-manager) consumes the very impressive 700-800 MB RAM just by opening itself. Is it something on my side that needs fixing, or is it by everybody and nobody noticed, or is it “normal” as in “yeah it is broken but we don’t care”
Pamac GTK4 consumes about 900MB
whereas Pamac GTK3 consumes about 1,4 GB…
You are kidding me, right?
Just for comparison, Octopi consumes about 160-200 MB
Yepp I can confirm that:
- Pamac GTK3 → ~190MB
- Pamac GTK4 → ~800MB
For me that is not an issue, since I have enough RAM and starts in pretty equal time.
Probably just because of the new GTK4 framework.
It’s not the GTK4 by itself, because i have a lot of other gtk4 apps like Baobab and they run normal (with like 100MB). It might be the manjaro implementation of it.
not really.
when i press pamac-gtk3 on “updates”, the gnome-syste-monitor says 850MB
with Pamac-GTK4 on the other hand 950MB
It’s quite probable…
… that pamac is buggy, yes. Otherwise, from the gtk4 crop, i have gnome-logs, baobab, gnome-firmware. Each of them runs with 70 MB RAM. So, no, gtk4 is not THAT resource intensive, otherwise if every program made with it needed a Gig of RAM, nobody would use it.
Probably compare it by pmap:
pmap -p $(pgrep pamac-manager) | sort -h -k2
GTK3
530989: pamac-manager
000055e496d2c000 4K rw--- /usr/bin/pamac-manager
00007f4abac5e000 4K rw--- /usr/lib/librsvg-2.so.2.48.0
00007f4abb7ff000 4K ----- [ anon ]
00007f4ad81ff000 4K ----- [ anon ]
00007f4ad8e00000 4K r---- /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so
00007f4ad8e01000 4K r-x-- /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so
00007f4ad8e02000 4K r---- /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so
00007f4ad8e03000 4K r---- /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so
00007f4ad8e04000 4K rw--- /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so
00007f4ad8e57000 4K r---- /usr/lib/gtk-3.0/3.0.0/immodules/im-wayland.so
00007f4ad8e58000 4K r---- /usr/lib/gtk-3.0/3.0.0/immodules/im-wayland.so
00007f4ad8e59000 4K rw--- /usr/lib/gtk-3.0/3.0.0/immodules/im-wayland.so
00007f4ad906e000 4K ----- [ anon ]
00007f4ad99fe000 4K ----- [ anon ]
00007f4ada1ff000 4K ----- [ anon ]
00007f4adae98000 4K r---- /usr/lib/libxfce4util.so.7.0.0
00007f4adae99000 4K rw--- /usr/lib/libxfce4util.so.7.0.0
00007f4adae9a000 4K rw--- [ anon ]
00007f4adaeae000 4K r---- /usr/lib/libxfconf-0.so.3.0.0
00007f4adaeaf000 4K rw--- /usr/lib/libxfconf-0.so.3.0.0
00007f4adaee6000 4K r---- /usr/lib/gio/modules/libdconfsettings.so
00007f4adaee7000 4K rw--- /usr/lib/gio/modules/libdconfsettings.so
00007f4adb0a3000 4K r---- /usr/lib/libsodium.so.23.3.0
00007f4adb0a4000 4K rw--- /usr/lib/libsodium.so.23.3.0
00007f4adb0b6000 4K r---- /usr/lib/libavahi-client.so.3.2.9
00007f4adb0b7000 4K rw--- /usr/lib/libavahi-client.so.3.2.9
00007f4adb0c4000 4K r---- /usr/lib/libavahi-common.so.3.5.4
00007f4adb0c5000 4K rw--- /usr/lib/libavahi-common.so.3.5.4
00007f4adb0e1000 4K r---- /usr/lib/libpolkit-gobject-1.so.0.0.0
00007f4adb0e2000 4K rw--- /usr/lib/libpolkit-gobject-1.so.0.0.0
00007f4adb0f2000 4K r---- /usr/lib/libmalcontent-0.so.0.11.1
00007f4adb0f3000 4K rw--- /usr/lib/libmalcontent-0.so.0.11.1
00007f4adb111000 4K r---- /usr/lib/libseccomp.so.2.5.4
00007f4adb112000 4K rw--- /usr/lib/libseccomp.so.2.5.4
00007f4adb20f000 4K rw--- /usr/lib/libostree-1.so.1.0.0
00007f4adb21f000 4K r---- /usr/lib/libdconf.so.1.0.0
00007f4adb220000 4K rw--- /usr/lib/libdconf.so.1.0.0
00007f4adb3db000 4K rw--- /usr/lib/libstemmer.so.0.0.0
00007f4adb3fb000 4K r---- /usr/lib/libyaml-0.so.2.0.9
00007f4adb3fc000 4K rw--- /usr/lib/libyaml-0.so.2.0.9
00007f4adb3fd000 4K ----- [ anon ]
00007f4adbbfe000 4K ----- [ anon ]
00007f4adc3ff000 4K ----- [ anon ]
00007f4adce76000 4K rw--- /usr/lib/libstdc++.so.6.0.32
00007f4adce7d000 4K r---- /usr/lib/libpthread.so.0
00007f4adce7e000 4K r-x-- /usr/lib/libpthread.so.0
00007f4adce7f000 4K r---- /usr/lib/libpthread.so.0
00007f4adce80000 4K r---- /usr/lib/libpthread.so.0
00007f4adce81000 4K rw--- /usr/lib/libpthread.so.0
00007f4adce94000 4K r---- /usr/lib/libpamac-flatpak.so.11.6
00007f4adce95000 4K rw--- /usr/lib/libpamac-flatpak.so.11.6
00007f4adcec6000 4K r---- /usr/lib/libxmlb.so.2.0.0
00007f4adcec7000 4K rw--- /usr/lib/libxmlb.so.2.0.0
00007f4adcf79000 4K r---- /usr/lib/libpamac-appstream.so.11.6
00007f4adcf7a000 4K rw--- /usr/lib/libpamac-appstream.so.11.6
00007f4adcf87000 4K r---- /usr/lib/libpamac-aur.so.11.6
00007f4adcf88000 4K rw--- /usr/lib/libpamac-aur.so.11.6
00007f4adcf8b000 4K r---- /usr/lib/libgthread-2.0.so.0.7600.4
00007f4adcf8c000 4K r-x-- /usr/lib/libgthread-2.0.so.0.7600.4
00007f4adcf8d000 4K r---- /usr/lib/libgthread-2.0.so.0.7600.4
00007f4adcf8e000 4K r---- /usr/lib/libgthread-2.0.so.0.7600.4
00007f4adcf8f000 4K rw--- /usr/lib/libgthread-2.0.so.0.7600.4
00007f4adcf95000 4K r---- /usr/lib/gio/modules/libxfconfgsettingsbackend.so
00007f4adcf96000 4K r---- /usr/lib/gio/modules/libxfconfgsettingsbackend.so
00007f4adcf97000 4K rw--- /usr/lib/gio/modules/libxfconfgsettingsbackend.so
00007f4adcffd000 4K rw--- /usr/lib/gvfs/libgvfscommon.so
00007f4adee8d000 4K r---- /usr/lib/libicudata.so.73.2
00007f4adefe2000 4K rw--- [ anon ]
00007f4adefed000 4K r---- /usr/lib/libcap.so.2.69
00007f4adefee000 4K rw--- /usr/lib/libcap.so.2.69
00007f4adeffc000 4K r---- /usr/lib/libresolv.so.2
00007f4adeffd000 4K rw--- /usr/lib/libresolv.so.2
00007f4adf00c000 4K r---- /usr/lib/libkrb5support.so.0.1
00007f4adf00d000 4K rw--- /usr/lib/libkrb5support.so.0.1
00007f4adf03b000 4K rw--- /usr/lib/libk5crypto.so.3.1
00007f4adf114000 4K r---- /usr/lib/libbrotlicommon.so.1.0.9
00007f4adf115000 4K r-x-- /usr/lib/libbrotlicommon.so.1.0.9
00007f4adf135000 4K r---- /usr/lib/libbrotlicommon.so.1.0.9
00007f4adf136000 4K rw--- /usr/lib/libbrotlicommon.so.1.0.9
00007f4adf2f0000 4K rw--- /usr/lib/libunistring.so.5.0.0
00007f4adf315000 4K r---- /usr/lib/libgpg-error.so.0.34.0
00007f4adf316000 4K rw--- /usr/lib/libgpg-error.so.0.34.0
00007f4adf3ff000 4K rw--- /usr/lib/libssh2.so.1.0.1
00007f4adf605000 4K rw--- /usr/lib/libicuuc.so.73.2
00007f4adf608000 4K r---- /var/lib/flatpak/exports/share/icons/hicolor/icon-theme.cache
00007f4adf60f000 4K r---- /usr/lib/libkeyutils.so.1.10
00007f4adf610000 4K r---- /usr/lib/libkeyutils.so.1.10
00007f4adf611000 4K rw--- /usr/lib/libkeyutils.so.1.10
00007f4adf614000 4K r-x-- /usr/lib/libcom_err.so.2.1
00007f4adf615000 4K r---- /usr/lib/libcom_err.so.2.1
00007f4adf616000 4K r---- /usr/lib/libcom_err.so.2.1
00007f4adf617000 4K rw--- /usr/lib/libcom_err.so.2.1
00007f4adf62d000 4K r---- /usr/lib/libassuan.so.0.8.6
00007f4adf62e000 4K rw--- /usr/lib/libassuan.so.0.8.6
00007f4adf651000 4K r---- /usr/lib/libidn2.so.0.3.8
00007f4adf652000 4K rw--- /usr/lib/libidn2.so.0.3.8
00007f4adf673000 4K r---- /usr/lib/liblz4.so.1.9.4
00007f4adf674000 4K rw--- /usr/lib/liblz4.so.1.9.4
00007f4adf67b000 4K r---- /usr/lib/libacl.so.1.1.2301
00007f4adf67c000 4K r---- /usr/lib/libacl.so.1.1.2301
00007f4adf67d000 4K rw--- /usr/lib/libacl.so.1.1.2301
00007f4adf764000 4K rw--- /usr/lib/libsystemd.so.0.36.0
00007f4adf765000 4K rw--- [ anon ]
00007f4adf76c000 4K r---- /usr/lib/libXdmcp.so.6.0.0
00007f4adf76d000 4K rw--- /usr/lib/libXdmcp.so.6.0.0
00007f4adf76e000 4K r---- /usr/lib/libXau.so.6.0.0
00007f4adf76f000 4K r-x-- /usr/lib/libXau.so.6.0.0
00007f4adf770000 4K r---- /usr/lib/libXau.so.6.0.0
00007f4adf771000 4K r---- /usr/lib/libXau.so.6.0.0
00007f4adf772000 4K rw--- /usr/lib/libXau.so.6.0.0
00007f4adf784000 4K r---- /usr/lib/libbz2.so.1.0.8
00007f4adf785000 4K rw--- /usr/lib/libbz2.so.1.0.8
00007f4adf78c000 4K r---- /usr/lib/libdatrie.so.1.4.0
00007f4adf78d000 4K r---- /usr/lib/libdatrie.so.1.4.0
00007f4adf78e000 4K rw--- /usr/lib/libdatrie.so.1.4.0
00007f4adf7b9000 4K rw--- /usr/lib/libnghttp2.so.14.24.3
00007f4adf80d000 4K rw--- /usr/lib/libgssapi_krb5.so.2.2
00007f4adf80e000 4K r---- /usr/lib/libbrotlidec.so.1.0.9
00007f4adf81a000 4K r---- /usr/lib/libbrotlidec.so.1.0.9
00007f4adf81b000 4K rw--- /usr/lib/libbrotlidec.so.1.0.9
00007f4adf82e000 4K r---- /usr/lib/libpsl.so.5.3.4
00007f4adf82f000 4K rw--- /usr/lib/libpsl.so.5.3.4
00007f4adf883000 4K r---- /usr/lib/libgpgme.so.11.30.0
00007f4adf9ff000 4K rw--- /usr/lib/libarchive.so.13.7.1
00007f4adff3e000 4K rw--- /usr/lib/libblkid.so.1.1.0
00007f4adff70000 4K r---- /usr/lib/liblzma.so.5.4.4
00007f4adff71000 4K rw--- /usr/lib/liblzma.so.5.4.4
00007f4ae0043000 4K r---- /usr/lib/libzstd.so.1.5.5
00007f4ae0044000 4K rw--- /usr/lib/libzstd.so.1.5.5
00007f4ae02ff000 4K rw--- /usr/lib/libxml2.so.2.11.4
00007f4ae0300000 4K rw--- [ anon ]
00007f4ae032a000 4K r---- /usr/lib/libjson-glib-1.0.so.0.600.6
00007f4ae032b000 4K rw--- /usr/lib/libjson-glib-1.0.so.0.600.6
00007f4ae037c000 4K rw--- /usr/lib/libdbus-1.so.3.32.3
00007f4ae03b6000 4K rw--- /usr/lib/libatspi.so.0.0.1
00007f4ae03e3000 4K rw--- /usr/lib/libexpat.so.1.8.10
00007f4ae0490000 4K rw--- /usr/lib/libpixman-1.so.0.42.2
00007f4ae0491000 4K r---- /usr/lib/libxcb-shm.so.0.0.0
00007f4ae0492000 4K r-x-- /usr/lib/libxcb-shm.so.0.0.0
00007f4ae0493000 4K r---- /usr/lib/libxcb-shm.so.0.0.0
00007f4ae0494000 4K r---- /usr/lib/libxcb-shm.so.0.0.0
00007f4ae0495000 4K rw--- /usr/lib/libxcb-shm.so.0.0.0
00007f4ae04a3000 4K r---- /usr/lib/libxcb-render.so.0.0.0
00007f4ae04a4000 4K rw--- /usr/lib/libxcb-render.so.0.0.0
00007f4ae04ce000 4K r---- /usr/lib/libxcb.so.1.1.0
00007f4ae04cf000 4K rw--- /usr/lib/libxcb.so.1.1.0
00007f4ae04db000 4K r---- /usr/lib/libXrender.so.1.3.0
00007f4ae04dc000 4K rw--- /usr/lib/libXrender.so.1.3.0
00007f4ae0501000 4K rw--- /usr/lib/libgraphite2.so.3.2.1
00007f4ae05cf000 4K rw--- /usr/lib/libfreetype.so.6.20.0
00007f4ae05d9000 4K r---- /usr/lib/libthai.so.0.3.1
00007f4ae05da000 4K rw--- /usr/lib/libthai.so.0.3.1
00007f4ae0672000 4K rw--- /usr/lib/libsoup-3.0.so.0.7.0
00007f4ae06ae000 4K r---- /usr/lib/libalpm.so.13.0.2
00007f4ae06af000 4K rw--- /usr/lib/libalpm.so.13.0.2
00007f4ae06d5000 4K r---- /usr/lib/libgcc_s.so.1
00007f4ae06d6000 4K rw--- /usr/lib/libgcc_s.so.1
00007f4ae0770000 4K r---- /usr/lib/libpcre2-8.so.0.11.2
00007f4ae0771000 4K rw--- /usr/lib/libpcre2-8.so.0.11.2
00007f4ae077a000 4K r---- /usr/lib/libffi.so.8.1.2
00007f4ae077b000 4K r---- /usr/lib/libffi.so.8.1.2
00007f4ae077c000 4K rw--- /usr/lib/libffi.so.8.1.2
00007f4ae07cd000 4K rw--- /usr/lib/libmount.so.1.1.0
00007f4ae07e6000 4K r---- /usr/lib/libz.so.1.2.13
00007f4ae07e7000 4K rw--- /usr/lib/libz.so.1.2.13
00007f4ae092b000 4K r---- /usr/lib/libjpeg.so.8.3.2
00007f4ae092c000 4K rw--- /usr/lib/libjpeg.so.8.3.2
00007f4ae0965000 4K r---- /usr/lib/libpng16.so.16.40.0
00007f4ae0966000 4K rw--- /usr/lib/libpng16.so.16.40.0
00007f4ae0967000 4K r---- /usr/lib/libXinerama.so.1.0.0
00007f4ae0968000 4K r-x-- /usr/lib/libXinerama.so.1.0.0
00007f4ae0969000 4K r---- /usr/lib/libXinerama.so.1.0.0
00007f4ae096a000 4K r---- /usr/lib/libXinerama.so.1.0.0
00007f4ae096b000 4K rw--- /usr/lib/libXinerama.so.1.0.0
00007f4ae0977000 4K r---- /usr/lib/libXrandr.so.2.2.0
00007f4ae0978000 4K rw--- /usr/lib/libXrandr.so.2.2.0
00007f4ae0979000 4K r---- /usr/lib/libXcomposite.so.1.0.0
00007f4ae097a000 4K r-x-- /usr/lib/libXcomposite.so.1.0.0
00007f4ae097b000 4K r---- /usr/lib/libXcomposite.so.1.0.0
00007f4ae097c000 4K r---- /usr/lib/libXcomposite.so.1.0.0
00007f4ae097d000 4K rw--- /usr/lib/libXcomposite.so.1.0.0
00007f4ae0980000 4K r---- /usr/lib/libXdamage.so.1.1.0
00007f4ae0981000 4K r-x-- /usr/lib/libXdamage.so.1.1.0
00007f4ae0982000 4K r---- /usr/lib/libXdamage.so.1.1.0
00007f4ae0983000 4K r---- /usr/lib/libXdamage.so.1.1.0
00007f4ae0984000 4K rw--- /usr/lib/libXdamage.so.1.1.0
00007f4ae098f000 4K r---- /usr/lib/libXcursor.so.1.0.2
00007f4ae0990000 4K rw--- /usr/lib/libXcursor.so.1.0.2
00007f4ae09a4000 4K r---- /usr/lib/libXext.so.6.4.0
00007f4ae09a5000 4K rw--- /usr/lib/libXext.so.6.4.0
00007f4ae09a6000 4K r---- /usr/lib/libwayland-egl.so.1.22.0
00007f4ae09a7000 4K r-x-- /usr/lib/libwayland-egl.so.1.22.0
00007f4ae09a8000 4K r---- /usr/lib/libwayland-egl.so.1.22.0
00007f4ae09a9000 4K r---- /usr/lib/libwayland-egl.so.1.22.0
00007f4ae09aa000 4K rw--- /usr/lib/libwayland-egl.so.1.22.0
00007f4ae09af000 4K r---- /usr/lib/libwayland-cursor.so.0.22.0
00007f4ae09b0000 4K r---- /usr/lib/libwayland-cursor.so.0.22.0
00007f4ae09c6000 4K rw--- /usr/lib/libwayland-client.so.0.22.0
00007f4ae0a0d000 4K rw--- /usr/lib/libxkbcommon.so.0.0.0
00007f4ae0a13000 4K r---- /usr/lib/libXfixes.so.3.1.0
00007f4ae0a14000 4K r---- /usr/lib/libXfixes.so.3.1.0
00007f4ae0a15000 4K rw--- /usr/lib/libXfixes.so.3.1.0
00007f4ae0af0000 4K rw--- /usr/lib/libtracker-sparql-3.0.so.0.503.0
00007f4ae0b06000 4K r---- /usr/lib/libcloudproviders.so.0.3.1
00007f4ae0b07000 4K rw--- /usr/lib/libcloudproviders.so.0.3.1
00007f4ae0c98000 4K r---- /usr/lib/libXi.so.6.1.0
00007f4ae0c99000 4K rw--- /usr/lib/libXi.so.6.1.0
00007f4ae0d85000 4K r---- /usr/lib/libm.so.6
00007f4ae0d86000 4K rw--- /usr/lib/libm.so.6
00007f4ae0edf000 4K rw--- /usr/lib/libatk-1.0.so.0.24812.1
00007f4ae0eea000 4K rw--- /usr/lib/libcairo-gobject.so.2.11708.0
00007f4ae0f09000 4K r---- /usr/lib/libfribidi.so.0.4.0
00007f4ae0f0a000 4K rw--- /usr/lib/libfribidi.so.0.4.0
00007f4ae0f59000 4K rw--- /usr/lib/libfontconfig.so.1.13.0
00007f4ae108b000 4K rw--- [ anon ]
00007f4ae1195000 4K r---- /usr/lib/libharfbuzz.so.0.60811.0
00007f4ae1196000 4K rw--- /usr/lib/libharfbuzz.so.0.60811.0
00007f4ae11ff000 4K rw--- /usr/lib/libpango-1.0.so.0.5000.14
00007f4ae144d000 4K r--s- /run/user/1000/dconf/user
00007f4ae146a000 4K r---- /usr/lib/libpangoft2-1.0.so.0.5000.14
00007f4ae146b000 4K rw--- /usr/lib/libpangoft2-1.0.so.0.5000.14
00007f4ae147a000 4K r---- /usr/lib/libpangocairo-1.0.so.0.5000.14
00007f4ae147b000 4K rw--- /usr/lib/libpangocairo-1.0.so.0.5000.14
00007f4ae1480000 4K r---- /usr/lib/libgmodule-2.0.so.0.7600.4
00007f4ae1481000 4K r---- /usr/lib/libgmodule-2.0.so.0.7600.4
00007f4ae1482000 4K rw--- /usr/lib/libgmodule-2.0.so.0.7600.4
00007f4ae1536000 4K rw--- /usr/lib/libpamac.so.11.6
00007f4ae15e5000 4K rw--- /usr/lib/libhandy-1.so.0
00007f4ae172e000 4K r---- /usr/lib/libglib-2.0.so.0.7600.4
00007f4ae172f000 4K rw--- /usr/lib/libglib-2.0.so.0.7600.4
00007f4ae1730000 4K rw--- [ anon ]
00007f4ae1904000 4K rw--- /usr/lib/libgio-2.0.so.0.7600.4
00007f4ae21d6000 4K r---- /usr/lib/locale/C.UTF-8/LC_COLLATE
00007f4ae223c000 4K rw--- /usr/lib/libgobject-2.0.so.0.7600.4
00007f4ae2282000 4K rw--- /usr/lib/libgdk_pixbuf-2.0.so.0.4200.10
00007f4ae22a6000 4K rw--- /usr/lib/libpamac-gtk.so
00007f4ae22a9000 4K r--s- /var/lib/flatpak/exports/share/mime/mime.cache
00007f4ae22aa000 4K r---- /usr/lib/libavahi-glib.so.1.0.2
00007f4ae22ab000 4K r-x-- /usr/lib/libavahi-glib.so.1.0.2
00007f4ae22ac000 4K r---- /usr/lib/libavahi-glib.so.1.0.2
00007f4ae22ad000 4K r---- /usr/lib/libavahi-glib.so.1.0.2
00007f4ae22ae000 4K rw--- /usr/lib/libavahi-glib.so.1.0.2
00007f4ae22e0000 4K rw--- /usr/lib/gio/modules/libgvfsdbus.so
00007f4ae22e1000 4K r---- /usr/lib/ld-linux-x86-64.so.2
ffffffffff600000 4K --x-- [ anon ]
000055e496d2a000 8K r---- /usr/bin/pamac-manager
00007f4ad8e53000 8K r---- /usr/lib/gtk-3.0/3.0.0/immodules/im-wayland.so
00007f4ad8e55000 8K r-x-- /usr/lib/gtk-3.0/3.0.0/immodules/im-wayland.so
00007f4adb0f4000 8K r---- /usr/lib/libseccomp.so.2.5.4
00007f4adb30f000 8K rw--- /usr/lib/libflatpak.so.0.11504.0
00007f4adb3dc000 8K r---- /usr/lib/libyaml-0.so.2.0.9
00007f4adcf6f000 8K rw--- /usr/lib/libappstream.so.0.16.2
00007f4adcf77000 8K r---- /usr/lib/libpamac-appstream.so.11.6
00007f4adcf85000 8K r---- /usr/lib/libpamac-aur.so.11.6
00007f4adcf89000 8K r---- /home/user/.config/dconf/user
00007f4adcf93000 8K r-x-- /usr/lib/gio/modules/libxfconfgsettingsbackend.so
00007f4adcffe000 8K rw--- [ anon ]
00007f4adefeb000 8K r---- /usr/lib/libcap.so.2.69
00007f4adeffa000 8K r---- /usr/lib/libresolv.so.2
00007f4adeffe000 8K rw--- [ anon ]
00007f4adf00a000 8K r---- /usr/lib/libkrb5support.so.0.1
00007f4adf039000 8K r---- /usr/lib/libk5crypto.so.3.1
00007f4adf112000 8K rw--- /usr/lib/libkrb5.so.3.3
00007f4adf3fd000 8K r---- /usr/lib/libssh2.so.1.0.1
00007f4adf606000 8K rw--- [ anon ]
00007f4adf609000 8K rw--- [ anon ]
00007f4adf60b000 8K r---- /usr/lib/libkeyutils.so.1.10
00007f4adf60d000 8K r-x-- /usr/lib/libkeyutils.so.1.10
00007f4adf612000 8K r---- /usr/lib/libcom_err.so.2.1
00007f4adf618000 8K rw--- [ anon ]
00007f4adf62f000 8K rw--- [ anon ]
00007f4adf631000 8K r---- /usr/lib/libidn2.so.0.3.8
00007f4adf671000 8K r---- /usr/lib/liblz4.so.1.9.4
00007f4adf675000 8K r---- /usr/lib/libacl.so.1.1.2301
00007f4adf766000 8K r---- /usr/lib/libXdmcp.so.6.0.0
00007f4adf768000 8K r-x-- /usr/lib/libXdmcp.so.6.0.0
00007f4adf76a000 8K r---- /usr/lib/libXdmcp.so.6.0.0
00007f4adf773000 8K r---- /usr/lib/libbz2.so.1.0.8
00007f4adf782000 8K r---- /usr/lib/libbz2.so.1.0.8
00007f4adf786000 8K r---- /usr/lib/libdatrie.so.1.4.0
00007f4adf80b000 8K r---- /usr/lib/libgssapi_krb5.so.2.2
00007f4adf81c000 8K r---- /usr/lib/libpsl.so.5.3.4
00007f4adf81e000 8K r-x-- /usr/lib/libpsl.so.5.3.4
00007f4adf884000 8K rw--- /usr/lib/libgpgme.so.11.30.0
00007f4ae0045000 8K rw--- [ anon ]
00007f4ae037a000 8K r---- /usr/lib/libdbus-1.so.3.32.3
00007f4ae03b7000 8K rw--- [ anon ]
00007f4ae03e1000 8K r---- /usr/lib/libexpat.so.1.8.10
00007f4ae04a1000 8K r---- /usr/lib/libxcb-render.so.0.0.0
00007f4ae04d0000 8K r---- /usr/lib/libXrender.so.1.3.0
00007f4ae04d9000 8K r---- /usr/lib/libXrender.so.1.3.0
00007f4ae04dd000 8K rw--- [ anon ]
00007f4ae04ff000 8K r---- /usr/lib/libgraphite2.so.3.2.1
00007f4ae05d0000 8K r---- /usr/lib/libthai.so.0.3.1
00007f4ae06b0000 8K rw--- [ anon ]
00007f4ae0772000 8K r---- /usr/lib/libffi.so.8.1.2
00007f4ae07cb000 8K r---- /usr/lib/libmount.so.1.1.0
00007f4ae087f000 8K rw--- [ anon ]
00007f4ae096c000 8K r---- /usr/lib/libXrandr.so.2.2.0
00007f4ae0975000 8K r---- /usr/lib/libXrandr.so.2.2.0
00007f4ae097e000 8K rw--- [ anon ]
00007f4ae098d000 8K r---- /usr/lib/libXcursor.so.1.0.2
00007f4ae09ab000 8K r---- /usr/lib/libwayland-cursor.so.0.22.0
00007f4ae09ad000 8K r-x-- /usr/lib/libwayland-cursor.so.0.22.0
00007f4ae09c4000 8K r---- /usr/lib/libwayland-client.so.0.22.0
00007f4ae0a0b000 8K r---- /usr/lib/libxkbcommon.so.0.0.0
00007f4ae0a0e000 8K r---- /usr/lib/libXfixes.so.3.1.0
00007f4ae0b3f000 8K r---- /usr/lib/libatk-bridge-2.0.so.0.0.0
00007f4ae0b41000 8K rw--- /usr/lib/libatk-bridge-2.0.so.0.0.0
00007f4ae0ee4000 8K r-x-- /usr/lib/libcairo-gobject.so.2.11708.0
00007f4ae0ee6000 8K r---- /usr/lib/libcairo-gobject.so.2.11708.0
00007f4ae0ee8000 8K r---- /usr/lib/libcairo-gobject.so.2.11708.0
00007f4ae0eeb000 8K r---- /usr/lib/libfribidi.so.0.4.0
00007f4ae0f57000 8K r---- /usr/lib/libfontconfig.so.1.13.0
00007f4ae1089000 8K rw--- /usr/lib/libcairo.so.2.11708.0
00007f4ae143e000 8K rw--- /usr/lib/libc.so.6
00007f4ae1478000 8K r---- /usr/lib/libpangocairo-1.0.so.0.5000.14
00007f4ae147c000 8K r---- /usr/lib/libgmodule-2.0.so.0.7600.4
00007f4ae147e000 8K r-x-- /usr/lib/libgmodule-2.0.so.0.7600.4
00007f4ae1905000 8K rw--- [ anon ]
00007f4ae19fe000 8K rw--- /usr/lib/libgdk-3.so.0.2406.32
00007f4ae21cf000 8K rw--- /usr/lib/libgtk-3.so.0.2406.32
00007f4ae2280000 8K r---- /usr/lib/libgdk_pixbuf-2.0.so.0.4200.10
00007f4ae22a4000 8K r---- /usr/lib/libpamac-gtk.so
00007f4ae22a7000 8K rw--- [ anon ]
00007f4ae22de000 8K r---- /usr/lib/gio/modules/libgvfsdbus.so
00007f4ae2312000 8K r---- /usr/lib/ld-linux-x86-64.so.2
00007f4ae2314000 8K rw--- /usr/lib/ld-linux-x86-64.so.2
00007ffc22570000 8K r-x-- [ anon ]
00007f4ad8e1a000 12K r---- /home/user/.local/share/icons/hicolor/icon-theme.cache
00007f4adade4000 12K r--s- /var/cache/fontconfig/699564f050ff7e0f9dae359f33bc56a5-le64.cache-8
00007f4adaded000 12K r--s- /var/cache/fontconfig/6ba42ae0000f58711b5caaf10d690066-le64.cache-8
00007f4adaed6000 12K r---- /usr/share/locale/de/LC_MESSAGES/at-spi2-core.mo
00007f4adaee3000 12K r---- /usr/lib/gio/modules/libdconfsettings.so
00007f4adb0b8000 12K r---- /usr/lib/libavahi-common.so.3.5.4
00007f4adb0c1000 12K r---- /usr/lib/libavahi-common.so.3.5.4
00007f4adb20c000 12K r---- /usr/lib/libostree-1.so.1.0.0
00007f4adcf71000 12K r---- /usr/lib/libpamac-appstream.so.11.6
00007f4adcf74000 12K r-x-- /usr/lib/libpamac-appstream.so.11.6
00007f4adcf90000 12K r---- /usr/lib/gio/modules/libxfconfgsettingsbackend.so
00007f4adefe3000 12K r---- /usr/lib/libcap.so.2.69
00007f4adefef000 12K r---- /usr/lib/libresolv.so.2
00007f4adf000000 12K r---- /usr/lib/libkrb5support.so.0.1
00007f4adf653000 12K r---- /usr/lib/liblz4.so.1.9.4
00007f4adf7b6000 12K r---- /usr/lib/libnghttp2.so.14.24.3
00007f4adf817000 12K r---- /usr/lib/libbrotlidec.so.1.0.9
00007f4adf933000 12K rw--- /usr/lib/libcurl.so.4.8.0
00007f4adfef7000 12K rw--- /usr/lib/libcrypto.so.3
00007f4adfefa000 12K rw--- [ anon ]
00007f4ae04df000 12K r---- /usr/lib/libgraphite2.so.3.2.1
00007f4ae05d6000 12K r---- /usr/lib/libthai.so.0.3.1
00007f4ae06d7000 12K r---- /usr/lib/libpcre2-8.so.0.11.2
00007f4ae07ce000 12K r---- /usr/lib/libz.so.1.2.13
00007f4ae087c000 12K rw--- /usr/lib/libtiff.so.6.0.1
00007f4ae0985000 12K r---- /usr/lib/libXcursor.so.1.0.2
00007f4ae09c1000 12K r---- /usr/lib/libwayland-client.so.0.22.0
00007f4ae0a10000 12K r-x-- /usr/lib/libXfixes.so.3.1.0
00007f4ae0c7f000 12K r---- /usr/lib/libX11.so.6.4.0
00007f4ae0c86000 12K r---- /usr/lib/libXi.so.6.1.0
00007f4ae0c95000 12K r---- /usr/lib/libXi.so.6.1.0
00007f4ae0edc000 12K r---- /usr/lib/libatk-1.0.so.0.24812.1
00007f4ae15e2000 12K r---- /usr/lib/libhandy-1.so.0
00007f4ae2239000 12K r---- /usr/lib/libgobject-2.0.so.0.7600.4
00007f4adae88000 16K r---- /usr/lib/libxfce4util.so.7.0.0
00007f4adae94000 16K r---- /usr/lib/libxfce4util.so.7.0.0
00007f4adaed9000 16K r---- /usr/lib/gio/modules/libdconfsettings.so
00007f4adb0a5000 16K r---- /usr/lib/libavahi-client.so.3.2.9
00007f4adb0b2000 16K r---- /usr/lib/libavahi-client.so.3.2.9
00007f4adb0e3000 16K r---- /usr/lib/libmalcontent-0.so.0.11.1
00007f4adb0ee000 16K r---- /usr/lib/libmalcontent-0.so.0.11.1
00007f4adb210000 16K r---- /usr/lib/libdconf.so.1.0.0
00007f4adb21b000 16K r---- /usr/lib/libdconf.so.1.0.0
00007f4adb3f7000 16K r---- /usr/lib/libyaml-0.so.2.0.9
00007f4adce77000 16K rw--- [ anon ]
00007f4adce90000 16K r---- /usr/lib/libpamac-flatpak.so.11.6
00007f4adcf7b000 16K r---- /usr/lib/libpamac-aur.so.11.6
00007f4adefde000 16K rw--- /usr/lib/libgcrypt.so.20.4.2
00007f4adf00e000 16K r---- /usr/lib/libk5crypto.so.3.1
00007f4adf2ec000 16K r---- /usr/lib/libunistring.so.5.0.0
00007f4adf3b3000 16K rw--- /usr/lib/libssl.so.3
00007f4adf61a000 16K r---- /usr/lib/libassuan.so.0.8.6
00007f4adf629000 16K r---- /usr/lib/libassuan.so.0.8.6
00007f4adf633000 16K r-x-- /usr/lib/libidn2.so.0.3.8
00007f4adf677000 16K r-x-- /usr/lib/libacl.so.1.1.2301
00007f4adf788000 16K r-x-- /usr/lib/libdatrie.so.1.4.0
00007f4adf92f000 16K r---- /usr/lib/libcurl.so.4.8.0
00007f4adf9fb000 16K r---- /usr/lib/libarchive.so.13.7.1
00007f4adff3f000 16K r---- /usr/lib/liblzma.so.5.4.4
00007f4ae0193000 16K r---- /usr/lib/libsqlite3.so.0.8.6
00007f4ae0197000 16K rw--- /usr/lib/libsqlite3.so.0.8.6
00007f4ae03b2000 16K r---- /usr/lib/libatspi.so.0.0.1
00007f4ae03b9000 16K r---- /usr/lib/libexpat.so.1.8.10
00007f4ae05d2000 16K r-x-- /usr/lib/libthai.so.0.3.1
00007f4ae066e000 16K r---- /usr/lib/libsoup-3.0.so.0.7.0
00007f4ae06b2000 16K r---- /usr/lib/libgcc_s.so.1
00007f4ae06d1000 16K r---- /usr/lib/libgcc_s.so.1
00007f4ae0991000 16K r---- /usr/lib/libXext.so.6.4.0
00007f4ae09a0000 16K r---- /usr/lib/libXext.so.6.4.0
00007f4ae09b1000 16K rw--- /usr/lib/libwayland-cursor.so.0.22.0
00007f4ae0c82000 16K rw--- /usr/lib/libX11.so.6.4.0
00007f4ae0ee0000 16K r---- /usr/lib/libcairo-gobject.so.2.11708.0
00007f4ae1085000 16K r---- /usr/lib/libcairo.so.2.11708.0
00007f4ae11fb000 16K r---- /usr/lib/libpango-1.0.so.0.5000.14
00007f4ae1466000 16K r---- /usr/lib/libpangoft2-1.0.so.0.5000.14
00007f4ae21d7000 16K rw--- [ anon ]
00007ffc2256c000 16K r---- [ anon ]
00007f4ad8df5000 20K r---- /usr/share/locale/de/LC_MESSAGES/libalpm.mo
00007f4ad8e1d000 20K r---- /usr/share/icons/hicolor/icon-theme.cache
00007f4adae9b000 20K r---- /usr/lib/libxfconf-0.so.3.0.0
00007f4adaea9000 20K r---- /usr/lib/libxfconf-0.so.3.0.0
00007f4adb30a000 20K r---- /usr/lib/libflatpak.so.0.11504.0
00007f4adce82000 20K r---- /usr/lib/libpamac-flatpak.so.11.6
00007f4adefd9000 20K r---- /usr/lib/libgcrypt.so.20.4.2
00007f4adefe6000 20K r-x-- /usr/lib/libcap.so.2.69
00007f4adf2f1000 20K r---- /usr/lib/libgpg-error.so.0.34.0
00007f4ae049c000 20K r-x-- /usr/lib/libxcb-render.so.0.0.0
00007f4ae04fa000 20K r---- /usr/lib/libgraphite2.so.3.2.1
00007f4ae0877000 20K r---- /usr/lib/libtiff.so.6.0.1
00007f4ae0988000 20K r-x-- /usr/lib/libXcursor.so.1.0.2
00007f4ae09c7000 20K r---- /usr/lib/libxkbcommon.so.0.0.0
00007f4ae0b01000 20K r---- /usr/lib/libcloudproviders.so.0.3.1
00007f4ae0eed000 20K r-x-- /usr/lib/libfribidi.so.0.4.0
00007f4ae146c000 20K r---- /usr/lib/libpangocairo-1.0.so.0.5000.14
00007f4ae1531000 20K r---- /usr/lib/libpamac.so.11.6
00007f4ae21d1000 20K rw--- [ anon ]
00007f4ad8dfa000 24K r---- /usr/share/locale/de/LC_MESSAGES/gdk-pixbuf.mo
00007f4adade7000 24K r--s- /var/cache/fontconfig/b67b32625a2bb51b023d3814a918f351-le64.cache-8
00007f4adaedd000 24K r-x-- /usr/lib/gio/modules/libdconfsettings.so
00007f4adb0bb000 24K r-x-- /usr/lib/libavahi-common.so.3.5.4
00007f4adcf7f000 24K r-x-- /usr/lib/libpamac-aur.so.11.6
00007f4adcff7000 24K r---- /usr/lib/gvfs/libgvfscommon.so
00007f4adf78f000 24K r---- /usr/lib/libnghttp2.so.14.24.3
00007f4adfefd000 24K rw--- [ anon ]
00007f4adff38000 24K r---- /usr/lib/libblkid.so.1.1.0
00007f4ae0496000 24K r---- /usr/lib/libxcb-render.so.0.0.0
00007f4ae0774000 24K r-x-- /usr/lib/libffi.so.8.1.2
00007f4ae0881000 24K r---- /usr/lib/libjpeg.so.8.3.2
00007f4ae092d000 24K r---- /usr/lib/libpng16.so.16.40.0
00007f4ae09b5000 24K r---- /usr/lib/libwayland-client.so.0.22.0
00007f4ae09bb000 24K r-x-- /usr/lib/libwayland-client.so.0.22.0
00007f4ae144e000 24K rw--- [ anon ]
00007f4adaecf000 28K r---- /usr/share/locale/de/LC_MESSAGES/libhandy.mo
00007f4adb0c6000 28K r---- /usr/lib/libpolkit-gobject-1.so.0.0.0
00007f4adb0e7000 28K r-x-- /usr/lib/libmalcontent-0.so.0.11.1
00007f4adb214000 28K r-x-- /usr/lib/libdconf.so.1.0.0
00007f4adf003000 28K r-x-- /usr/lib/libkrb5support.so.0.1
00007f4ae04d2000 28K r-x-- /usr/lib/libXrender.so.1.3.0
00007f4ae07df000 28K r---- /usr/lib/libz.so.1.2.13
00007f4ae096e000 28K r-x-- /usr/lib/libXrandr.so.2.2.0
00007f4ae0af1000 28K r---- /usr/lib/libcloudproviders.so.0.3.1
00007f4ae0eb1000 28K rw--- /usr/lib/libepoxy.so.0.0.0
00007f4ae1454000 28K r---- /usr/lib/libpangoft2-1.0.so.0.5000.14
00007f4ae1471000 28K r-x-- /usr/lib/libpangocairo-1.0.so.0.5000.14
00007f4ad8d9d000 32K r---- /usr/share/locale/de/LC_MESSAGES/pamac.mo
00007f4adae8c000 32K r-x-- /usr/lib/libxfce4util.so.7.0.0
00007f4adaec7000 32K r---- /usr/share/locale/de_DE/LC_MESSAGES/pamac.mo
00007f4adb0d9000 32K r---- /usr/lib/libpolkit-gobject-1.so.0.0.0
00007f4adce96000 32K r---- /usr/lib/libxmlb.so.2.0.0
00007f4adcf67000 32K r---- /usr/lib/libappstream.so.0.16.2
00007f4adeff2000 32K r-x-- /usr/lib/libresolv.so.2
00007f4adf3b7000 32K r---- /usr/lib/libssh2.so.1.0.1
00007f4adf80f000 32K r-x-- /usr/lib/libbrotlidec.so.1.0.9
00007f4adf830000 32K r---- /usr/lib/libgpgme.so.11.30.0
00007f4adff03000 32K r---- /usr/lib/libblkid.so.1.1.0
00007f4ae03d9000 32K r---- /usr/lib/libexpat.so.1.8.10
00007f4ae0488000 32K r---- /usr/lib/libpixman-1.so.0.42.2
00007f4ae05c7000 32K r---- /usr/lib/libfreetype.so.6.20.0
00007f4ae0673000 32K r---- /usr/lib/libalpm.so.13.0.2
00007f4ae07e8000 32K r---- /usr/lib/libtiff.so.6.0.1
00007f4ae0ea9000 32K r---- /usr/lib/libepoxy.so.0.0.0
00007f4ae0f0b000 32K r---- /usr/lib/libfontconfig.so.1.13.0
00007f4ae18fc000 32K r---- /usr/lib/libgio-2.0.so.0.7600.4
00007f4ae2283000 32K r---- /usr/lib/libpamac-gtk.so
00007f4ae229c000 32K r---- /usr/lib/libpamac-gtk.so
00007f4ad8da5000 36K r---- /usr/share/locale/de/LC_MESSAGES/libgpg-error.mo
00007f4adaea0000 36K r-x-- /usr/lib/libxfconf-0.so.3.0.0
00007f4adaebe000 36K r--s- /var/cache/fontconfig/f349e9996a5320f6dd491cedd2b1f964-le64.cache-8
00007f4adb0a9000 36K r-x-- /usr/lib/libavahi-client.so.3.2.9
00007f4adce87000 36K r-x-- /usr/lib/libpamac-flatpak.so.11.6
00007f4ae0301000 36K r---- /usr/lib/libjson-glib-1.0.so.0.600.6
00007f4ae04c5000 36K r---- /usr/lib/libxcb.so.1.1.0
00007f4ae0af8000 36K r-x-- /usr/lib/libcloudproviders.so.0.3.1
00007f4ae19f5000 36K r---- /usr/lib/libgdk-3.so.0.2406.32
00007f4ae223d000 36K r---- /usr/lib/libgdk_pixbuf-2.0.so.0.4200.10
00007f4adf30b000 40K r---- /usr/lib/libgpg-error.so.0.34.0
00007f4adf3a9000 40K r---- /usr/lib/libssl.so.3
00007f4adff2e000 40K r---- /usr/lib/libblkid.so.1.1.0
00007f4ae0320000 40K r---- /usr/lib/libjson-glib-1.0.so.0.600.6
00007f4ae077d000 40K r---- /usr/lib/libmount.so.1.1.0
00007f4ae095b000 40K r---- /usr/lib/libpng16.so.16.40.0
00007f4ae22af000 40K r---- /usr/lib/gio/modules/libgvfsdbus.so
00007f4ae22d4000 40K r---- /usr/lib/gio/modules/libgvfsdbus.so
00007f4ae2308000 40K r---- /usr/lib/ld-linux-x86-64.so.2
00007f4adcebb000 44K r---- /usr/lib/libxmlb.so.2.0.0
00007f4adf61e000 44K r-x-- /usr/lib/libassuan.so.0.8.6
00007f4adf759000 44K r---- /usr/lib/libsystemd.so.0.36.0
00007f4ae02f4000 44K r---- /usr/lib/libxml2.so.2.11.4
00007f4ae03e4000 44K r---- /usr/lib/libpixman-1.so.0.42.2
00007f4ae0995000 44K r-x-- /usr/lib/libXext.so.6.4.0
00007f4ae0eb8000 44K r---- /usr/lib/libatk-1.0.so.0.24812.1
00007f4ae0ed1000 44K r---- /usr/lib/libatk-1.0.so.0.24812.1
00007f4ae145b000 44K r-x-- /usr/lib/libpangoft2-1.0.so.0.5000.14
000055e496cde000 48K r---- /usr/bin/pamac-manager
00007f4adb0cd000 48K r-x-- /usr/lib/libpolkit-gobject-1.so.0.0.0
00007f4adcfeb000 48K r---- /usr/lib/gvfs/libgvfscommon.so
00007f4adee8f000 48K rw--- [ anon ]
00007f4adf02d000 48K r---- /usr/lib/libk5crypto.so.3.1
00007f4adf7aa000 48K r---- /usr/lib/libnghttp2.so.14.24.3
00007f4adf7ba000 48K r---- /usr/lib/libgssapi_krb5.so.2.2
00007f4adf7ff000 48K r---- /usr/lib/libgssapi_krb5.so.2.2
00007f4adff64000 48K r---- /usr/lib/liblzma.so.5.4.4
00007f4adff72000 48K r---- /usr/lib/libzstd.so.1.5.5
00007f4ae04a5000 48K r---- /usr/lib/libxcb.so.1.1.0
00007f4ae06a2000 48K r---- /usr/lib/libalpm.so.13.0.2
00007f4ae0b08000 48K r---- /usr/lib/libatk-bridge-2.0.so.0.0.0
00007f4ae0c89000 48K r-x-- /usr/lib/libXi.so.6.1.0
00007f4ae108c000 48K r---- /usr/lib/libharfbuzz.so.0.60811.0
00007f4adaeb1000 52K r--s- /var/cache/fontconfig/210c0516121708a580e22e6b1f9a103a-le64.cache-8
00007f4adb04b000 52K r---- /usr/lib/libsodium.so.23.3.0
00007f4adb104000 52K r---- /usr/lib/libseccomp.so.2.5.4
00007f4adce69000 52K r---- /usr/lib/libstdc++.so.6.0.32
00007f4adf775000 52K r-x-- /usr/lib/libbz2.so.1.0.8
00007f4ae03a5000 52K r---- /usr/lib/libatspi.so.0.0.1
00007f4ae1440000 52K rw--- [ anon ]
00007f4adb0f6000 56K r-x-- /usr/lib/libseccomp.so.2.5.4
00007f4adf104000 56K r---- /usr/lib/libkrb5.so.3.3
00007f4adf3ef000 56K r---- /usr/lib/libssh2.so.1.0.1
00007f4adf820000 56K r---- /usr/lib/libpsl.so.5.3.4
00007f4ae032c000 56K r---- /usr/lib/libdbus-1.so.3.32.3
00007f4ae0502000 56K r---- /usr/lib/libfreetype.so.6.20.0
00007f4ae07d1000 56K r-x-- /usr/lib/libz.so.1.2.13
00007f4ae0ae2000 56K r---- /usr/lib/libtracker-sparql-3.0.so.0.503.0
00007f4ae0ec3000 56K r-x-- /usr/lib/libatk-1.0.so.0.24812.1
00007f4ad8eaa000 60K r--s- /var/cache/fontconfig/491f45a0a771fef1c10b9b647a97fb82-le64.cache-8
00007f4adee9b000 60K r---- /usr/lib/libgcrypt.so.20.4.2
00007f4ae07bc000 60K r---- /usr/lib/libmount.so.1.1.0
00007f4ae21db000 60K r---- /usr/lib/libgobject-2.0.so.0.7600.4
00007f4adf886000 64K r---- /usr/lib/libcurl.so.4.8.0
00007f4adf936000 64K r---- /usr/lib/libarchive.so.13.7.1
00007f4ae0c9a000 64K r---- /usr/lib/libm.so.6
00007f4ae21bf000 64K r---- /usr/lib/libgtk-3.so.0.2406.32
00007f4ae0047000 68K r---- /usr/lib/libsqlite3.so.0.8.6
00007f4ae037d000 68K r---- /usr/lib/libatspi.so.0.0.1
00007f4ae226f000 68K r---- /usr/lib/libgdk_pixbuf-2.0.so.0.4200.10
00007f4ae228b000 68K r-x-- /usr/lib/libpamac-gtk.so
00007f4adb091000 72K r---- /usr/lib/libsodium.so.23.3.0
00007f4adf137000 72K r---- /usr/lib/libunistring.so.5.0.0
00007f4ae0368000 72K r---- /usr/lib/libdbus-1.so.3.32.3
00007f4ae0476000 72K r---- /usr/lib/libpixman-1.so.0.42.2
00007f4adb376000 76K r---- /usr/lib/libstemmer.so.0.0.0
00007f4adcfc1000 76K r---- /usr/lib/gvfs/libgvfscommon.so
00007f4adf5f2000 76K r---- /usr/lib/libicuuc.so.73.2
00007f4adf870000 76K r---- /usr/lib/libgpgme.so.11.30.0
00007f4ae0f5a000 76K r---- /usr/lib/libcairo.so.2.11708.0
00007f4ae1197000 76K r---- /usr/lib/libpango-1.0.so.0.5000.14
00007f4ad8eb9000 80K r--s- /var/cache/fontconfig/614d1caaa4d7914789410f6367de37ca-le64.cache-8
00007f4ae002f000 80K r---- /usr/lib/libzstd.so.1.5.5
00007f4ae04b1000 80K r-x-- /usr/lib/libxcb.so.1.1.0
00007f4ae0b2b000 80K r---- /usr/lib/libatk-bridge-2.0.so.0.0.0
00007f4ad8e05000 84K r---- /usr/share/icons/Adwaita/icon-theme.cache
00007f4adf2f6000 84K r-x-- /usr/lib/libgpg-error.so.0.34.0
00007f4adf795000 84K r-x-- /usr/lib/libnghttp2.so.14.24.3
00007f4ae030a000 88K r-x-- /usr/lib/libjson-glib-1.0.so.0.600.6
00007f4adcfd4000 92K r-x-- /usr/lib/gvfs/libgvfscommon.so
00007f4adf67e000 92K r---- /usr/lib/libsystemd.so.0.36.0
00007f4ae038e000 92K r-x-- /usr/lib/libatspi.so.0.0.1
00007f4ae0b14000 92K r-x-- /usr/lib/libatk-bridge-2.0.so.0.0.0
00007f4ae0ef2000 92K r---- /usr/lib/libfribidi.so.0.4.0
00007f4ae0f40000 92K r---- /usr/lib/libfontconfig.so.1.13.0
00007f4adb221000 96K r---- /usr/lib/libflatpak.so.0.11504.0
00007f4ae04e2000 96K r-x-- /usr/lib/libgraphite2.so.3.2.1
000055e496d11000 100K r---- /usr/bin/pamac-manager
00007f4adaee8000 100K r---- /usr/share/glib-2.0/schemas/gschemas.compiled
00007f4adb113000 100K r---- /usr/lib/libostree-1.so.1.0.0
00007f4adb3de000 100K r-x-- /usr/lib/libyaml-0.so.2.0.9
00007f4ae0a16000 100K r---- /usr/lib/libtracker-sparql-3.0.so.0.503.0
00007f4ae1483000 100K r---- /usr/lib/libpamac.so.11.6
00007f4ae1537000 100K r---- /usr/lib/libhandy-1.so.0
00007f4adf637000 104K r---- /usr/lib/libidn2.so.0.3.8
00007f4ae05db000 104K r---- /usr/lib/libsoup-3.0.so.0.7.0
00007f4ae221f000 104K r---- /usr/lib/libgobject-2.0.so.0.7600.4
00007f4adf012000 108K r-x-- /usr/lib/libk5crypto.so.3.1
00007f4adf656000 108K r-x-- /usr/lib/liblz4.so.1.9.4
00007f4ae06b6000 108K r-x-- /usr/lib/libgcc_s.so.1
00007f4ae11e0000 108K r---- /usr/lib/libpango-1.0.so.0.5000.14
00007f4ae22b9000 108K r-x-- /usr/lib/gio/modules/libgvfsdbus.so
00007f4adaf7e000 112K r---- /usr/share/locale/de/LC_MESSAGES/gtk30.mo
00007f4adf38d000 112K r---- /usr/lib/libssl.so.3
00007f4ae03bd000 112K r-x-- /usr/lib/libexpat.so.1.8.10
00007f4ae0b43000 112K r---- /usr/lib/libX11.so.6.4.0
00007f4adce9e000 116K r-x-- /usr/lib/libxmlb.so.2.0.0
00007f4adf317000 120K r---- /usr/lib/libssl.so.3
00007f4adf911000 120K r---- /usr/lib/libcurl.so.4.8.0
00007f4ae09cc000 120K r-x-- /usr/lib/libxkbcommon.so.0.0.0
00007f4ae15e6000 120K r---- /usr/lib/libglib-2.0.so.0.7600.4
00007f4adf116000 124K r---- /usr/lib/libbrotlicommon.so.1.0.9
00007f4ac4000000 132K rw--- [ anon ]
00007f4ac8000000 132K rw--- [ anon ]
00007f4acc000000 132K rw--- [ anon ]
00007f4ad0000000 132K rw--- [ anon ]
00007f4ad4000000 132K rw--- [ anon ]
00007f4adcec8000 132K r---- /usr/lib/libappstream.so.0.16.2
00007f4adff43000 132K r-x-- /usr/lib/liblzma.so.5.4.4
00007f4ae09ea000 132K r---- /usr/lib/libxkbcommon.so.0.0.0
00007ffc224ed000 132K rw--- [ stack ]
00007f4adaf5b000 140K r---- /usr/share/locale/de/LC_MESSAGES/glib20.mo
00007f4adf03c000 140K r---- /usr/lib/libkrb5.so.3.3
00007f4adff0b000 140K r-x-- /usr/lib/libblkid.so.1.1.0
00007f4ae150d000 144K r---- /usr/lib/libpamac.so.11.6
00007f4adb351000 148K r-x-- /usr/lib/libstemmer.so.0.0.0
00007f4ad8e5a000 152K r--s- /var/cache/fontconfig/f2e43df3287529323e79e7929dc44cc9-le64.cache-8
00007f4adaf35000 152K r---- /usr/share/locale/de/LC_MESSAGES/libc.mo
00007f4ae0648000 152K r---- /usr/lib/libsoup-3.0.so.0.7.0
00007f4ae1200000 152K r---- /usr/lib/libc.so.6
00007f4ae22e2000 152K r-x-- /usr/lib/ld-linux-x86-64.so.2
000055e496cea000 156K r-x-- /usr/bin/pamac-manager
00007f4adf9d4000 156K r---- /usr/lib/libarchive.so.13.7.1
00007f4ae067b000 156K r-x-- /usr/lib/libalpm.so.13.0.2
00007f4ae0933000 160K r-x-- /usr/lib/libpng16.so.16.40.0
00007f4adcf98000 164K r--s- /usr/share/mime/mime.cache
00007f4ae2246000 164K r-x-- /usr/lib/libgdk_pixbuf-2.0.so.0.4200.10
00007f4ad8e80000 168K r--s- /var/cache/fontconfig/8d4af663993b81a124ee82e610bb31f9-le64.cache-8
00007f4ae059d000 168K r---- /usr/lib/libfreetype.so.6.20.0
00007f4ae1907000 168K r---- /usr/lib/libgdk-3.so.0.2406.32
00007f4ae0745000 172K r---- /usr/lib/libpcre2-8.so.0.11.2
00007f4ae0f13000 180K r-x-- /usr/lib/libfontconfig.so.1.13.0
00007f4adcf39000 184K r---- /usr/lib/libappstream.so.0.16.2
00007f4ae033a000 184K r-x-- /usr/lib/libdbus-1.so.3.32.3
00007f4adf3bf000 192K r-x-- /usr/lib/libssh2.so.1.0.1
00007f4ad8e22000 196K r---- /usr/share/icons/Papirus-Dark-Maia/icon-theme.cache
00007f4ae0846000 196K r---- /usr/lib/libtiff.so.6.0.1
00007f4adb2d8000 200K r---- /usr/lib/libflatpak.so.0.11504.0
00007f4ae019b000 200K r---- /usr/lib/libxml2.so.2.11.4
00007f4adaf01000 208K r---- /usr/share/locale/de/LC_MESSAGES/gtk30-properties.mo
00007f4adf724000 212K r---- /usr/lib/libsystemd.so.0.36.0
00007f4ae015e000 212K r---- /usr/lib/libsqlite3.so.0.8.6
00007f4ae0787000 212K r-x-- /usr/lib/libmount.so.1.1.0
00007f4ae21ea000 212K r-x-- /usr/lib/libgobject-2.0.so.0.7600.4
00007f4ae115f000 216K r---- /usr/lib/libharfbuzz.so.0.60811.0
00007f4ae11aa000 216K r-x-- /usr/lib/libpango-1.0.so.0.5000.14
00007f4ae0aab000 220K r---- /usr/lib/libtracker-sparql-3.0.so.0.503.0
00007f4ae104e000 220K r---- /usr/lib/libcairo.so.2.11708.0
00007f4ae15ab000 220K r---- /usr/lib/libhandy-1.so.0
00007f4adf838000 224K r-x-- /usr/lib/libgpgme.so.11.30.0
00007f4ae08f3000 224K r---- /usr/lib/libjpeg.so.8.3.2
00007f4adb058000 228K r-x-- /usr/lib/libsodium.so.23.3.0
00007f4adb1d3000 228K r---- /usr/lib/libostree-1.so.1.0.0
00007f4adf7c6000 228K r-x-- /usr/lib/libgssapi_krb5.so.2.2
00007f4ae1731000 228K r---- /usr/lib/libgio-2.0.so.0.7600.4
00007f4adf0c6000 248K r---- /usr/lib/libkrb5.so.3.3
00007f4adef9a000 252K r---- /usr/lib/libgcrypt.so.20.4.2
00007f4adb311000 256K r---- /usr/lib/libstemmer.so.0.0.0
00007f4adf149000 260K r-x-- /usr/lib/libunistring.so.5.0.0
00007f4ad8128000 284K r---- /usr/share/fonts/TTF/Roboto-Bold.ttf
00007f4ad8dae000 284K r---- /usr/share/fonts/TTF/Roboto-Bold.ttf
00007f4ad816f000 288K r---- /usr/share/fonts/TTF/Roboto-Regular.ttf
00007f4ad81b7000 288K r---- /usr/share/fonts/TTF/Roboto-Regular.ttf
00007f4ae19ad000 288K r---- /usr/lib/libgdk-3.so.0.2406.32
00007f4ae02ab000 292K r---- /usr/lib/libxml2.so.2.11.4
00007f4adcee9000 320K r-x-- /usr/lib/libappstream.so.0.16.2
00007f4adb389000 328K r---- /usr/lib/libstemmer.so.0.0.0
00007f4ae05f5000 332K r-x-- /usr/lib/libsoup-3.0.so.0.7.0
00007f4ae1385000 340K r---- /usr/lib/libc.so.6
00007f4ae07f0000 344K r-x-- /usr/lib/libtiff.so.6.0.1
00007f4adf335000 352K r-x-- /usr/lib/libssl.so.3
00007f4adfe9c000 364K r---- /usr/lib/libcrypto.so.3
00007f4ae1550000 364K r-x-- /usr/lib/libhandy-1.so.0
00007f4ae0d29000 368K r---- /usr/lib/libm.so.6
00007f4ae0e4c000 372K r---- /usr/lib/libepoxy.so.0.0.0
00007f4ae0d87000 380K r---- /usr/lib/libepoxy.so.0.0.0
00007f4ae13da000 400K r---- /usr/lib/libc.so.6
00007f4adf400000 404K r---- /usr/lib/libicuuc.so.73.2
00007f4ae0de6000 408K r-x-- /usr/lib/libepoxy.so.0.0.0
00007f4adf05f000 412K r-x-- /usr/lib/libkrb5.so.3.3
00007f4ae06da000 428K r-x-- /usr/lib/libpcre2-8.so.0.11.2
00007f4ae0887000 432K r-x-- /usr/lib/libjpeg.so.8.3.2
00007f4ae149c000 452K r-x-- /usr/lib/libpamac.so.11.6
00007f4ababe9000 468K r---- /usr/lib/librsvg-2.so.2.48.0
00007f4adf896000 492K r-x-- /usr/lib/libcurl.so.4.8.0
00007f4ae0a2f000 496K r-x-- /usr/lib/libtracker-sparql-3.0.so.0.503.0
00007f4ae1931000 496K r-x-- /usr/lib/libgdk-3.so.0.2406.32
00007f4ae0caa000 508K r-x-- /usr/lib/libm.so.6
00007f4ae1878000 528K r---- /usr/lib/libgio-2.0.so.0.7600.4
00007f4ae1a00000 528K r---- /usr/lib/libgtk-3.so.0.2406.32
00007f4ae03ef000 540K r-x-- /usr/lib/libpixman-1.so.0.42.2
00007f4ae0b5f000 556K r-x-- /usr/lib/libX11.so.6.4.0
00007f4ae0510000 564K r-x-- /usr/lib/libfreetype.so.6.20.0
00007f4ae16a1000 564K r---- /usr/lib/libglib-2.0.so.0.7600.4
00007f4adf946000 568K r-x-- /usr/lib/libarchive.so.13.7.1
00007f4aba800000 572K r---- /usr/lib/librsvg-2.so.2.48.0
00007f4adf695000 572K r-x-- /usr/lib/libsystemd.so.0.36.0
00007f4adf562000 576K r---- /usr/lib/libicuuc.so.73.2
00007f4ae0bea000 596K r---- /usr/lib/libX11.so.6.4.0
00007f4adcdd3000 600K r---- /usr/lib/libstdc++.so.6.0.32
00007f4ad8fd7000 604K r--s- /var/cache/fontconfig/17090aa38d5c6f09fb8c5c354938f1d7-le64.cache-8
00007f4adadf0000 608K r--s- /var/cache/fontconfig/df311e82a1a24c41a75c2c930223552e-le64.cache-8
00007f4adcc00000 624K r---- /usr/lib/libstdc++.so.6.0.32
00007f4ae1604000 628K r-x-- /usr/lib/libglib-2.0.so.0.7600.4
00007f4adb239000 636K r-x-- /usr/lib/libflatpak.so.0.11504.0
00007f4adb12c000 668K r-x-- /usr/lib/libostree-1.so.1.0.0
00007f4adaf9a000 708K r--s- /home/user/.local/share/mime/mime.cache
00007f4adfa00000 708K r---- /usr/lib/libcrypto.so.3
00007f4adff7e000 708K r-x-- /usr/lib/libzstd.so.1.5.5
00007f4ab4000000 732K rw--- [ anon ]
00007f4ac0000000 748K rw--- [ anon ]
00007f4ae1098000 796K r-x-- /usr/lib/libharfbuzz.so.0.60811.0
00007f4adfdca000 840K r---- /usr/lib/libcrypto.so.3
00007f4ae01cd000 888K r-x-- /usr/lib/libxml2.so.2.11.4
00007f4ae0f6d000 900K r-x-- /usr/lib/libcairo.so.2.11708.0
00007f4adeeaa000 960K r-x-- /usr/lib/libgcrypt.so.20.4.2
00007f4adf465000 1012K r-x-- /usr/lib/libicuuc.so.73.2
00007f4ae0058000 1048K r-x-- /usr/lib/libsqlite3.so.0.8.6
00007f4ad8ecd000 1064K r--s- /var/cache/fontconfig/f6b893a7224233d96cb72fd88691c0b4-le64.cache-8
00007f4ae176a000 1080K r-x-- /usr/lib/libgio-2.0.so.0.7600.4
00007f4abaacd000 1136K r---- /usr/lib/librsvg-2.so.2.48.0
00007f4adcc9c000 1244K r-x-- /usr/lib/libstdc++.so.6.0.32
00007f4ae1226000 1404K r-x-- /usr/lib/libc.so.6
00007f4adf18a000 1416K r---- /usr/lib/libunistring.so.5.0.0
00007f4ad986f000 1596K rw-s- /memfd:wayland-cursor (deleted)
00007f4aba608000 2016K r---- /usr/share/fonts/TTF/JetBrainsMonoNerdFont-Regular.ttf
00007f4abb607000 2016K r---- /usr/share/fonts/TTF/JetBrainsMonoNerdFont-Regular.ttf
00007f4aba88f000 2296K r-x-- /usr/lib/librsvg-2.so.2.48.0
00007f4aba399000 2492K rw-s- /memfd:gdk-wayland (deleted)
00007f4abae00000 2944K r---- /usr/share/icons/Papirus/icon-theme.cache
00007f4abb200000 2944K r---- /usr/share/icons/Papirus-Dark/icon-theme.cache
00007f4adfab1000 3172K r-x-- /usr/lib/libcrypto.so.3
00007f4ad8a00000 3612K r--s- /var/cache/fontconfig/923e285e415b1073c8df160bee08820f-le64.cache-8
00007f4ae1a84000 3668K r-x-- /usr/lib/libgtk-3.so.0.2406.32
00007f4ae1e19000 3736K r---- /usr/lib/libgtk-3.so.0.2406.32
00007f4adaa00000 3984K r---- /usr/lib/locale/locale-archive
00007f4ad8200000 8192K rw--- [ anon ]
00007f4ad906f000 8192K rw--- [ anon ]
00007f4ad99ff000 8192K rw--- [ anon ]
00007f4ada200000 8192K rw--- [ anon ]
00007f4adb3fe000 8192K rw--- [ anon ]
00007f4adbbff000 8192K rw--- [ anon ]
00007f4adc400000 8192K rw--- [ anon ]
00007f4abe77a000 25112K ----- [ anon ]
00007f4add000000 31284K r---- /usr/lib/libicudata.so.73.2
00007f4abb800000 48616K rw--- [ anon ]
00007f4ac00bb000 64788K ----- [ anon ]
00007f4ab40b7000 64804K ----- [ anon ]
00007f4ac4021000 65404K ----- [ anon ]
00007f4ac8021000 65404K ----- [ anon ]
00007f4acc021000 65404K ----- [ anon ]
00007f4ad0021000 65404K ----- [ anon ]
00007f4ad4021000 65404K ----- [ anon ]
000055e4977b0000 130140K rw--- [ anon ]
gesamt 845700K
GTK4
532628: pamac-manager
0000555e96177000 4K rw--- /usr/bin/pamac-manager
00007f15c57fb000 4K ----- [ anon ]
00007f15c5ffc000 4K ----- [ anon ]
00007f15c67fd000 4K ----- [ anon ]
00007f15c6ffe000 4K ----- [ anon ]
00007f15c77ff000 4K ----- [ anon ]
00007f15d85fd000 4K ----- [ anon ]
00007f15d8dfe000 4K ----- [ anon ]
00007f15d95ff000 4K ----- [ anon ]
00007f15f81f9000 4K ----- [ anon ]
00007f15f89fa000 4K ----- [ anon ]
00007f15fbe5e000 4K rw--- /usr/lib/librsvg-2.so.2.48.0
00007f1614709000 4K rw-s- [ anon ]
00007f161470a000 4K rw-s- [ anon ]
00007f161470b000 4K rw-s- [ anon ]
00007f161470c000 4K rw-s- [ anon ]
00007f161470d000 4K rw-s- [ anon ]
00007f161470e000 4K rw-s- [ anon ]
00007f161470f000 4K rw-s- [ anon ]
00007f1614b20000 4K r---- /usr/lib/libGLX.so.0.0.0
00007f1614b21000 4K rw--- /usr/lib/libGLX.so.0.0.0
00007f1614bb6000 4K rw--- /usr/lib/libGL.so.1.7.0
00007f1614bb7000 4K rw--- [ anon ]
00007f1614bf0000 4K rw-s- [ anon ]
00007f1614bf1000 4K rw-s- [ anon ]
00007f1614bf2000 4K rw-s- [ anon ]
00007f1614bf3000 4K rw-s- [ anon ]
00007f1614bf4000 4K rw-s- [ anon ]
00007f1614bf5000 4K rw-s- [ anon ]
00007f1614bf6000 4K rw-s- [ anon ]
00007f1614f87000 4K rw-s- [ anon ]
00007f1614f88000 4K rw-s- [ anon ]
00007f1614fad000 4K rw-s- [ anon ]
00007f1614fb2000 4K rw-s- [ anon ]
00007f1614fb3000 4K rw-s- [ anon ]
00007f1614fb4000 4K rw-s- [ anon ]
00007f1614fb5000 4K rw-s- [ anon ]
00007f1614fb6000 4K rw-s- [ anon ]
00007f1614fb7000 4K rw-s- [ anon ]
00007f1614fb8000 4K rw-s- [ anon ]
00007f1614fb9000 4K rw-s- [ anon ]
00007f1614fba000 4K rw-s- [ anon ]
00007f1614fbb000 4K rw-s- [ anon ]
00007f1614fbc000 4K rw-s- [ anon ]
00007f1614fbd000 4K rw-s- [ anon ]
00007f1614fbe000 4K rw-s- [ anon ]
00007f1614fbf000 4K rw-s- [ anon ]
00007f1614fc0000 4K rw-s- [ anon ]
00007f1614fc1000 4K rw-s- [ anon ]
00007f1614fc2000 4K rw-s- [ anon ]
00007f1614fc3000 4K rw-s- [ anon ]
00007f1614fc4000 4K rw-s- [ anon ]
00007f1614fc5000 4K rw-s- [ anon ]
00007f1614fc6000 4K rw-s- [ anon ]
00007f1614fc7000 4K rw-s- [ anon ]
00007f1614fc8000 4K rw-s- [ anon ]
00007f1614fc9000 4K rw-s- [ anon ]
00007f1614fca000 4K rw-s- [ anon ]
00007f1614fcb000 4K rw-s- [ anon ]
00007f1614fcc000 4K rw-s- [ anon ]
00007f1615017000 4K r---- /usr/lib/libpciaccess.so.0.11.1
00007f1615018000 4K rw--- /usr/lib/libpciaccess.so.0.11.1
00007f161508f000 4K rw--- /usr/lib/libncursesw.so.6.4
00007f16150c8000 4K rw--- /usr/lib/libedit.so.0.0.70
00007f16150ef000 4K r---- /usr/lib/libdrm_intel.so.1.0.0
00007f16150f0000 4K rw--- /usr/lib/libdrm_intel.so.1.0.0
00007f16150f9000 4K r---- /usr/lib/libdrm_nouveau.so.2.0.0
00007f16150fa000 4K rw--- /usr/lib/libdrm_nouveau.so.2.0.0
00007f1615105000 4K r---- /usr/lib/libdrm_amdgpu.so.1.0.0
00007f1615106000 4K rw--- /usr/lib/libdrm_amdgpu.so.1.0.0
00007f1615121000 4K r---- /usr/lib/libelf-0.189.so
00007f1615122000 4K rw--- /usr/lib/libelf-0.189.so
00007f161512f000 4K r---- /usr/lib/libdrm_radeon.so.1.0.1
00007f1615130000 4K rw--- /usr/lib/libdrm_radeon.so.1.0.1
00007f161513f000 4K r---- /usr/lib/libsensors.so.5.0.0
00007f1615140000 4K rw--- /usr/lib/libsensors.so.5.0.0
00007f1615141000 4K r---- /usr/lib/libxshmfence.so.1.0.0
00007f1615142000 4K r-x-- /usr/lib/libxshmfence.so.1.0.0
00007f1615143000 4K r---- /usr/lib/libxshmfence.so.1.0.0
00007f1615144000 4K r---- /usr/lib/libxshmfence.so.1.0.0
00007f1615145000 4K rw--- /usr/lib/libxshmfence.so.1.0.0
00007f161514c000 4K r---- /usr/lib/libxcb-sync.so.1.0.0
00007f161514d000 4K r---- /usr/lib/libxcb-sync.so.1.0.0
00007f161514e000 4K rw--- /usr/lib/libxcb-sync.so.1.0.0
00007f1615153000 4K r---- /usr/lib/libxcb-dri3.so.0.1.0
00007f1615154000 4K r---- /usr/lib/libxcb-dri3.so.0.1.0
00007f1615155000 4K rw--- /usr/lib/libxcb-dri3.so.0.1.0
00007f161516b000 4K rw--- /usr/lib/libwayland-server.so.0.22.0
00007f1615181000 4K r---- /usr/lib/libdrm.so.2.4.0
00007f1615182000 4K rw--- /usr/lib/libdrm.so.2.4.0
00007f1615193000 4K r---- /usr/lib/libxcb-randr.so.0.1.0
00007f1615194000 4K rw--- /usr/lib/libxcb-randr.so.0.1.0
00007f16151cd000 4K rw--- /usr/lib/libglapi.so.0.0.0
00007f16151ce000 4K rw--- [ anon ]
00007f1615219000 4K rw--- /usr/lib/libEGL_mesa.so.0.0.0
00007f161521a000 4K rw-s- [ anon ]
00007f161521b000 4K rw-s- [ anon ]
00007f161521c000 4K rw-s- [ anon ]
00007f161521d000 4K rw-s- [ anon ]
00007f161521e000 4K rw-s- [ anon ]
00007f161521f000 4K rw-s- [ anon ]
00007f1615220000 4K rw-s- [ anon ]
00007f1615221000 4K rw-s- [ anon ]
00007f1615222000 4K rw-s- [ anon ]
00007f1615223000 4K rw-s- [ anon ]
00007f1615224000 4K rw-s- [ anon ]
00007f1615225000 4K rw-s- [ anon ]
00007f1615226000 4K rw-s- [ anon ]
00007f1615227000 4K rw-s- [ anon ]
00007f1615228000 4K rw-s- [ anon ]
00007f1615229000 4K rw-s- [ anon ]
00007f161522a000 4K rw-s- [ anon ]
00007f161522b000 4K rw-s- [ anon ]
00007f161522c000 4K rw-s- [ anon ]
00007f161522d000 4K rw-s- [ anon ]
00007f161522e000 4K rw-s- [ anon ]
00007f161522f000 4K rw-s- [ anon ]
00007f1615230000 4K rw-s- [ anon ]
00007f1615231000 4K rw-s- [ anon ]
00007f1615232000 4K rw-s- [ anon ]
00007f1615233000 4K rw-s- [ anon ]
00007f161525c000 4K r---- /usr/lib/libxcb-present.so.0.0.0
00007f161525d000 4K r-x-- /usr/lib/libxcb-present.so.0.0.0
00007f161525e000 4K r---- /usr/lib/libxcb-present.so.0.0.0
00007f161525f000 4K r---- /usr/lib/libxcb-present.so.0.0.0
00007f1615260000 4K rw--- /usr/lib/libxcb-present.so.0.0.0
00007f1615267000 4K r---- /usr/lib/libxcb-xfixes.so.0.0.0
00007f1615268000 4K r---- /usr/lib/libxcb-xfixes.so.0.0.0
00007f1615269000 4K rw--- /usr/lib/libxcb-xfixes.so.0.0.0
00007f161526e000 4K r---- /usr/lib/libxcb-dri2.so.0.0.0
00007f161526f000 4K r---- /usr/lib/libxcb-dri2.so.0.0.0
00007f1615270000 4K rw--- /usr/lib/libxcb-dri2.so.0.0.0
00007f161527f000 4K r---- /usr/lib/libgbm.so.1.0.0
00007f1615280000 4K rw--- /usr/lib/libgbm.so.1.0.0
00007f1615330000 4K rw--- /usr/lib/libGLdispatch.so.0.0.0
00007f1615349000 4K r---- /usr/lib/libEGL.so.1.1.0
00007f161534a000 4K rw--- /usr/lib/libEGL.so.1.1.0
00007f161534b000 4K rw-s- [ anon ]
00007f161534c000 4K rw-s- [ anon ]
00007f161534d000 4K rw-s- [ anon ]
00007f161534e000 4K rw-s- [ anon ]
00007f161534f000 4K rw-s- [ anon ]
00007f1615350000 4K rw-s- [ anon ]
00007f1615351000 4K rw-s- [ anon ]
00007f1615352000 4K rw-s- [ anon ]
00007f1615353000 4K rw-s- [ anon ]
00007f1615354000 4K rw-s- [ anon ]
00007f1615355000 4K rw-s- [ anon ]
00007f1615356000 4K rw-s- [ anon ]
00007f1615357000 4K rw-s- [ anon ]
00007f1615358000 4K rw-s- [ anon ]
00007f16153c9000 4K rw-s- [ anon ]
00007f16153ca000 4K rw-s- [ anon ]
00007f16153cb000 4K rw-s- [ anon ]
00007f161541a000 4K r---- /usr/lib/libX11-xcb.so.1.0.0
00007f161541b000 4K r-x-- /usr/lib/libX11-xcb.so.1.0.0
00007f161541c000 4K r---- /usr/lib/libX11-xcb.so.1.0.0
00007f161541d000 4K r---- /usr/lib/libX11-xcb.so.1.0.0
00007f161541e000 4K rw--- /usr/lib/libX11-xcb.so.1.0.0
00007f161541f000 4K rw-s- [ anon ]
00007f1615420000 4K r---- /dev/shm/wlroots-gePhBh (deleted)
00007f1615425000 4K rwx-- [ anon ]
00007f1615426000 4K rw-s- [ anon ]
00007f16155fe000 4K ----- [ anon ]
00007f1615dff000 4K ----- [ anon ]
00007f16169e4000 4K rw-s- [ anon ]
00007f1616b3b000 4K r---- /usr/lib/libxfce4util.so.7.0.0
00007f1616b3c000 4K rw--- /usr/lib/libxfce4util.so.7.0.0
00007f1616b3d000 4K rw--- [ anon ]
00007f1616b51000 4K r---- /usr/lib/libxfconf-0.so.3.0.0
00007f1616b52000 4K rw--- /usr/lib/libxfconf-0.so.3.0.0
00007f1616b53000 4K rw-s- [ anon ]
00007f1616b89000 4K r---- /usr/lib/gio/modules/libdconfsettings.so
00007f1616b8a000 4K rw--- /usr/lib/gio/modules/libdconfsettings.so
00007f1616ba4000 4K rw-s- [ anon ]
00007f1616bab000 4K r---- /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so
00007f1616bac000 4K r-x-- /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so
00007f1616bad000 4K r---- /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so
00007f1616bae000 4K r---- /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so
00007f1616baf000 4K rw--- /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so
00007f1616c0e000 4K ----- [ anon ]
00007f161740f000 4K ----- [ anon ]
00007f1617d11000 4K rw--- /usr/lib/libdbus-1.so.3.32.3
00007f1617d6a000 4K r---- /usr/lib/libsodium.so.23.3.0
00007f1617d6b000 4K rw--- /usr/lib/libsodium.so.23.3.0
00007f1617d7d000 4K r---- /usr/lib/libavahi-client.so.3.2.9
00007f1617d7e000 4K rw--- /usr/lib/libavahi-client.so.3.2.9
00007f1617d8b000 4K r---- /usr/lib/libavahi-common.so.3.5.4
00007f1617d8c000 4K rw--- /usr/lib/libavahi-common.so.3.5.4
00007f1617da8000 4K r---- /usr/lib/libpolkit-gobject-1.so.0.0.0
00007f1617da9000 4K rw--- /usr/lib/libpolkit-gobject-1.so.0.0.0
00007f1617db9000 4K r---- /usr/lib/libmalcontent-0.so.0.11.1
00007f1617dba000 4K rw--- /usr/lib/libmalcontent-0.so.0.11.1
00007f1617eb7000 4K rw--- /usr/lib/libostree-1.so.1.0.0
00007f1624000000 4K rw-s- [ anon ]
00007f1624001000 4K r---- /usr/lib/libpthread.so.0
00007f1624002000 4K r-x-- /usr/lib/libpthread.so.0
00007f1624003000 4K r---- /usr/lib/libpthread.so.0
00007f1624004000 4K r---- /usr/lib/libpthread.so.0
00007f1624005000 4K rw--- /usr/lib/libpthread.so.0
00007f1624023000 4K r---- /usr/lib/libseccomp.so.2.5.4
00007f1624024000 4K rw--- /usr/lib/libseccomp.so.2.5.4
00007f16241fb000 4K rw--- /usr/lib/libsystemd.so.0.36.0
00007f16241fc000 4K rw--- [ anon ]
00007f16241fd000 4K ----- [ anon ]
00007f16249fe000 4K ----- [ anon ]
00007f16251ff000 4K ----- [ anon ]
00007f1625c76000 4K rw--- /usr/lib/libstdc++.so.6.0.32
00007f1625c8a000 4K r---- /usr/lib/libdconf.so.1.0.0
00007f1625c8b000 4K rw--- /usr/lib/libdconf.so.1.0.0
00007f1625d56000 4K rw--- /usr/lib/libstemmer.so.0.0.0
00007f1627c8d000 4K r---- /usr/lib/libicudata.so.73.2
00007f1627c8e000 4K r---- /var/lib/flatpak/exports/share/icons/hicolor/icon-theme.cache
00007f1627c8f000 4K rw-s- [ anon ]
00007f1627ca2000 4K r---- /usr/lib/libpamac-flatpak.so.11.6
00007f1627ca3000 4K rw--- /usr/lib/libpamac-flatpak.so.11.6
00007f1627cae000 4K r---- /usr/lib/libcap.so.2.69
00007f1627caf000 4K rw--- /usr/lib/libcap.so.2.69
00007f1627ccf000 4K r---- /usr/lib/libyaml-0.so.2.0.9
00007f1627cd0000 4K rw--- /usr/lib/libyaml-0.so.2.0.9
00007f1627d01000 4K r---- /usr/lib/libxmlb.so.2.0.0
00007f1627d02000 4K rw--- /usr/lib/libxmlb.so.2.0.0
00007f1627d0b000 4K r---- /usr/lib/libpamac-appstream.so.11.6
00007f1627d0c000 4K rw--- /usr/lib/libpamac-appstream.so.11.6
00007f1627d19000 4K r---- /usr/lib/libpamac-aur.so.11.6
00007f1627d1a000 4K rw--- /usr/lib/libpamac-aur.so.11.6
00007f1627d1d000 4K r---- /usr/lib/libgthread-2.0.so.0.7600.4
00007f1627d1e000 4K r-x-- /usr/lib/libgthread-2.0.so.0.7600.4
00007f1627d1f000 4K r---- /usr/lib/libgthread-2.0.so.0.7600.4
00007f1627d20000 4K r---- /usr/lib/libgthread-2.0.so.0.7600.4
00007f1627d21000 4K rw--- /usr/lib/libgthread-2.0.so.0.7600.4
00007f1627d27000 4K r---- /usr/lib/gio/modules/libxfconfgsettingsbackend.so
00007f1627d28000 4K r---- /usr/lib/gio/modules/libxfconfgsettingsbackend.so
00007f1627d29000 4K rw--- /usr/lib/gio/modules/libxfconfgsettingsbackend.so
00007f1627d8f000 4K rw--- /usr/lib/gvfs/libgvfscommon.so
00007f1627dab000 4K r---- /usr/lib/libresolv.so.2
00007f1627dac000 4K rw--- /usr/lib/libresolv.so.2
00007f1627db3000 4K r---- /usr/lib/libkeyutils.so.1.10
00007f1627db4000 4K r---- /usr/lib/libkeyutils.so.1.10
00007f1627db5000 4K rw--- /usr/lib/libkeyutils.so.1.10
00007f1627dc2000 4K r---- /usr/lib/libkrb5support.so.0.1
00007f1627dc3000 4K rw--- /usr/lib/libkrb5support.so.0.1
00007f1627dc6000 4K r-x-- /usr/lib/libcom_err.so.2.1
00007f1627dc7000 4K r---- /usr/lib/libcom_err.so.2.1
00007f1627dc8000 4K r---- /usr/lib/libcom_err.so.2.1
00007f1627dc9000 4K rw--- /usr/lib/libcom_err.so.2.1
00007f1627df7000 4K rw--- /usr/lib/libk5crypto.so.3.1
00007f1627ed0000 4K r---- /usr/lib/libbrotlicommon.so.1.0.9
00007f1627ed1000 4K r-x-- /usr/lib/libbrotlicommon.so.1.0.9
00007f1627ef1000 4K r---- /usr/lib/libbrotlicommon.so.1.0.9
00007f1627ef2000 4K rw--- /usr/lib/libbrotlicommon.so.1.0.9
00007f16280ac000 4K rw--- /usr/lib/libunistring.so.5.0.0
00007f16280d1000 4K r---- /usr/lib/libgpg-error.so.0.34.0
00007f16280d2000 4K rw--- /usr/lib/libgpg-error.so.0.34.0
00007f16281bb000 4K rw--- /usr/lib/libssh2.so.1.0.1
00007f16281dc000 4K r---- /usr/lib/libidn2.so.0.3.8
00007f16281dd000 4K rw--- /usr/lib/libidn2.so.0.3.8
00007f16281fe000 4K r---- /usr/lib/liblz4.so.1.9.4
00007f16281ff000 4K rw--- /usr/lib/liblz4.so.1.9.4
00007f1628405000 4K rw--- /usr/lib/libicuuc.so.73.2
00007f162841d000 4K r---- /usr/lib/libassuan.so.0.8.6
00007f162841e000 4K rw--- /usr/lib/libassuan.so.0.8.6
00007f1628427000 4K r---- /usr/lib/libacl.so.1.1.2301
00007f1628428000 4K r---- /usr/lib/libacl.so.1.1.2301
00007f1628429000 4K rw--- /usr/lib/libacl.so.1.1.2301
00007f1628430000 4K r---- /usr/lib/libXdmcp.so.6.0.0
00007f1628431000 4K rw--- /usr/lib/libXdmcp.so.6.0.0
00007f1628432000 4K r---- /usr/lib/libXau.so.6.0.0
00007f1628433000 4K r-x-- /usr/lib/libXau.so.6.0.0
00007f1628434000 4K r---- /usr/lib/libXau.so.6.0.0
00007f1628435000 4K r---- /usr/lib/libXau.so.6.0.0
00007f1628436000 4K rw--- /usr/lib/libXau.so.6.0.0
00007f1628448000 4K r---- /usr/lib/libbz2.so.1.0.8
00007f1628449000 4K rw--- /usr/lib/libbz2.so.1.0.8
00007f1628450000 4K r---- /usr/lib/libdatrie.so.1.4.0
00007f1628451000 4K r---- /usr/lib/libdatrie.so.1.4.0
00007f1628452000 4K rw--- /usr/lib/libdatrie.so.1.4.0
00007f162847d000 4K rw--- /usr/lib/libnghttp2.so.14.24.3
00007f16284d1000 4K rw--- /usr/lib/libgssapi_krb5.so.2.2
00007f16284d2000 4K r---- /usr/lib/libbrotlidec.so.1.0.9
00007f16284de000 4K r---- /usr/lib/libbrotlidec.so.1.0.9
00007f16284df000 4K rw--- /usr/lib/libbrotlidec.so.1.0.9
00007f1628533000 4K r---- /usr/lib/libgpgme.so.11.30.0
00007f16285ff000 4K rw--- /usr/lib/libarchive.so.13.7.1
00007f1628afd000 4K r--s- /run/user/1000/dconf/user
00007f1628b14000 4K r---- /usr/lib/libpsl.so.5.3.4
00007f1628b15000 4K rw--- /usr/lib/libpsl.so.5.3.4
00007f1628c03000 4K rw--- /usr/lib/libblkid.so.1.1.0
00007f1628c23000 4K r---- /usr/lib/liblzo2.so.2.0.0
00007f1628c24000 4K rw--- /usr/lib/liblzo2.so.2.0.0
00007f1628c56000 4K r---- /usr/lib/liblzma.so.5.4.4
00007f1628c57000 4K rw--- /usr/lib/liblzma.so.5.4.4
00007f1628d29000 4K r---- /usr/lib/libzstd.so.1.5.5
00007f1628d2a000 4K rw--- /usr/lib/libzstd.so.1.5.5
00007f1628fe5000 4K rw--- /usr/lib/libxml2.so.2.11.4
00007f1628fe6000 4K rw--- [ anon ]
00007f1629010000 4K r---- /usr/lib/libjson-glib-1.0.so.0.600.6
00007f1629011000 4K rw--- /usr/lib/libjson-glib-1.0.so.0.600.6
00007f1629035000 4K r---- /usr/lib/libgcc_s.so.1
00007f1629036000 4K rw--- /usr/lib/libgcc_s.so.1
00007f1629061000 4K rw--- /usr/lib/libexpat.so.1.8.10
00007f1629110000 4K rw--- /usr/lib/libpixman-1.so.0.42.2
00007f1629111000 4K r---- /usr/lib/libxcb-shm.so.0.0.0
00007f1629112000 4K r-x-- /usr/lib/libxcb-shm.so.0.0.0
00007f1629113000 4K r---- /usr/lib/libxcb-shm.so.0.0.0
00007f1629114000 4K r---- /usr/lib/libxcb-shm.so.0.0.0
00007f1629115000 4K rw--- /usr/lib/libxcb-shm.so.0.0.0
00007f1629123000 4K r---- /usr/lib/libxcb-render.so.0.0.0
00007f1629124000 4K rw--- /usr/lib/libxcb-render.so.0.0.0
00007f162914e000 4K r---- /usr/lib/libxcb.so.1.1.0
00007f162914f000 4K rw--- /usr/lib/libxcb.so.1.1.0
00007f162915b000 4K r---- /usr/lib/libXrender.so.1.3.0
00007f162915c000 4K rw--- /usr/lib/libXrender.so.1.3.0
00007f162917f000 4K rw--- /usr/lib/libgraphite2.so.3.2.1
00007f162924f000 4K rw--- /usr/lib/libfreetype.so.6.20.0
00007f1629259000 4K r---- /usr/lib/libthai.so.0.3.1
00007f162925a000 4K rw--- /usr/lib/libthai.so.0.3.1
00007f16292f2000 4K rw--- /usr/lib/libsoup-3.0.so.0.7.0
00007f162932e000 4K r---- /usr/lib/libalpm.so.13.0.2
00007f162932f000 4K rw--- /usr/lib/libalpm.so.13.0.2
00007f16293c9000 4K r---- /usr/lib/libpcre2-8.so.0.11.2
00007f16293ca000 4K rw--- /usr/lib/libpcre2-8.so.0.11.2
00007f16293d5000 4K r---- /usr/lib/libffi.so.8.1.2
00007f16293d6000 4K r---- /usr/lib/libffi.so.8.1.2
00007f16293d7000 4K rw--- /usr/lib/libffi.so.8.1.2
00007f1629428000 4K rw--- /usr/lib/libmount.so.1.1.0
00007f1629441000 4K r---- /usr/lib/libz.so.1.2.13
00007f1629442000 4K rw--- /usr/lib/libz.so.1.2.13
00007f1629465000 4K rw--- /usr/lib/libcairo-script-interpreter.so.2.11708.0
00007f1629466000 4K r---- /usr/lib/libXinerama.so.1.0.0
00007f1629467000 4K r-x-- /usr/lib/libXinerama.so.1.0.0
00007f1629468000 4K r---- /usr/lib/libXinerama.so.1.0.0
00007f1629469000 4K r---- /usr/lib/libXinerama.so.1.0.0
00007f162946a000 4K rw--- /usr/lib/libXinerama.so.1.0.0
00007f1629476000 4K r---- /usr/lib/libXrandr.so.2.2.0
00007f1629477000 4K rw--- /usr/lib/libXrandr.so.2.2.0
00007f162947d000 4K r---- /usr/lib/libXfixes.so.3.1.0
00007f162947e000 4K r---- /usr/lib/libXfixes.so.3.1.0
00007f162947f000 4K rw--- /usr/lib/libXfixes.so.3.1.0
00007f1629480000 4K r---- /usr/lib/libXdamage.so.1.1.0
00007f1629481000 4K r-x-- /usr/lib/libXdamage.so.1.1.0
00007f1629482000 4K r---- /usr/lib/libXdamage.so.1.1.0
00007f1629483000 4K r---- /usr/lib/libXdamage.so.1.1.0
00007f1629484000 4K rw--- /usr/lib/libXdamage.so.1.1.0
00007f162948f000 4K r---- /usr/lib/libXcursor.so.1.0.2
00007f1629490000 4K rw--- /usr/lib/libXcursor.so.1.0.2
00007f16294a4000 4K r---- /usr/lib/libXext.so.6.4.0
00007f16294a5000 4K rw--- /usr/lib/libXext.so.6.4.0
00007f16294a6000 4K r---- /usr/lib/libwayland-egl.so.1.22.0
00007f16294a7000 4K r-x-- /usr/lib/libwayland-egl.so.1.22.0
00007f16294a8000 4K r---- /usr/lib/libwayland-egl.so.1.22.0
00007f16294a9000 4K r---- /usr/lib/libwayland-egl.so.1.22.0
00007f16294aa000 4K rw--- /usr/lib/libwayland-egl.so.1.22.0
00007f16294bc000 4K rw--- /usr/lib/libwayland-client.so.0.22.0
00007f1629503000 4K rw--- /usr/lib/libxkbcommon.so.0.0.0
00007f16295ae000 4K r---- /usr/lib/libjpeg.so.8.3.2
00007f16295af000 4K rw--- /usr/lib/libjpeg.so.8.3.2
00007f162967f000 4K r---- /usr/lib/libpng16.so.16.40.0
00007f1629680000 4K rw--- /usr/lib/libpng16.so.16.40.0
00007f162975b000 4K rw--- /usr/lib/libtracker-sparql-3.0.so.0.503.0
00007f1629771000 4K r---- /usr/lib/libcloudproviders.so.0.3.1
00007f1629772000 4K rw--- /usr/lib/libcloudproviders.so.0.3.1
00007f1629789000 4K r---- /usr/lib/libpangoft2-1.0.so.0.5000.14
00007f162978a000 4K rw--- /usr/lib/libpangoft2-1.0.so.0.5000.14
00007f16298ea000 4K ----- /usr/lib/libgraphene-1.0.so.0.1000.8
00007f16298eb000 4K r---- /usr/lib/libgraphene-1.0.so.0.1000.8
00007f16298ec000 4K rw--- /usr/lib/libgraphene-1.0.so.0.1000.8
00007f16299d8000 4K r---- /usr/lib/libm.so.6
00007f16299d9000 4K rw--- /usr/lib/libm.so.6
00007f1629b59000 4K rw--- /usr/lib/libfontconfig.so.1.13.0
00007f1629c8b000 4K rw--- [ anon ]
00007f1629d95000 4K r---- /usr/lib/libharfbuzz.so.0.60811.0
00007f1629d96000 4K rw--- /usr/lib/libharfbuzz.so.0.60811.0
00007f1629dff000 4K rw--- /usr/lib/libpango-1.0.so.0.5000.14
00007f162a04d000 4K r---- /usr/lib/locale/C.UTF-8/LC_COLLATE
00007f162a064000 4K r---- /usr/lib/libXi.so.6.1.0
00007f162a065000 4K rw--- /usr/lib/libXi.so.6.1.0
00007f162a119000 4K rw--- /usr/lib/libpamac.so.11.6
00007f162a27b000 4K rw--- /usr/lib/libadwaita-1.so.0
00007f162a27c000 4K rw--- [ anon ]
00007f162a3c5000 4K r---- /usr/lib/libglib-2.0.so.0.7600.4
00007f162a3c6000 4K rw--- /usr/lib/libglib-2.0.so.0.7600.4
00007f162a3c7000 4K rw--- [ anon ]
00007f162a429000 4K rw--- /usr/lib/libgobject-2.0.so.0.7600.4
00007f162a5fd000 4K rw--- /usr/lib/libgio-2.0.so.0.7600.4
00007f162ade6000 4K rw--- /usr/lib/libcairo-gobject.so.2.11708.0
00007f162ae05000 4K r---- /usr/lib/libfribidi.so.0.4.0
00007f162ae06000 4K rw--- /usr/lib/libfribidi.so.0.4.0
00007f162ae17000 4K r---- /usr/lib/libpangocairo-1.0.so.0.5000.14
00007f162ae18000 4K rw--- /usr/lib/libpangocairo-1.0.so.0.5000.14
00007f162ae1d000 4K r---- /usr/lib/libgmodule-2.0.so.0.7600.4
00007f162ae1e000 4K r---- /usr/lib/libgmodule-2.0.so.0.7600.4
00007f162ae1f000 4K rw--- /usr/lib/libgmodule-2.0.so.0.7600.4
00007f162ae67000 4K rw--- /usr/lib/libgdk_pixbuf-2.0.so.0.4200.10
00007f162ae89000 4K rw--- /usr/lib/libpamac-gtk.so
00007f162ae8c000 4K r--s- /var/lib/flatpak/exports/share/mime/mime.cache
00007f162ae8d000 4K r---- /usr/lib/libavahi-glib.so.1.0.2
00007f162ae8e000 4K r-x-- /usr/lib/libavahi-glib.so.1.0.2
00007f162ae8f000 4K r---- /usr/lib/libavahi-glib.so.1.0.2
00007f162ae90000 4K r---- /usr/lib/libavahi-glib.so.1.0.2
00007f162ae91000 4K rw--- /usr/lib/libavahi-glib.so.1.0.2
00007f162aec3000 4K rw--- /usr/lib/gio/modules/libgvfsdbus.so
00007f162aec4000 4K r---- /usr/lib/ld-linux-x86-64.so.2
0000555e96175000 8K r---- /usr/bin/pamac-manager
00007f1615015000 8K r---- /usr/lib/libpciaccess.so.0.11.1
00007f16150c6000 8K r---- /usr/lib/libedit.so.0.0.70
00007f16150f1000 8K r---- /usr/lib/libdrm_nouveau.so.2.0.0
00007f16150f7000 8K r---- /usr/lib/libdrm_nouveau.so.2.0.0
00007f1615103000 8K r---- /usr/lib/libdrm_amdgpu.so.1.0.0
00007f1615123000 8K r---- /usr/lib/libdrm_radeon.so.1.0.1
00007f161514f000 8K r---- /usr/lib/libxcb-dri3.so.0.1.0
00007f1615151000 8K r-x-- /usr/lib/libxcb-dri3.so.0.1.0
00007f1615169000 8K r---- /usr/lib/libwayland-server.so.0.22.0
00007f161526a000 8K r---- /usr/lib/libxcb-dri2.so.0.0.0
00007f161526c000 8K r-x-- /usr/lib/libxcb-dri2.so.0.0.0
00007f1617d0f000 8K r---- /usr/lib/libdbus-1.so.3.32.3
00007f1624006000 8K r---- /usr/lib/libseccomp.so.2.5.4
00007f1624113000 8K rw--- /usr/lib/libflatpak.so.0.11504.0
00007f1625dfe000 8K rw--- /usr/lib/libappstream.so.0.16.2
00007f1627cac000 8K r---- /usr/lib/libcap.so.2.69
00007f1627cb0000 8K r---- /usr/lib/libyaml-0.so.2.0.9
00007f1627d09000 8K r---- /usr/lib/libpamac-appstream.so.11.6
00007f1627d17000 8K r---- /usr/lib/libpamac-aur.so.11.6
00007f1627d1b000 8K r---- /home/user/.config/dconf/user
00007f1627d25000 8K r-x-- /usr/lib/gio/modules/libxfconfgsettingsbackend.so
00007f1627da9000 8K r---- /usr/lib/libresolv.so.2
00007f1627dad000 8K rw--- [ anon ]
00007f1627daf000 8K r---- /usr/lib/libkeyutils.so.1.10
00007f1627db1000 8K r-x-- /usr/lib/libkeyutils.so.1.10
00007f1627dc0000 8K r---- /usr/lib/libkrb5support.so.0.1
00007f1627dc4000 8K r---- /usr/lib/libcom_err.so.2.1
00007f1627df5000 8K r---- /usr/lib/libk5crypto.so.3.1
00007f1627ece000 8K rw--- /usr/lib/libkrb5.so.3.3
00007f16281b9000 8K r---- /usr/lib/libssh2.so.1.0.1
00007f16281bc000 8K r---- /usr/lib/libidn2.so.0.3.8
00007f16281fc000 8K r---- /usr/lib/liblz4.so.1.9.4
00007f162841f000 8K rw--- [ anon ]
00007f1628421000 8K r---- /usr/lib/libacl.so.1.1.2301
00007f162842a000 8K r---- /usr/lib/libXdmcp.so.6.0.0
00007f162842c000 8K r-x-- /usr/lib/libXdmcp.so.6.0.0
00007f162842e000 8K r---- /usr/lib/libXdmcp.so.6.0.0
00007f1628437000 8K r---- /usr/lib/libbz2.so.1.0.8
00007f1628446000 8K r---- /usr/lib/libbz2.so.1.0.8
00007f162844a000 8K r---- /usr/lib/libdatrie.so.1.4.0
00007f16284cf000 8K r---- /usr/lib/libgssapi_krb5.so.2.2
00007f1628534000 8K rw--- /usr/lib/libgpgme.so.11.30.0
00007f1628b02000 8K r---- /usr/lib/libpsl.so.5.3.4
00007f1628b04000 8K r-x-- /usr/lib/libpsl.so.5.3.4
00007f1628bc6000 8K rw--- [ anon ]
00007f1628d2b000 8K rw--- [ anon ]
00007f162905f000 8K r---- /usr/lib/libexpat.so.1.8.10
00007f1629062000 8K rw--- [ anon ]
00007f1629121000 8K r---- /usr/lib/libxcb-render.so.0.0.0
00007f1629150000 8K r---- /usr/lib/libXrender.so.1.3.0
00007f1629159000 8K r---- /usr/lib/libXrender.so.1.3.0
00007f162917d000 8K r---- /usr/lib/libgraphite2.so.3.2.1
00007f1629180000 8K rw--- [ anon ]
00007f1629250000 8K r---- /usr/lib/libthai.so.0.3.1
00007f16293cb000 8K rw--- [ anon ]
00007f16293cd000 8K r---- /usr/lib/libffi.so.8.1.2
00007f1629426000 8K r---- /usr/lib/libmount.so.1.1.0
00007f1629463000 8K r---- /usr/lib/libcairo-script-interpreter.so.2.11708.0
00007f162946b000 8K r---- /usr/lib/libXrandr.so.2.2.0
00007f1629474000 8K r---- /usr/lib/libXrandr.so.2.2.0
00007f1629478000 8K r---- /usr/lib/libXfixes.so.3.1.0
00007f162948d000 8K r---- /usr/lib/libXcursor.so.1.0.2
00007f16294ba000 8K r---- /usr/lib/libwayland-client.so.0.22.0
00007f1629501000 8K r---- /usr/lib/libxkbcommon.so.0.0.0
00007f1629b57000 8K r---- /usr/lib/libfontconfig.so.1.13.0
00007f1629c89000 8K rw--- /usr/lib/libcairo.so.2.11708.0
00007f162a03e000 8K rw--- /usr/lib/libc.so.6
00007f162a5fe000 8K rw--- [ anon ]
00007f162ade0000 8K r-x-- /usr/lib/libcairo-gobject.so.2.11708.0
00007f162ade2000 8K r---- /usr/lib/libcairo-gobject.so.2.11708.0
00007f162ade4000 8K r---- /usr/lib/libcairo-gobject.so.2.11708.0
00007f162ade7000 8K r---- /usr/lib/libfribidi.so.0.4.0
00007f162ae07000 8K rw--- [ anon ]
00007f162ae15000 8K r---- /usr/lib/libpangocairo-1.0.so.0.5000.14
00007f162ae19000 8K r---- /usr/lib/libgmodule-2.0.so.0.7600.4
00007f162ae1b000 8K r-x-- /usr/lib/libgmodule-2.0.so.0.7600.4
00007f162ae20000 8K rw--- [ anon ]
00007f162ae65000 8K r---- /usr/lib/libgdk_pixbuf-2.0.so.0.4200.10
00007f162ae87000 8K r---- /usr/lib/libpamac-gtk.so
00007f162ae8a000 8K rw--- [ anon ]
00007f162aec1000 8K r---- /usr/lib/gio/modules/libgvfsdbus.so
00007f162aef5000 8K r---- /usr/lib/ld-linux-x86-64.so.2
00007f162aef7000 8K rw--- /usr/lib/ld-linux-x86-64.so.2
00007fff53dd9000 8K r-x-- [ anon ]
00007f1614b00000 12K r---- /usr/lib/libGLX.so.0.0.0
00007f1614b1d000 12K r---- /usr/lib/libGLX.so.0.0.0
00007f161500d000 12K r---- /usr/lib/libpciaccess.so.0.11.1
00007f16150c9000 12K rw--- [ anon ]
00007f16150cc000 12K r---- /usr/lib/libdrm_intel.so.1.0.0
00007f16150fb000 12K r---- /usr/lib/libdrm_amdgpu.so.1.0.0
00007f1615131000 12K r---- /usr/lib/libsensors.so.5.0.0
00007f1615146000 12K r---- /usr/lib/libxcb-sync.so.1.0.0
00007f1615149000 12K r-x-- /usr/lib/libxcb-sync.so.1.0.0
00007f1615190000 12K r---- /usr/lib/libxcb-randr.so.0.1.0
00007f1615261000 12K r---- /usr/lib/libxcb-xfixes.so.0.0.0
00007f1615264000 12K r-x-- /usr/lib/libxcb-xfixes.so.0.0.0
00007f1615271000 12K r---- /usr/lib/libgbm.so.1.0.0
00007f1615339000 12K r---- /usr/lib/libEGL.so.1.1.0
00007f16169e5000 12K r--s- /var/cache/fontconfig/699564f050ff7e0f9dae359f33bc56a5-le64.cache-8
00007f1616b63000 12K r--s- /var/cache/fontconfig/6ba42ae0000f58711b5caaf10d690066-le64.cache-8
00007f1616b86000 12K r---- /usr/lib/gio/modules/libdconfsettings.so
00007f1616bb0000 12K r---- /home/user/.local/share/icons/hicolor/icon-theme.cache
00007f1617d7f000 12K r---- /usr/lib/libavahi-common.so.3.5.4
00007f1617d88000 12K r---- /usr/lib/libavahi-common.so.3.5.4
00007f1617eb4000 12K r---- /usr/lib/libostree-1.so.1.0.0
00007f1627ca4000 12K r---- /usr/lib/libcap.so.2.69
00007f1627d03000 12K r---- /usr/lib/libpamac-appstream.so.11.6
00007f1627d06000 12K r-x-- /usr/lib/libpamac-appstream.so.11.6
00007f1627d22000 12K r---- /usr/lib/gio/modules/libxfconfgsettingsbackend.so
00007f1627d9e000 12K r---- /usr/lib/libresolv.so.2
00007f1627db6000 12K r---- /usr/lib/libkrb5support.so.0.1
00007f16281de000 12K r---- /usr/lib/liblz4.so.1.9.4
00007f162847a000 12K r---- /usr/lib/libnghttp2.so.14.24.3
00007f16284db000 12K r---- /usr/lib/libbrotlidec.so.1.0.9
00007f1628af7000 12K rw--- /usr/lib/libcrypto.so.3
00007f1628afa000 12K rw--- [ anon ]
00007f1628bc3000 12K rw--- /usr/lib/libcurl.so.4.8.0
00007f1628c04000 12K r---- /usr/lib/liblzo2.so.2.0.0
00007f1628c20000 12K r---- /usr/lib/liblzo2.so.2.0.0
00007f162915d000 12K r---- /usr/lib/libgraphite2.so.3.2.1
00007f1629256000 12K r---- /usr/lib/libthai.so.0.3.1
00007f1629330000 12K r---- /usr/lib/libpcre2-8.so.0.11.2
00007f1629429000 12K r---- /usr/lib/libz.so.1.2.13
00007f162947a000 12K r-x-- /usr/lib/libXfixes.so.3.1.0
00007f1629485000 12K r---- /usr/lib/libXcursor.so.1.0.2
00007f16294b7000 12K r---- /usr/lib/libwayland-client.so.0.22.0
00007f1629644000 12K rw--- /usr/lib/libtiff.so.6.0.1
00007f16298c7000 12K r---- /usr/lib/libX11.so.6.4.0
00007f162a052000 12K r---- /usr/lib/libXi.so.6.1.0
00007f162a061000 12K r---- /usr/lib/libXi.so.6.1.0
00007f162a426000 12K r---- /usr/lib/libgobject-2.0.so.0.7600.4
00007f1614710000 16K rw-s- [ anon ]
00007f16147cc000 16K rw-s- [ anon ]
00007f16147d0000 16K rw-s- [ anon ]
00007f16147d4000 16K rw-s- [ anon ]
00007f16147d8000 16K rw-s- [ anon ]
00007f16147dc000 16K rw-s- [ anon ]
00007f16147e0000 16K rw-s- [ anon ]
00007f16147e4000 16K rw-s- [ anon ]
00007f16147e8000 16K rw-s- [ anon ]
00007f16147ec000 16K rw-s- [ anon ]
00007f16147f0000 16K rw-s- [ anon ]
00007f16147f4000 16K rw-s- [ anon ]
00007f16147f8000 16K rw-s- [ anon ]
00007f16147fc000 16K rw-s- [ anon ]
00007f1614ae0000 16K rw-s- [ anon ]
00007f1614ae4000 16K rw-s- [ anon ]
00007f1614ae8000 16K rw-s- [ anon ]
00007f1614aec000 16K rw-s- [ anon ]
00007f1614af0000 16K rw-s- [ anon ]
00007f1614af4000 16K rw-s- [ anon ]
00007f1614af8000 16K rw-s- [ anon ]
00007f1614afc000 16K rw-s- [ anon ]
00007f1614bb8000 16K rw-s- [ anon ]
00007f1614bbc000 16K rw-s- [ anon ]
00007f1614bc0000 16K rw-s- [ anon ]
00007f1614bc4000 16K rw-s- [ anon ]
00007f1614bc8000 16K rw-s- [ anon ]
00007f1614bcc000 16K rw-s- [ anon ]
00007f1614f89000 16K rw-s- [ anon ]
00007f1614fae000 16K rw-s- [ anon ]
00007f161508b000 16K r---- /usr/lib/libncursesw.so.6.4
00007f16150f3000 16K r-x-- /usr/lib/libdrm_nouveau.so.2.0.0
00007f1615107000 16K r---- /usr/lib/libelf-0.189.so
00007f161511d000 16K r---- /usr/lib/libelf-0.189.so
00007f161512b000 16K r---- /usr/lib/libdrm_radeon.so.1.0.1
00007f161513b000 16K r---- /usr/lib/libsensors.so.5.0.0
00007f1615165000 16K r---- /usr/lib/libwayland-server.so.0.22.0
00007f161517d000 16K r---- /usr/lib/libdrm.so.2.4.0
00007f16151c9000 16K r---- /usr/lib/libglapi.so.0.0.0
00007f1615215000 16K r---- /usr/lib/libEGL_mesa.so.0.0.0
00007f161527b000 16K r---- /usr/lib/libgbm.so.1.0.0
00007f1615345000 16K r---- /usr/lib/libEGL.so.1.1.0
00007f1615416000 16K rw-s- [ anon ]
00007f1615421000 16K rw-s- [ anon ]
00007f1616b2b000 16K r---- /usr/lib/libxfce4util.so.7.0.0
00007f1616b37000 16K r---- /usr/lib/libxfce4util.so.7.0.0
00007f1616b7c000 16K r---- /usr/lib/gio/modules/libdconfsettings.so
00007f1617d6c000 16K r---- /usr/lib/libavahi-client.so.3.2.9
00007f1617d79000 16K r---- /usr/lib/libavahi-client.so.3.2.9
00007f1617daa000 16K r---- /usr/lib/libmalcontent-0.so.0.11.1
00007f1617db5000 16K r---- /usr/lib/libmalcontent-0.so.0.11.1
00007f1617ffb000 16K rw--- /usr/lib/libgcrypt.so.20.4.2
00007f1625c77000 16K rw--- [ anon ]
00007f1625c7b000 16K r---- /usr/lib/libdconf.so.1.0.0
00007f1625c86000 16K r---- /usr/lib/libdconf.so.1.0.0
00007f1627c9e000 16K r---- /usr/lib/libpamac-flatpak.so.11.6
00007f1627ccb000 16K r---- /usr/lib/libyaml-0.so.2.0.9
00007f1627d0d000 16K r---- /usr/lib/libpamac-aur.so.11.6
00007f1627dca000 16K r---- /usr/lib/libk5crypto.so.3.1
00007f16280a8000 16K r---- /usr/lib/libunistring.so.5.0.0
00007f162816f000 16K rw--- /usr/lib/libssl.so.3
00007f16281be000 16K r-x-- /usr/lib/libidn2.so.0.3.8
00007f1628406000 16K rw--- [ anon ]
00007f162840a000 16K r---- /usr/lib/libassuan.so.0.8.6
00007f1628419000 16K r---- /usr/lib/libassuan.so.0.8.6
00007f1628423000 16K r-x-- /usr/lib/libacl.so.1.1.2301
00007f162844c000 16K r-x-- /usr/lib/libdatrie.so.1.4.0
00007f16285fb000 16K r---- /usr/lib/libarchive.so.13.7.1
00007f1628afe000 16K rw--- [ anon ]
00007f1628bbf000 16K r---- /usr/lib/libcurl.so.4.8.0
00007f1628c25000 16K r---- /usr/lib/liblzma.so.5.4.4
00007f1628e79000 16K r---- /usr/lib/libsqlite3.so.0.8.6
00007f1628e7d000 16K rw--- /usr/lib/libsqlite3.so.0.8.6
00007f1629012000 16K r---- /usr/lib/libgcc_s.so.1
00007f1629031000 16K r---- /usr/lib/libgcc_s.so.1
00007f1629037000 16K r---- /usr/lib/libexpat.so.1.8.10
00007f1629252000 16K r-x-- /usr/lib/libthai.so.0.3.1
00007f16292ee000 16K r---- /usr/lib/libsoup-3.0.so.0.7.0
00007f1629491000 16K r---- /usr/lib/libXext.so.6.4.0
00007f16294a0000 16K r---- /usr/lib/libXext.so.6.4.0
00007f1629785000 16K r---- /usr/lib/libpangoft2-1.0.so.0.5000.14
00007f16298ca000 16K rw--- /usr/lib/libX11.so.6.4.0
00007f1629c85000 16K r---- /usr/lib/libcairo.so.2.11708.0
00007f1629dfb000 16K r---- /usr/lib/libpango-1.0.so.0.5000.14
00007f162a04e000 16K rw--- [ anon ]
00007f162a277000 16K r---- /usr/lib/libadwaita-1.so.0
00007f162add8000 16K rw--- [ anon ]
00007f162addc000 16K r---- /usr/lib/libcairo-gobject.so.2.11708.0
00007fff53dd5000 16K r---- [ anon ]
00007f1615010000 20K r-x-- /usr/lib/libpciaccess.so.0.11.1
00007f16150fe000 20K r-x-- /usr/lib/libdrm_amdgpu.so.1.0.0
00007f161516c000 20K r---- /usr/lib/libdrm.so.2.4.0
00007f1616b3e000 20K r---- /usr/lib/libxfconf-0.so.3.0.0
00007f1616b4c000 20K r---- /usr/lib/libxfconf-0.so.3.0.0
00007f1616bb3000 20K r---- /usr/share/icons/hicolor/icon-theme.cache
00007f1616bb8000 20K r---- /usr/share/locale/de/LC_MESSAGES/libalpm.mo
00007f1617ff6000 20K r---- /usr/lib/libgcrypt.so.20.4.2
00007f162410e000 20K r---- /usr/lib/libflatpak.so.0.11504.0
00007f1627c90000 20K r---- /usr/lib/libpamac-flatpak.so.11.6
00007f1627ca7000 20K r-x-- /usr/lib/libcap.so.2.69
00007f16280ad000 20K r---- /usr/lib/libgpg-error.so.0.34.0
00007f162911c000 20K r-x-- /usr/lib/libxcb-render.so.0.0.0
00007f1629178000 20K r---- /usr/lib/libgraphite2.so.3.2.1
00007f162945e000 20K r---- /usr/lib/libcairo-script-interpreter.so.2.11708.0
00007f1629488000 20K r-x-- /usr/lib/libXcursor.so.1.0.2
00007f16294bd000 20K r---- /usr/lib/libxkbcommon.so.0.0.0
00007f162963f000 20K r---- /usr/lib/libtiff.so.6.0.1
00007f162976c000 20K r---- /usr/lib/libcloudproviders.so.0.3.1
00007f16298e5000 20K r---- /usr/lib/libgraphene-1.0.so.0.1000.8
00007f162a114000 20K r---- /usr/lib/libpamac.so.11.6
00007f162ade9000 20K r-x-- /usr/lib/libfribidi.so.0.4.0
00007f162ae09000 20K r---- /usr/lib/libpangocairo-1.0.so.0.5000.14
00007f1615125000 24K r-x-- /usr/lib/libdrm_radeon.so.1.0.1
00007f161518a000 24K r-x-- /usr/lib/libxcb-randr.so.0.1.0
00007f16154ee000 24K r--s- /var/cache/fontconfig/b67b32625a2bb51b023d3814a918f351-le64.cache-8
00007f1616b80000 24K r-x-- /usr/lib/gio/modules/libdconfsettings.so
00007f1616ba5000 24K r---- /usr/share/locale/de/LC_MESSAGES/gdk-pixbuf.mo
00007f1617d82000 24K r-x-- /usr/lib/libavahi-common.so.3.5.4
00007f1627d11000 24K r-x-- /usr/lib/libpamac-aur.so.11.6
00007f1627d89000 24K r---- /usr/lib/gvfs/libgvfscommon.so
00007f1628453000 24K r---- /usr/lib/libnghttp2.so.14.24.3
00007f1628bfd000 24K r---- /usr/lib/libblkid.so.1.1.0
00007f1629116000 24K r---- /usr/lib/libxcb-render.so.0.0.0
00007f16293cf000 24K r-x-- /usr/lib/libffi.so.8.1.2
00007f16294ab000 24K r---- /usr/lib/libwayland-client.so.0.22.0
00007f16294b1000 24K r-x-- /usr/lib/libwayland-client.so.0.22.0
00007f1629504000 24K r---- /usr/lib/libjpeg.so.8.3.2
00007f1629647000 24K r---- /usr/lib/libpng16.so.16.40.0
00007f1615134000 28K r-x-- /usr/lib/libsensors.so.5.0.0
00007f1615156000 28K r---- /usr/lib/libwayland-server.so.0.22.0
00007f1615183000 28K r---- /usr/lib/libxcb-randr.so.0.1.0
00007f1615274000 28K r-x-- /usr/lib/libgbm.so.1.0.0
00007f1617d8d000 28K r---- /usr/lib/libpolkit-gobject-1.so.0.0.0
00007f1617dae000 28K r-x-- /usr/lib/libmalcontent-0.so.0.11.1
00007f1625c7f000 28K r-x-- /usr/lib/libdconf.so.1.0.0
00007f1627db9000 28K r-x-- /usr/lib/libkrb5support.so.0.1
00007f1629152000 28K r-x-- /usr/lib/libXrender.so.1.3.0
00007f162943a000 28K r---- /usr/lib/libz.so.1.2.13
00007f1629443000 28K r---- /usr/lib/libcairo-script-interpreter.so.2.11708.0
00007f162946d000 28K r-x-- /usr/lib/libXrandr.so.2.2.0
00007f162975c000 28K r---- /usr/lib/libcloudproviders.so.0.3.1
00007f1629773000 28K r---- /usr/lib/libpangoft2-1.0.so.0.5000.14
00007f1629b04000 28K rw--- /usr/lib/libepoxy.so.0.0.0
00007f162add1000 28K rw--- [ anon ]
00007f162ae0e000 28K r-x-- /usr/lib/libpangocairo-1.0.so.0.5000.14
00007f162ae80000 28K r---- /usr/lib/libpamac-gtk.so
00007f15dbcb2000 32K rw--- /usr/lib/dri/iris_dri.so
00007f16147b4000 32K r---- /usr/share/locale/de/LC_MESSAGES/pamac.mo
00007f161515d000 32K r-x-- /usr/lib/libwayland-server.so.0.22.0
00007f1615331000 32K rw--- [ anon ]
00007f1616b2f000 32K r-x-- /usr/lib/libxfce4util.so.7.0.0
00007f1616bbd000 32K r---- /usr/share/locale/de_DE/LC_MESSAGES/pamac.mo
00007f1617da0000 32K r---- /usr/lib/libpolkit-gobject-1.so.0.0.0
00007f1625df6000 32K r---- /usr/lib/libappstream.so.0.16.2
00007f1627cd1000 32K r---- /usr/lib/libxmlb.so.2.0.0
00007f1627da1000 32K r-x-- /usr/lib/libresolv.so.2
00007f1628173000 32K r---- /usr/lib/libssh2.so.1.0.1
00007f16284d3000 32K r-x-- /usr/lib/libbrotlidec.so.1.0.9
00007f16284e0000 32K r---- /usr/lib/libgpgme.so.11.30.0
00007f1628bc8000 32K r---- /usr/lib/libblkid.so.1.1.0
00007f1629057000 32K r---- /usr/lib/libexpat.so.1.8.10
00007f1629108000 32K r---- /usr/lib/libpixman-1.so.0.42.2
00007f1629247000 32K r---- /usr/lib/libfreetype.so.6.20.0
00007f16292f3000 32K r---- /usr/lib/libalpm.so.13.0.2
00007f16295b0000 32K r---- /usr/lib/libtiff.so.6.0.1
00007f16298ce000 32K r---- /usr/lib/libgraphene-1.0.so.0.1000.8
00007f1629afc000 32K r---- /usr/lib/libepoxy.so.0.0.0
00007f1629b0b000 32K r---- /usr/lib/libfontconfig.so.1.13.0
00007f162a5f5000 32K r---- /usr/lib/libgio-2.0.so.0.7600.4
00007f162ae68000 32K r---- /usr/lib/libpamac-gtk.so
00007f1614bf7000 36K r---- /usr/share/locale/de/LC_MESSAGES/libgpg-error.mo
00007f1615090000 36K r---- /usr/lib/libedit.so.0.0.70
00007f161533c000 36K r-x-- /usr/lib/libEGL.so.1.1.0
00007f1616b43000 36K r-x-- /usr/lib/libxfconf-0.so.3.0.0
00007f1616b73000 36K r--s- /var/cache/fontconfig/f349e9996a5320f6dd491cedd2b1f964-le64.cache-8
00007f1617d70000 36K r-x-- /usr/lib/libavahi-client.so.3.2.9
00007f1627c95000 36K r-x-- /usr/lib/libpamac-flatpak.so.11.6
00007f1628fe7000 36K r---- /usr/lib/libjson-glib-1.0.so.0.600.6
00007f1629145000 36K r---- /usr/lib/libxcb.so.1.1.0
00007f1629763000 36K r-x-- /usr/lib/libcloudproviders.so.0.3.1
00007f162ae22000 36K r---- /usr/lib/libgdk_pixbuf-2.0.so.0.4200.10
00007f1614bdc000 40K rw-s- [ anon ]
00007f1614be6000 40K rw-s- [ anon ]
00007f16150e5000 40K r---- /usr/lib/libdrm_intel.so.1.0.0
00007f16151cf000 40K r---- /usr/lib/libEGL_mesa.so.0.0.0
00007f16280c7000 40K r---- /usr/lib/libgpg-error.so.0.34.0
00007f1628165000 40K r---- /usr/lib/libssl.so.3
00007f1628bf3000 40K r---- /usr/lib/libblkid.so.1.1.0
00007f1629006000 40K r---- /usr/lib/libjson-glib-1.0.so.0.600.6
00007f16293d8000 40K r---- /usr/lib/libmount.so.1.1.0
00007f1629675000 40K r---- /usr/lib/libpng16.so.16.40.0
00007f162ae92000 40K r---- /usr/lib/gio/modules/libgvfsdbus.so
00007f162aeb7000 40K r---- /usr/lib/gio/modules/libgvfsdbus.so
00007f162aeeb000 40K r---- /usr/lib/ld-linux-x86-64.so.2
00007f16241f0000 44K r---- /usr/lib/libsystemd.so.0.36.0
00007f1627cf6000 44K r---- /usr/lib/libxmlb.so.2.0.0
00007f162840e000 44K r-x-- /usr/lib/libassuan.so.0.8.6
00007f1628fda000 44K r---- /usr/lib/libxml2.so.2.11.4
00007f1629064000 44K r---- /usr/lib/libpixman-1.so.0.42.2
00007f1629495000 44K r-x-- /usr/lib/libXext.so.6.4.0
00007f162977a000 44K r-x-- /usr/lib/libpangoft2-1.0.so.0.5000.14
00007f1614bd0000 48K rw-s- [ anon ]
00007f1615171000 48K r-x-- /usr/lib/libdrm.so.2.4.0
00007f1617d94000 48K r-x-- /usr/lib/libpolkit-gobject-1.so.0.0.0
00007f1627d7d000 48K r---- /usr/lib/gvfs/libgvfscommon.so
00007f1627de9000 48K r---- /usr/lib/libk5crypto.so.3.1
00007f162846e000 48K r---- /usr/lib/libnghttp2.so.14.24.3
00007f162847e000 48K r---- /usr/lib/libgssapi_krb5.so.2.2
00007f16284c3000 48K r---- /usr/lib/libgssapi_krb5.so.2.2
00007f1628c4a000 48K r---- /usr/lib/liblzma.so.5.4.4
00007f1628c58000 48K r---- /usr/lib/libzstd.so.1.5.5
00007f1629125000 48K r---- /usr/lib/libxcb.so.1.1.0
00007f1629322000 48K r---- /usr/lib/libalpm.so.13.0.2
00007f1629c8c000 48K r---- /usr/lib/libharfbuzz.so.0.60811.0
00007f162a055000 48K r-x-- /usr/lib/libXi.so.6.1.0
0000555e9612b000 52K r---- /usr/bin/pamac-manager
00007f1615195000 52K r---- /usr/lib/libglapi.so.0.0.0
00007f1616b66000 52K r--s- /var/cache/fontconfig/210c0516121708a580e22e6b1f9a103a-le64.cache-8
00007f1617d12000 52K r---- /usr/lib/libsodium.so.23.3.0
00007f1624016000 52K r---- /usr/lib/libseccomp.so.2.5.4
00007f1625c69000 52K r---- /usr/lib/libstdc++.so.6.0.32
00007f1628439000 52K r-x-- /usr/lib/libbz2.so.1.0.8
00007f162a040000 52K rw--- [ anon ]
00007f1614ba8000 56K r---- /usr/lib/libGL.so.1.7.0
00007f16150b8000 56K r---- /usr/lib/libedit.so.0.0.70
00007f16151a2000 56K r-x-- /usr/lib/libglapi.so.0.0.0
00007f1617cc1000 56K r---- /usr/lib/libdbus-1.so.3.32.3
00007f1624008000 56K r-x-- /usr/lib/libseccomp.so.2.5.4
00007f1627d90000 56K rw--- [ anon ]
00007f1627ec0000 56K r---- /usr/lib/libkrb5.so.3.3
00007f16281ab000 56K r---- /usr/lib/libssh2.so.1.0.1
00007f1628b06000 56K r---- /usr/lib/libpsl.so.5.3.4
00007f1629182000 56K r---- /usr/lib/libfreetype.so.6.20.0
00007f162942c000 56K r-x-- /usr/lib/libz.so.1.2.13
00007f162974d000 56K r---- /usr/lib/libtracker-sparql-3.0.so.0.503.0
00007f1615206000 60K r---- /usr/lib/libEGL_mesa.so.0.0.0
00007f1616b54000 60K r--s- /var/cache/fontconfig/491f45a0a771fef1c10b9b647a97fb82-le64.cache-8
00007f1617eb8000 60K r---- /usr/lib/libgcrypt.so.20.4.2
00007f1629417000 60K r---- /usr/lib/libmount.so.1.1.0
00007f16298d6000 60K r-x-- /usr/lib/libgraphene-1.0.so.0.1000.8
00007f162a3c8000 60K r---- /usr/lib/libgobject-2.0.so.0.7600.4
00007f15fbe9f000 64K rw-s- [ anon ]
00007f1614007000 64K rw-s- [ anon ]
00007f16146f9000 64K rw-s- [ anon ]
00007f1614714000 64K rw-s- [ anon ]
00007f16147bc000 64K rw-s- [ anon ]
00007f1614b22000 64K rw--- [ anon ]
00007f1614f8d000 64K rw-s- [ anon ]
00007f1614f9d000 64K rw-s- [ anon ]
00007f161524c000 64K rw-s- [ anon ]
00007f1615359000 64K rw-s- [ anon ]
00007f1615369000 64K rw-s- [ anon ]
00007f1615379000 64K rw-s- [ anon ]
00007f1615389000 64K rw-s- [ anon ]
00007f1615399000 64K rw-s- [ anon ]
00007f16153a9000 64K rw-s- [ anon ]
00007f16153b9000 64K rw-s- [ anon ]
00007f1615427000 64K rw-s- [ anon ]
00007f1615437000 64K rw-s- [ anon ]
00007f1615447000 64K rw-s- [ anon ]
00007f1628536000 64K r---- /usr/lib/libarchive.so.13.7.1
00007f1628b16000 64K r---- /usr/lib/libcurl.so.4.8.0
00007f16298ed000 64K r---- /usr/lib/libm.so.6
00007f162ae70000 64K r-x-- /usr/lib/libpamac-gtk.so
00007f1628d2d000 68K r---- /usr/lib/libsqlite3.so.0.8.6
00007f162ae54000 68K r---- /usr/lib/libgdk_pixbuf-2.0.so.0.4200.10
00007f161510b000 72K r-x-- /usr/lib/libelf-0.189.so
00007f1617cfd000 72K r---- /usr/lib/libdbus-1.so.3.32.3
00007f1617d58000 72K r---- /usr/lib/libsodium.so.23.3.0
00007f1627ef3000 72K r---- /usr/lib/libunistring.so.5.0.0
00007f16290f6000 72K r---- /usr/lib/libpixman-1.so.0.42.2
00007f1615301000 76K r---- /usr/lib/libGLdispatch.so.0.0.0
00007f1625cf1000 76K r---- /usr/lib/libstemmer.so.0.0.0
00007f1627d53000 76K r---- /usr/lib/gvfs/libgvfscommon.so
00007f16283f2000 76K r---- /usr/lib/libicuuc.so.73.2
00007f1628520000 76K r---- /usr/lib/libgpgme.so.11.30.0
00007f1629b5a000 76K r---- /usr/lib/libcairo.so.2.11708.0
00007f1629d97000 76K r---- /usr/lib/libpango-1.0.so.0.5000.14
00007f16169e8000 80K r--s- /var/cache/fontconfig/614d1caaa4d7914789410f6367de37ca-le64.cache-8
00007f1628d15000 80K r---- /usr/lib/libzstd.so.1.5.5
00007f1629131000 80K r-x-- /usr/lib/libxcb.so.1.1.0
00007f162944a000 80K r-x-- /usr/lib/libcairo-script-interpreter.so.2.11708.0
00007f1614b93000 84K r---- /usr/lib/libGL.so.1.7.0
00007f16280b2000 84K r-x-- /usr/lib/libgpg-error.so.0.34.0
00007f1628459000 84K r-x-- /usr/lib/libnghttp2.so.14.24.3
00007f1615019000 88K r---- /usr/lib/libncursesw.so.6.4
00007f16150cf000 88K r-x-- /usr/lib/libdrm_intel.so.1.0.0
00007f1628ff0000 88K r-x-- /usr/lib/libjson-glib-1.0.so.0.600.6
0000555e9615e000 92K r---- /usr/bin/pamac-manager
00007f1624115000 92K r---- /usr/lib/libsystemd.so.0.36.0
00007f1627d66000 92K r-x-- /usr/lib/gvfs/libgvfscommon.so
00007f1629b40000 92K r---- /usr/lib/libfontconfig.so.1.13.0
00007f162adee000 92K r---- /usr/lib/libfribidi.so.0.4.0
00007f1615073000 96K r---- /usr/lib/libncursesw.so.6.4
00007f1615234000 96K rw-s- /memfd:wayland-cursor (deleted)
00007f1624025000 96K r---- /usr/lib/libflatpak.so.0.11504.0
00007f1629160000 96K r-x-- /usr/lib/libgraphite2.so.3.2.1
00007f16151b0000 100K r---- /usr/lib/libglapi.so.0.0.0
00007f16153fd000 100K r---- /usr/share/locale/de/LC_MESSAGES/gtk40.mo
00007f1616b8b000 100K r---- /usr/share/glib-2.0/schemas/gschemas.compiled
00007f1617dbb000 100K r---- /usr/lib/libostree-1.so.1.0.0
00007f1627cb2000 100K r-x-- /usr/lib/libyaml-0.so.2.0.9
00007f1628c07000 100K r-x-- /usr/lib/liblzo2.so.2.0.0
00007f1629681000 100K r---- /usr/lib/libtracker-sparql-3.0.so.0.503.0
00007f162a066000 100K r---- /usr/lib/libpamac.so.11.6
00007f1614b03000 104K r-x-- /usr/lib/libGLX.so.0.0.0
00007f16281c2000 104K r---- /usr/lib/libidn2.so.0.3.8
00007f162925b000 104K r---- /usr/lib/libsoup-3.0.so.0.7.0
00007f162a40c000 104K r---- /usr/lib/libgobject-2.0.so.0.7600.4
00007f1627dce000 108K r-x-- /usr/lib/libk5crypto.so.3.1
00007f16281e1000 108K r-x-- /usr/lib/liblz4.so.1.9.4
00007f1629016000 108K r-x-- /usr/lib/libgcc_s.so.1
00007f1629de0000 108K r---- /usr/lib/libpango-1.0.so.0.5000.14
00007f162ae9c000 108K r-x-- /usr/lib/gio/modules/libgvfsdbus.so
00007f1615314000 112K r---- /usr/lib/libGLdispatch.so.0.0.0
00007f1628149000 112K r---- /usr/lib/libssl.so.3
00007f162903b000 112K r-x-- /usr/lib/libexpat.so.1.8.10
00007f162978b000 112K r---- /usr/lib/libX11.so.6.4.0
00007f162ac3a000 112K r---- /usr/lib/libgtk-4.so.1.1000.5
00007f1627cd9000 116K r-x-- /usr/lib/libxmlb.so.2.0.0
00007f16280d3000 120K r---- /usr/lib/libssl.so.3
00007f1628ba1000 120K r---- /usr/lib/libcurl.so.4.8.0
00007f16294c2000 120K r-x-- /usr/lib/libxkbcommon.so.0.0.0
00007f162a27d000 120K r---- /usr/lib/libglib-2.0.so.0.7600.4
00007f1614b74000 124K r-x-- /usr/lib/libGL.so.1.7.0
00007f1615099000 124K r-x-- /usr/lib/libedit.so.0.0.70
00007f1627ed2000 124K r---- /usr/lib/libbrotlicommon.so.1.0.9
00007f15a4000000 132K rw--- [ anon ]
00007f15a8000000 132K rw--- [ anon ]
00007f15ac000000 132K rw--- [ anon ]
00007f15b0000000 132K rw--- [ anon ]
00007f15b4000000 132K rw--- [ anon ]
00007f15bc000000 132K rw--- [ anon ]
00007f15c0000000 132K rw--- [ anon ]
00007f15d4000000 132K rw--- [ anon ]
00007f15dc000000 132K rw--- [ anon ]
00007f15e0000000 132K rw--- [ anon ]
00007f15e4000000 132K rw--- [ anon ]
00007f15e8000000 132K rw--- [ anon ]
00007f15f0000000 132K rw--- [ anon ]
00007f1600000000 132K rw--- [ anon ]
00007f161c000000 132K rw--- [ anon ]
00007f1620000000 132K rw--- [ anon ]
00007f1625d57000 132K r---- /usr/lib/libappstream.so.0.16.2
00007f1628c29000 132K r-x-- /usr/lib/liblzma.so.5.4.4
00007f16294e0000 132K r---- /usr/lib/libxkbcommon.so.0.0.0
00007f1617fff000 136K rw--- [ anon ]
00007f162a11a000 136K r---- /usr/lib/libadwaita-1.so.0
00007f1616beb000 140K r---- /usr/share/locale/de/LC_MESSAGES/glib20.mo
00007f1627df8000 140K r---- /usr/lib/libkrb5.so.3.3
00007f1628bd0000 140K r-x-- /usr/lib/libblkid.so.1.1.0
00007f162a0f0000 144K r---- /usr/lib/libpamac.so.11.6
00007f1625ccc000 148K r-x-- /usr/lib/libstemmer.so.0.0.0
0000555e96138000 152K r-x-- /usr/bin/pamac-manager
00007f161549e000 152K r--s- /var/cache/fontconfig/f2e43df3287529323e79e7929dc44cc9-le64.cache-8
00007f1616bc5000 152K r---- /usr/share/locale/de/LC_MESSAGES/libc.mo
00007f16292c8000 152K r---- /usr/lib/libsoup-3.0.so.0.7.0
00007f1629e00000 152K r---- /usr/lib/libc.so.6
00007f162aec5000 152K r-x-- /usr/lib/ld-linux-x86-64.so.2
00007f16285d4000 156K r---- /usr/lib/libarchive.so.13.7.1
00007f16292fb000 156K r-x-- /usr/lib/libalpm.so.13.0.2
00007f162964d000 160K r-x-- /usr/lib/libpng16.so.16.40.0
00007f1627d2a000 164K r--s- /usr/share/mime/mime.cache
00007f162ae2b000 164K r-x-- /usr/lib/libgdk_pixbuf-2.0.so.0.4200.10
00007f16154c4000 168K r--s- /var/cache/fontconfig/8d4af663993b81a124ee82e610bb31f9-le64.cache-8
00007f162921d000 168K r---- /usr/lib/libfreetype.so.6.20.0
00007f162939e000 172K r---- /usr/lib/libpcre2-8.so.0.11.2
00007f16151d9000 180K r-x-- /usr/lib/libEGL_mesa.so.0.0.0
00007f1629b13000 180K r-x-- /usr/lib/libfontconfig.so.1.13.0
00007f1617ccf000 184K r-x-- /usr/lib/libdbus-1.so.3.32.3
00007f1625dc8000 184K r---- /usr/lib/libappstream.so.0.16.2
00007f162817b000 192K r-x-- /usr/lib/libssh2.so.1.0.1
00007f159c000000 196K rw--- [ anon ]
00007f16153cc000 196K r---- /usr/share/icons/Papirus-Dark-Maia/icon-theme.cache
00007f162960e000 196K r---- /usr/lib/libtiff.so.6.0.1
00007f16240dc000 200K r---- /usr/lib/libflatpak.so.0.11504.0
00007f1628e81000 200K r---- /usr/lib/libxml2.so.2.11.4
00007f16241bb000 212K r---- /usr/lib/libsystemd.so.0.36.0
00007f1628e44000 212K r---- /usr/lib/libsqlite3.so.0.8.6
00007f16293e2000 212K r-x-- /usr/lib/libmount.so.1.1.0
00007f162a3d7000 212K r-x-- /usr/lib/libgobject-2.0.so.0.7600.4
00007f1629d5f000 216K r---- /usr/lib/libharfbuzz.so.0.60811.0
00007f1629daa000 216K r-x-- /usr/lib/libpango-1.0.so.0.5000.14
00007f1629716000 220K r---- /usr/lib/libtracker-sparql-3.0.so.0.503.0
00007f1629c4e000 220K r---- /usr/lib/libcairo.so.2.11708.0
00007f16284e8000 224K r-x-- /usr/lib/libgpgme.so.11.30.0
00007f1629576000 224K r---- /usr/lib/libjpeg.so.8.3.2
00007f1617d1f000 228K r-x-- /usr/lib/libsodium.so.23.3.0
00007f1617e7b000 228K r---- /usr/lib/libostree-1.so.1.0.0
00007f162848a000 228K r-x-- /usr/lib/libgssapi_krb5.so.2.2
00007f162a42a000 228K r---- /usr/lib/libgio-2.0.so.0.7600.4
00007f1627e82000 248K r---- /usr/lib/libkrb5.so.3.3
00007f16152c2000 252K r-x-- /usr/lib/libGLdispatch.so.0.0.0
00007f1617fb7000 252K r---- /usr/lib/libgcrypt.so.20.4.2
00007f1614fcd000 256K rw-s- [ anon ]
00007f1625c8c000 256K r---- /usr/lib/libstemmer.so.0.0.0
00007f1615281000 260K r---- /usr/lib/libGLdispatch.so.0.0.0
00007f1627f05000 260K r-x-- /usr/lib/libunistring.so.5.0.0
00007f1614b32000 264K r---- /usr/lib/libGL.so.1.7.0
00007f161502f000 272K r-x-- /usr/lib/libncursesw.so.6.4
00007f15d3dff000 284K rw--- /usr/lib/libLLVM-15.so
00007f1614231000 284K r---- /usr/share/fonts/TTF/Roboto-Bold.ttf
00007f1614278000 284K r---- /usr/share/fonts/TTF/Roboto-Bold.ttf
00007f1615457000 284K rw--- [ anon ]
00007f1614724000 288K r---- /usr/share/fonts/TTF/Roboto-Regular.ttf
00007f161476c000 288K r---- /usr/share/fonts/TTF/Roboto-Regular.ttf
00007f1628f91000 292K r---- /usr/lib/libxml2.so.2.11.4
00007f1625d78000 320K r-x-- /usr/lib/libappstream.so.0.16.2
00007f1625d04000 328K r---- /usr/lib/libstemmer.so.0.0.0
00007f1629275000 332K r-x-- /usr/lib/libsoup-3.0.so.0.7.0
00007f1629f85000 340K r---- /usr/lib/libc.so.6
00007f16295b8000 344K r-x-- /usr/lib/libtiff.so.6.0.1
00007f16280f1000 352K r-x-- /usr/lib/libssl.so.3
00007f1628a9c000 364K r---- /usr/lib/libcrypto.so.3
00007f162997c000 368K r---- /usr/lib/libm.so.6
00007f1629a9f000 372K r---- /usr/lib/libepoxy.so.0.0.0
00007f16299da000 380K r---- /usr/lib/libepoxy.so.0.0.0
00007f1629fda000 400K r---- /usr/lib/libc.so.6
00007f1628200000 404K r---- /usr/lib/libicuuc.so.73.2
00007f1629a39000 408K r-x-- /usr/lib/libepoxy.so.0.0.0
00007f1627e1b000 412K r-x-- /usr/lib/libkrb5.so.3.3
00007f1629333000 428K r-x-- /usr/lib/libpcre2-8.so.0.11.2
00007f162950a000 432K r-x-- /usr/lib/libjpeg.so.8.3.2
00007f162a13c000 440K r-x-- /usr/lib/libadwaita-1.so.0
00007f162a07f000 452K r-x-- /usr/lib/libpamac.so.11.6
00007f15fbde9000 468K r---- /usr/lib/librsvg-2.so.2.48.0
00007f15d3e46000 480K rw--- [ anon ]
00007f1628b26000 492K r-x-- /usr/lib/libcurl.so.4.8.0
00007f162969a000 496K r-x-- /usr/lib/libtracker-sparql-3.0.so.0.503.0
00007f16298fd000 508K r-x-- /usr/lib/libm.so.6
00007f162a571000 528K r---- /usr/lib/libgio-2.0.so.0.7600.4
00007f15dbc2c000 536K r---- /usr/lib/dri/iris_dri.so
00007f162906f000 540K r-x-- /usr/lib/libpixman-1.so.0.42.2
00007f16297a7000 556K r-x-- /usr/lib/libX11.so.6.4.0
00007f15d9e00000 560K r---- /usr/lib/dri/iris_dri.so
00007f1629190000 564K r-x-- /usr/lib/libfreetype.so.6.20.0
00007f162a338000 564K r---- /usr/lib/libglib-2.0.so.0.7600.4
00007f1628546000 568K r-x-- /usr/lib/libarchive.so.13.7.1
00007f15fba00000 572K r---- /usr/lib/librsvg-2.so.2.48.0
00007f162412c000 572K r-x-- /usr/lib/libsystemd.so.0.36.0
00007f1628362000 576K r---- /usr/lib/libicuuc.so.73.2
00007f1629832000 596K r---- /usr/lib/libX11.so.6.4.0
00007f1625bd3000 600K r---- /usr/lib/libstdc++.so.6.0.32
00007f16169fc000 604K r--s- /var/cache/fontconfig/17090aa38d5c6f09fb8c5c354938f1d7-le64.cache-8
00007f1616a93000 608K r--s- /var/cache/fontconfig/df311e82a1a24c41a75c2c930223552e-le64.cache-8
00007f1625a00000 624K r---- /usr/lib/libstdc++.so.6.0.32
00007f162a29b000 628K r-x-- /usr/lib/libglib-2.0.so.0.7600.4
00007f162403d000 636K r-x-- /usr/lib/libflatpak.so.0.11504.0
00007f162a600000 644K r---- /usr/lib/libgtk-4.so.1.1000.5
00007f1617dd4000 668K r-x-- /usr/lib/libostree-1.so.1.0.0
00007f1617c10000 708K r--s- /home/user/.local/share/mime/mime.cache
00007f1628600000 708K r---- /usr/lib/libcrypto.so.3
00007f1628c64000 708K r-x-- /usr/lib/libzstd.so.1.5.5
00007f1594000000 720K rw--- [ anon ]
00007f1598000000 740K rw--- [ anon ]
00007f15a0000000 740K rw--- [ anon ]
00007f1629c98000 796K r-x-- /usr/lib/libharfbuzz.so.0.60811.0
00007f162a1aa000 820K r---- /usr/lib/libadwaita-1.so.0
00007f16289ca000 840K r---- /usr/lib/libcrypto.so.3
00007fff53ccf000 844K rw--- [ stack ]
00007f1628eb3000 888K r-x-- /usr/lib/libxml2.so.2.11.4
00007f1629b6d000 900K r-x-- /usr/lib/libcairo.so.2.11708.0
00007f1617ec7000 960K r-x-- /usr/lib/libgcrypt.so.20.4.2
00007f1628265000 1012K r-x-- /usr/lib/libicuuc.so.73.2
00007f15fa0fc000 1028K rw--- [ anon ]
00007f15fb27f000 1028K rw--- [ anon ]
00007f1628d3e000 1048K r-x-- /usr/lib/libsqlite3.so.0.8.6
00007f16154f4000 1064K r--s- /var/cache/fontconfig/f6b893a7224233d96cb72fd88691c0b4-le64.cache-8
00007f162a463000 1080K r-x-- /usr/lib/libgio-2.0.so.0.7600.4
00007f15fbccd000 1136K r---- /usr/lib/librsvg-2.so.2.48.0
00007f1625a9c000 1244K r-x-- /usr/lib/libstdc++.so.6.0.32
00007f15f80b9000 1280K rw-s- [ anon ]
00007f15fbebf000 1280K rw-s- [ anon ]
00007f15fec80000 1280K rw-s- [ anon ]
00007f15fedc0000 1280K rw-s- [ anon ]
00007f15fef00000 1280K rw-s- [ anon ]
00007f15ff040000 1280K rw-s- [ anon ]
00007f15ff180000 1280K rw-s- [ anon ]
00007f15ff2c0000 1280K rw-s- [ anon ]
00007f16142bf000 1284K rw-s- /home/user/.cache/mesa_shader_cache/index
00007f1629e26000 1404K r-x-- /usr/lib/libc.so.6
00007f1627f46000 1416K r---- /usr/lib/libunistring.so.5.0.0
00007f162ac56000 1516K rw--- /usr/lib/libgtk-4.so.1.1000.5
00007f15ff400000 1536K rw-s- [ anon ]
00007f15ff580000 1536K rw-s- [ anon ]
00007f162aa9c000 1656K r---- /usr/lib/libgtk-4.so.1.1000.5
00007f15dbcba000 1784K rw--- [ anon ]
00007f15c4409000 2016K r---- /usr/share/fonts/TTF/JetBrainsMonoNerdFont-Regular.ttf
00007f15c4601000 2016K r---- /usr/share/fonts/TTF/JetBrainsMonoNerdFont-Regular.ttf
00007f15d817d000 2048K rw-s- [ anon ]
00007f15fb380000 2048K rw-s- [ anon ]
00007f15fea80000 2048K rw-s- [ anon ]
00007f15ff700000 2048K rw-s- [ anon ]
00007f15ff900000 2048K rw-s- [ anon ]
00007f1614031000 2048K rw-s- [ anon ]
00007f15fba8f000 2296K r-x-- /usr/lib/librsvg-2.so.2.48.0
00007f15ffb00000 2560K rw-s- [ anon ]
00007f15ffd80000 2560K rw-s- [ anon ]
00007f1614400000 2944K r---- /usr/share/icons/Papirus/icon-theme.cache
00007f1614800000 2944K r---- /usr/share/icons/Papirus-Dark/icon-theme.cache
00007f16286b1000 3172K r-x-- /usr/lib/libcrypto.so.3
00007f1614c00000 3612K r--s- /var/cache/fontconfig/923e285e415b1073c8df160bee08820f-le64.cache-8
00007f1616600000 3984K r---- /usr/lib/locale/locale-archive
00007f162a6a1000 4076K r-x-- /usr/lib/libgtk-4.so.1.1000.5
00007f15cc000000 4096K rw-s- [ anon ]
00007f15d3794000 6572K r---- /usr/lib/libLLVM-15.so
00007f15c57fc000 8192K rw--- [ anon ]
00007f15c5ffd000 8192K rw--- [ anon ]
00007f15c67fe000 8192K rw--- [ anon ]
00007f15c6fff000 8192K rw--- [ anon ]
00007f15d85fe000 8192K rw--- [ anon ]
00007f15d8dff000 8192K rw--- [ anon ]
00007f15d9600000 8192K rw--- [ anon ]
00007f15f81fa000 8192K rw--- [ anon ]
00007f15f89fb000 8192K rw--- [ anon ]
00007f16155ff000 8192K rw--- [ anon ]
00007f1615e00000 8192K rw--- [ anon ]
00007f1616c0f000 8192K rw--- [ anon ]
00007f1617410000 8192K rw--- [ anon ]
00007f16241fe000 8192K rw--- [ anon ]
00007f16249ff000 8192K rw--- [ anon ]
00007f1625200000 8192K rw--- [ anon ]
00007f15c7800000 8324K rw--- [ anon ]
00007f15db1cf000 10612K r---- /usr/lib/dri/iris_dri.so
00007f15cc600000 11148K r---- /usr/lib/libLLVM-15.so
00007f160c000000 13636K rw--- [ anon ]
00007f157c000000 17352K rw--- [ anon ]
00007f15d9e8c000 19724K r-x-- /usr/lib/dri/iris_dri.so
00007f158ab6c000 21072K ----- [ anon ]
00007f1625e00000 31284K r---- /usr/lib/libicudata.so.73.2
00007f15d0f3d000 41308K r---- /usr/lib/libLLVM-15.so
00007f157d0f2000 48184K ----- [ anon ]
00007f160cd51000 51900K ----- [ anon ]
00007f15cd0e3000 63848K r-x-- /usr/lib/libLLVM-15.so
00007f15980b9000 64796K ----- [ anon ]
00007f15a00b9000 64796K ----- [ anon ]
00007f15940b4000 64816K ----- [ anon ]
00007f159c031000 65340K ----- [ anon ]
00007f15a4021000 65404K ----- [ anon ]
00007f15a8021000 65404K ----- [ anon ]
00007f15ac021000 65404K ----- [ anon ]
00007f15b0021000 65404K ----- [ anon ]
00007f15b4021000 65404K ----- [ anon ]
00007f15bc021000 65404K ----- [ anon ]
00007f15c0021000 65404K ----- [ anon ]
00007f15c8021000 65404K ----- [ anon ]
00007f15d4021000 65404K ----- [ anon ]
00007f15dc021000 65404K ----- [ anon ]
00007f15e0021000 65404K ----- [ anon ]
00007f15e4021000 65404K ----- [ anon ]
00007f15e8021000 65404K ----- [ anon ]
00007f15f0021000 65404K ----- [ anon ]
00007f1600021000 65404K ----- [ anon ]
00007f1618021000 65404K ----- [ anon ]
00007f161c021000 65404K ----- [ anon ]
00007f1620021000 65404K ----- [ anon ]
00007f15ec000000 65536K rw--- [ anon ]
00007f15f4000000 65536K rw--- [ anon ]
00007f1604000000 65536K rw--- [ anon ]
00007f1608000000 65536K rw--- [ anon ]
00007f1610000000 65536K rw--- [ anon ]
00007f1584000000 110000K rw--- [ anon ]
0000555e9767f000 130164K rw--- [ anon ]
00007f158c000000 131072K rw--- [ anon ]
gesamt 2755216K
So you see anything relevant? From what I see: GTK4 uses here GPU accelearation (OpenGL) and therefore needs more RAM for caching.
The AUR database is really large and loading it requires a lot of memory. Made you’re experiencing this?
I have aur enabled, but octopi uses the same database and still…160 mb.
I am on xfce if that matters.
Does it really use the manjaro-hosted file or the API directly?
It seems so…
No I dont think so.
It has AUR support - but not manjaro’s specific db cache that was made for the expressed purpose of helping pamac not DDOS the AUR.
(because there just wasnt any other way? … heh … idk … pamac so silly)
For what its worth … I just checked and pamac-gtk seemed to use about 178 mb.
Enabling the AUR in itself in Pamac will make use of lot of RAM.
