Pamac GUI often gets stuck on “Refreshing AUR”
Hi,
I occasionally encounter an issue with pamac-manager (GUI) on Manjaro where the interface gets stuck while performing an AUR update check. This seems intermittent, and I do not know how to reproduce consistently.
Symptoms:
  • GUI shows “Refreshing AUR” indefinitely.
  • Status bar remains stuck on “Check Updates”.
  • Logs are inaccessible in the GUI.
  • The pamac GUI says “up-to-date” even when updates are available (e.g., firefox 146.0-1 -> 146.0.1-1).
  • CLI commands work correctly (pamac checkupdates --aur)
ps aux | grep pamac
jorgecpd    2436  0.0  0.0 838360 19160 ?        Ssl  dez18   0:00 /usr/bin/pamac-tray-plasma
jorgecpd  999486  0.0  0.4 3126620 139960 ?      Ssl  dez22   0:57 /usr/bin/pamac-manager --gapplication-service
jorgecpd 2096616  0.0  0.0   6764  4200 pts/1    S+   16:38   0:00 grep pamac
ls -l /var/lib/pacman/db.lck
ls: cannot access '/var/lib/pacman/db.lck': No such file or directory
1 available update:
firefox  146.0-1 -> 146.0.1-1  extra
dbus-monitor --session "sender='org.manjaro.pamac'"
signal time=1766594606.835642 sender=org.freedesktop.DBus -> destination=:1.1540 serial=4294967295 path=/org/freedesktop/DBus; interface=org.freedesktop.DBus; member=NameAcquired
   string ":1.1540"
signal time=1766594606.835662 sender=org.freedesktop.DBus -> destination=:1.1540 serial=4294967295 path=/org/freedesktop/DBus; interface=org.freedesktop.DBus; member=NameLost
   string ":1.1540"
sudo strace -f -e poll,epoll_wait,futex -p $(pgrep -f pamac-manager)
[pid 999497] futex(0x7f695b42ab00, FUTEX_WAIT_BITSET_PRIVATE, 2, NULL, FUTEX_BITSET_MATCH_ANY <unfinished ...>
[pid 999492] futex(0x558b2ed187d0, FUTEX_WAIT_PRIVATE, 1, NULL <unfinished ...>
[pid 999491] futex(0x558b2c7925b0, FUTEX_WAIT_PRIVATE, 8, NULL
sudo gdb -p $(pgrep -f pamac-manager)
info threads
  Id   Target Id                                            Frame
* 1    Thread 0x7f6959692080 (LWP 999486) "pamac-manager"   0x00007f695be9f002 in ?? () from /usr/lib/libc.so.6
  2    Thread 0x7f693f38a6c0 (LWP 999497) "async-io"        0x00007f695bf1872d in syscall () from /usr/lib/libc.so.6
  3    Thread 0x7f693f58b6c0 (LWP 999496) "gly-global-exec" 0x00007f695b178bb3 in ?? () from /usr/lib/libglycin-2.so.0
  4    Thread 0x7f693ffff6c0 (LWP 999495) "dconf worker"    0x00007f695be9f002 in ?? () from /usr/lib/libc.so.6
  5    Thread 0x7f69553ac6c0 (LWP 999493) "gdbus"           0x00007f695be9f002 in ?? () from /usr/lib/libc.so.6
  6    Thread 0x7f6955bad6c0 (LWP 999492) "pool-spawner"    0x00007f695bf1872d in syscall () from /usr/lib/libc.so.6
  7    Thread 0x7f69563de6c0 (LWP 999491) "[pango] fontcon" 0x00007f695bf1872d in syscall () from /usr/lib/libc.so.6
  8    Thread 0x7f6956f286c0 (LWP 999490) "gmain"           0x00007f695be9f002 in ?? () from /usr/lib/libc.so.6
  • All GUI threads exist but are stuck in futex waits.
  • CLI backend works correctly, so this appears to be a frontend-only issue.
  • No debug symbols are available in the shipped package, so backtraces cannot resolve to Vala functions.
inxi -zv8
  Kernel: 6.18.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=67c4e3fb-311e-4604-9383-d9cc274cf0fa rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
  Mobo: ASUSTeK model: ROG CROSSHAIR VIII FORMULA v: Rev X.0x
    Firmware: UEFI vendor: American Megatrends v: 5002 date: 01/13/2025
  ID-1: hidpp_battery_0 charge: 8% condition: N/A volts: 3.66 min: N/A
    model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
    serial: <filter> charging: status: discharging cycles: N/A
  System RAM: total: 32 GiB available: 31.25 GiB used: 21.5 GiB (68.8%)
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: G Skill Intl
    part-no: F4-3200C14-8GFX serial: N/A
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201030
    desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3786 min/max: 556/4854 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3786 2: 3786 3: 3786
    4: 3786 5: 3786 6: 3786 7: 3786 8: 3786 9: 3786 10: 3786 11: 3786 12: 3786
    13: 3786 14: 3786 15: 3786 16: 3786 bogomips: 121605
    xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
    XTX/7900 GRE/7900M] vendor: ASUSTeK TUF Gaming driver: amdgpu v: kernel
    arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1
    empty: DP-2,DP-3,Writeback-1 bus-ID: 0d:00.0 chip-ID: 1002:744c
    class-ID: 0300
  Device-2: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.2.2:7
    chip-ID: 046d:085b class-ID: 0102 serial: <filter>
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 5760x2160 display-ID: 0
  Monitor-1: DP-1 pos: right model: LG (GoldStar) 27GN950 serial: <filter>
    built: 2021 res: mode: 3840x2160 hz: 120 scale: 170% (1.7) to: 2259x1271
    dpi: 163 gamma: 1.2 chroma: red: x: 0.682 y: 0.314 green: x: 0.267
    y: 0.686 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
    size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
    modes: 3840x2160, 1920x1080, 1280x720, 1024x768, 800x600, 720x480,
    640x480
  EDID-Errors: 1: bad sync value: bad horizontal values: min: 30 max: 15
  EDID-Warnings: 1: parse_edid: unknown tag 112
  Monitor-2: HDMI-A-1 pos: primary,left model: Idek Iiyama PLE2607WS
    serial: <filter> built: 2008 res: mode: 1920x1200 hz: 60 scale: 160% (1.6)
    to: 1200x1920 dpi: 89 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green:
    x: 0.282 y: 0.600 blue: x: 0.149 y: 0.071 white: x: 0.314 y: 0.329
    size: 550x344mm (21.65x13.54") diag: 649mm (25.5") ratio: 16:10
    modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
    1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
    640x480, 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XTX (radeonsi
    navi31 LLVM 21.1.6 DRM 3.64 6.18.2-1-MANJARO) device-ID: 1002:744c
    memory: 23.44 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.335 layers: 2 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 25.3.1-arch1.2
    device-ID: 1002:744c surfaces: N/A
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 0d:00.1 chip-ID: 1002:ab30 class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.18.2-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
  Device-1: Aquantia AQC111 NBase-T/IEEE 802.3bz Ethernet [AQtion]
    vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 1 link-max: lanes: 4 port: N/A bus-ID: 05:00.0 chip-ID: 1d6a:11b1
    class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
  IF: enp6s0 state: down mac: <filter>
  Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp7s0 state: down mac: <filter>
  IF-ID-1: br-466c45b29e42 state: down mac: <filter>
  IF-ID-2: docker0 state: down mac: <filter>
  IF-ID-3: wg0-mullvad state: unknown speed: 10000 Mbps duplex: full
    mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 8087:0029
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0104
  Device-2: Microsoft Nano Transceiver v1.0 for Bluetooth
    driver: hid-generic,usbhid type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 3-3.1:5 chip-ID: 045e:0745 class-ID: 0300
  Local Storage: total: 8.3 TiB used: 1.73 TiB (20.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 990 PRO 4TB
    size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 50.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 49.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 830 Series
    size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 3B1Q scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 QVO 1TB
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE WH14NS40 rev: 1.05
    dev-links: cdrom
  Features: speed: 40 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 2.59 TiB size: 2.59 TiB (100.00%) used: 184.85 GiB (7.0%)
    fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:4 label: Manjaro root
    uuid: 67c4e3fb-311e-4604-9383-d9cc274cf0fa
    used: 32.1 MiB (6.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2 label: EFI
    uuid: 5BFB-F55D
  ID-3: /home raw-size: 3.49 TiB size: 3.44 TiB (98.40%)
    used: 1.52 TiB (44.1%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:6
    label: Home uuid: 1763d5a3-375c-4e17-a4cf-f96bde772b42
  ID-4: /var/cache raw-size: 2.59 TiB size: 2.59 TiB (100.00%)
    used: 184.85 GiB (7.0%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:4
    label: Manjaro root uuid: 67c4e3fb-311e-4604-9383-d9cc274cf0fa
  ID-5: /var/log raw-size: 2.59 TiB size: 2.59 TiB (100.00%)
  ID-1: swap-1 type: partition size: 63.5 GiB used: 30.33 GiB (47.8%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:3 label: Swap
    uuid: 2fb0f355-cde7-4eb9-9259-9822d28c5af2
  ID-1: /dev/nvme0n1p4 maj-min: 259:5 size: 1013.73 GiB fs: btrfs label: N/A
    uuid: 2012bb20-12df-40ac-a630-2ed115853dc0
  ID-2: /dev/nvme1n1p2 maj-min: 259:7 size: 150 GiB fs: btrfs
    label: snapshots backup syst\xc3\xa8me
    uuid: e51dc2b8-8026-4865-99e5-09216373f6af
  ID-3: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-4: /dev/sda2 maj-min: 8:2 size: 118.5 GiB fs: ntfs label: N/A
    uuid: 648AA69E8AA66C6C
  ID-5: /dev/sda3 maj-min: 8:3 size: 743 MiB fs: ntfs label: N/A
    uuid: FADE7F8FDE7F4345
  ID-6: /dev/sdb1 maj-min: 8:17 size: 868 MiB fs: vfat label: N/A
    uuid: A567-7EF7
  ID-7: /dev/sdb2 maj-min: 8:18 size: 930.66 GiB fs: ext4 label: N/A
    uuid: f18e7382-b9e7-4ab1-84ec-8fc5127f31d3
  Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-5.3:4 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
    serial: <filter>
  Device-2: 1-5.4:5 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:1872 class-ID: 0300
    serial: <filter>
  Device-3: 1-6:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Hub-5: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 3-2.1:4 info: Advanced Card Systems ACR38 SmartCard Reader
    type: smart card driver: N/A interfaces: 1 rev: 1.1
    chip-ID: 072f:90cc class-ID: 0b00
  Hub-6: 3-2.2:6 info: Texas Instruments TUSB8041 4-Port Hub ports: 4
    rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0451:8142
  Device-1: 3-2.2.2:7 info: Logitech Logitech Webcam C925e type: video,audio
  Device-2: 3-2.2.4:30 info: LG USA Monitor Controls
    type: HID,abstract (modem),CDC-data driver: cdc_acm,hid-generic,usbhid
    interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    chip-ID: 043e:9a8a class-ID: 0a00 serial: <filter>
  Hub-7: 3-3:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
  Device-1: 3-3.1:5 info: Microsoft Nano Transceiver v1.0 for Bluetooth
    type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
  Device-2: 3-3.2:8 info: HP HP Color LaserJet Pro M478f-9f type: printer
    driver: usblp interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 2mA chip-ID: 03f0:c52a class-ID: 0701 serial: <filter>
  Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-9: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-10: 4-2.2:4 info: Texas Instruments TUSB8041 4-Port Hub ports: 4
    rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
    chip-ID: 0451:8140 class-ID: 0900
  Hub-11: 4-3:3 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
  Hub-12: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-3:2 info: Logitech Lightspeed Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c539 class-ID: 0300
  Hub-13: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 52.0 C mobo: 38.0 C gpu: amdgpu temp: 58.0 C
    mem: 65.0 C
  Fan Speeds (rpm): cpu: 887 gpu: amdgpu fan: 618
  Packages: pm: pacman pkgs: 1480 libs: 373 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors.manjaro.org/repo/testing/$repo/$arch
    2: https://ask4.mm.fcix.net/manjaro/testing/$repo/$arch
    3: https://mirror.easyname.at/manjaro/testing/$repo/$arch
    4: https://ftp.lysator.liu.se/pub/manjaro/testing/$repo/$arch
    5: https://mirrors.up.pt/pub/manjaro/testing/$repo/$arch
    6: https://mirror.hostiko.network/manjaro/testing/$repo/$arch
    7: https://mirror.math.princeton.edu/pub/manjaro/testing/$repo/$arch
    8: https://edgeuno-bog2.mm.fcix.net/manjaro/testing/$repo/$arch
Processes:
  CPU top: 5 of 592
  1: cpu: 10.7% command: firefox pid: 828347 mem: 4217.9 MiB (13.1%)
  2: cpu: 10.4% command: firefox pid: 2094776 mem: 454.1 MiB (1.4%)
  3: cpu: 9.3% command: firefox pid: 2710 mem: 868.6 MiB (2.7%)
  4: cpu: 5.2% command: firefox pid: 164605 mem: 491.1 MiB (1.5%)
  5: cpu: 5.1% command: firefox pid: 2105592 mem: 242.7 MiB (0.7%)
  Memory top: 5 of 592
  1: mem: 4217.9 MiB (13.1%) command: firefox pid: 828347 cpu: 10.7%
  2: mem: 2047.0 MiB (6.3%) command: firefox pid: 50355 cpu: 3.6%
  3: mem: 1796.4 MiB (5.6%) command: firefox pid: 150758 cpu: 2.4%
  4: mem: 1684.2 MiB (5.2%) command: firefox pid: 831940 cpu: 0.2%
  5: mem: 1641.1 MiB (5.1%) command: firefox pid: 1562442 cpu: 2.5%
  Processes: 592 Power: uptime: 5d 21h 3m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
Please use the </> button or the three ticks on a separate line for code like logs, and not the quote. I corrected at least the inxi, free of charge :slight_smile: Don’t have time for the smaller quotes.
On topic: no idea, but you are the second one with such problem today. I would have said we (as user agent) or you, or your internet provider is temporarily banned or limited, there were ddos attacks on AUR lately. But if that was the case, bot GUI and CLI would have been stuck.
I just tested the cli and it looks ok by me
pamac update --aur --force-refresh
Preparing...
Authenticating as: Teo (teo)
Password:
Refreshing core.db...
Refreshing extra.db...
Refreshing multilib.db...
Refreshing core.files...
Refreshing extra.files...
Refreshing multilib.files...
Refreshing AUR...
Nothing to do.
So the theory for something network related is still on the table. I am on Vodafone in Germany.
I can’t speak to any hardware, OS or software problems, but a complicating factor in diagnosis may be that Arch seems to still be having issues with DDoS attacks, which started in August. According to their status page, there have been recent issues, and may explain teh intermittent nature of your problems.
I see Teo beat me to it. Darned slow/poor typing skills!
FWIW, it’s okay just now on Greenlight Fiber in the US.
Thanks for the feedback!
I understand the network/AUR issues theory, but in my case:
  • CLI (pamac checkupdates --aur) works fine, even with the GUI stuck.
  • The GUI sometimes gets stuck indefinitely on “Refreshing AUR”, and the bottom status bar remains on “Check Updates”.
  • Logs in the GUI cannot be accessed when this happens.
  • Using strace and dbus-monitor, I can see that threads in pamac-manager are stuck in futex waits, while the backend is fully functional.
This seems to be a frontend-only issue.
The status for today shows green, so the AUR was not completely down. But after all attacks this year they might have implemented some automatic limiter. And the problem with many home ISP providers is, they leave many users sharing one ip address, so that leads to false positives sometimes. For example vodafone gives only ipv6 addresses, so everything ipv4 has to go through a gateway, which shared by many users. That has lead to problems before (for me as a user, and not only with aur).
Not that seems like a bug in the GUI. If it was the network, the log from the arrow would have been accessible, i think.
Just a data point:
When I pull up the AUR web site, I get redirected to some intermediary website
which introduces a timeout of a few seconds and it states:
“checking your browser” or something to that effect
with a progress bar.
Does not happen every time, but once in a while.
The GUI finally froze completely on “Refreshing AUR”. I was offered an option to “Terminate Pamac” in a dialog. After terminating, I was able to relaunch pamac-manager, perform a check for updates, and successfully update Firefox.
Updating Firefox wasn’t the reason I wanted to report this ; I wanted to share that case if it’s pertinent for the devs.
It’s possible that the network or AUR servers were temporarily affected (e.g., DDoS or throttling) when the GUI initiated its request. Even if the network returned to normal afterwards, the GUI thread can remain blocked if the async request did not handle timeouts or errors properly. This would explain why the CLI works and why terminating the GUI allows it to start fresh.
Upon refreshing the database, pamac does not connect to the AUR directly. It downloads the compressed database from a Manjaro-owned mirror. That server also could have hickups and showed errors in the past but a AUR-targeted DoS or your blocked IP cannot be the reason for this.
However, pamac might still fetch the PKGBUILD files after the initial database download, the error log is unfortunately not very forthcoming.
There have similar reports (however infrequently) for a while, but not necessarily the same cause.
In another similar thread @ManjaroDevOps and @philm made a few comments; linked here in case they prove useful:
pamac uses a local cache for searches, but it still has to access the AUR itself for the build.
Pamac GUI relies on a local cache for searches and displaying package information, but it still needs to contact the AUR directly when refreshing the AUR database or preparing builds. In my case, the GUI consistently stalled at the AUR refresh stage.
Even after network connectivity appeared to be restored (if we consider the hypothesis that it was what caused the issue initially) and the CLI (pamac / pacman) worked correctly, the GUI remained stuck at the same step. Triggering “Refresh databases” from the GUI did not clear the condition.
This suggests that an initial network or AUR-side failure (e.g. timeout, rate-limiting, or temporary server issues) may leave the pamac GUI in a blocked internal state, from which it does not recover automatically. Restarting the pamac GUI fully cleared the issue, while the CLI was unaffected since it starts from a clean state on each invocation.
This does not rule out other causes, but it appears consistent with a GUI-side state or error-handling issue rather than a persistent network problem.
By the way, about half an hour ago, the aur was down again, the website gave error. Now it seems at least partially recovered, but a kitty in the web browser “makes sure you are not a bot” which might have effects on the terminal programs too.
Since I’m on the testing branch, I wish to ask the moderators whether posting to the Support category like I did is the right avenue to report on a bug or other similar issues. Aside from that, can I consider this bug reported and move on?
Of course. And you can even add a testing tag to the topic — as I have now done.
Of course. :man_shrugging:
I got a slightly different variation of this issue :
I ran Check for updates in the Pamac GUI; it completed normally and reported no updates.
I then used Refresh databases in the GUI; after that, the system tray icon turned red, indicating that an update was available.
When I ran Check for updates again, Pamac became unresponsive while showing “synchronizing databases”.
journalctl -u pamac-daemon did not show any relevant error messages around the time of the GUI freeze; only normal start/stop cycles were recorded.
Using ps -T, pamac-manager was still alive with several threads, but appeared idle.
A strace attached to the process showed threads blocked in futex() waits.
No active network connections related to Pamac were visible (ss, lsof returned no results).
No package manager lock was present at that time (no pacman or Pamac lock files were found).
Running pamac checkupdates from the CLI immediately afterwards worked as expected and reported one available AUR update.
If pertinent, I wish to add that in both cases that I reported in this thread, the system had undergone a prolonged S3 suspend period.
It is easy to test:
  • try using a VPN
:footprints:
I tested the VPN hypothesis: VPN on/off does not change the behaviour.
Having Mullvad running or not (including before a long S3 sleep) made no difference.
From my observations, the problematic behaviour seems to be correlated with a long S3 suspend / resume, and occurs consistently afterwards.
The behaviour is as follows:
  1. The system is resumed after a long S3 sleep.
  2. If there are no updates available:
  • “refresh” in pamac-manager may appear to complete normally.
  • However, if I then use “Refresh databases” in pamac-manager and subsequently run “refresh” again, pamac-manager gets stuck at “Synchronizing package databases”.
  1. If an update is available:
  • pamac-manager gets stuck at “Refreshing AUR”.
In all cases observed so far:
  • There is no pacman or pamac lock.
  • pamac-daemon starts and exits normally according to systemd.
  • Restarting pamac-manager immediately resolves the issue, without rebooting the system.
NetworkManager behaves as expected:
  • Interfaces are explicitly unmanaged when entering sleep.
  • On resume, they transition back to managed state.
  • NetworkManager reports CONNECTED_LOCAL and CONNECTED_GLOBAL.
  • No DHCP errors, link failures, DNS errors, or timeouts are logged.
There is no unusual sequence, delay, or error during network reinitialization.
The only abnormal message observed is a Gdk-CRITICAL about an invalid window
G_MESSAGES_DEBUG=all pamac-manager
Gdk-CRITICAL: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
