Pamac GUI no longer launching
Hi, the Pamac GUI is no longer launching on my machine (it worked fine before)… the error message and system information are shown below. Could someone please advise on a fix ? Thanks
$ pamac-manager
(pamac-manager:3104): Gdk-CRITICAL **: 12:25:46.001: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
(pamac-manager:3104): Gdk-WARNING **: 12:25:46.035: Native Windows wider than 65535 pixels are not supported
(pamac-manager:3104): Gdk-CRITICAL **: 12:25:46.135: ../gtk/gdk/wayland/gdkdisplay-wayland.c:1423: Unable to create Cairo image surface: invalid value (typically too big) for the size of the input (surface, pattern, etc.)
zsh: segmentation fault (core dumped)  pamac-manager
$ inxi -v7azy
  Kernel: 6.3.5-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.3-x86_64
    root=UUID=ed23b311-b77f-4810-bc58-0088f4364d02 rw rootflags=subvol=@ quiet
    cryptdevice=UUID=2e1359e4-87a1-469e-9ec2-1bed3286171c:luks-2e1359e4-87a1-469e-9ec2-1bed3286171c
    root=/dev/mapper/luks-2e1359e4-87a1-469e-9ec2-1bed3286171c splash
  Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
  Type: Mini-pc System: LENOVO product: 10MRA000AU v: ThinkCentre M710q
    serial: <superuser required> Chassis: type: 35 serial: <superuser required>
  Mobo: LENOVO model: 3111 v: SDK0J40697 WIN 3305066924948
    serial: <superuser required> UEFI: LENOVO v: M1AKT57A date: 12/20/2022
  System RAM: available: 15.51 GiB used: 2.24 GiB (14.5%)
  Info: model: Intel Core i3-7100T bits: 64 type: MT MCP arch: Kaby Lake
    gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 9 microcode: 0xF2
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 3400 min/max: 800/3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 3400 2: 3400 3: 3400 4: 3400 bogomips: 27208
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs intel_pt
    invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
    msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
    pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg
    sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 630 vendor: Lenovo driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: DP-1,DP-2
    empty: DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
    chip-ID: 8086:5912 class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: DP-1 model: Lenovo P24q-10 serial: <filter> built: 2018
    res: 2560x1440 dpi: 123 gamma: 1.2 size: 527x296mm (20.75x11.65")
    diag: 604mm (23.8") ratio: 16:9 modes: max: 2560x1440 min: 720x400
  Monitor-2: DP-2 model: Lenovo P24q-10 serial: <filter> built: 2018
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel HD Graphics 630 (KBL
    GT2) direct-render: Yes
  Device-1: Intel 200 Series PCH HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
    class-ID: 0403
  API: ALSA v: k6.3.5-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
  Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
    chip-ID: 8086:3166 class-ID: 0280
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 8087:0a2a
    class-ID: e001
  Device-1: luks-2e1359e4-87a1-469e-9ec2-1bed3286171c maj-min: 254:0
    type: LUKS dm: dm-0 size: 238.17 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 238.17 GiB
  Local Storage: total: 1.14 TiB used: 67.97 GiB (5.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: AAHA4102 temp: 31.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM014-1EJ164
    tech: HDD rpm: 5400 serial: <filter> fw-rev: SM36 scheme: GPT
  ID-1: / raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
    used: 67.97 GiB (28.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-2e1359e4-87a1-469e-9ec2-1bed3286171c label: N/A
    uuid: ed23b311-b77f-4810-bc58-0088f4364d02
    used: 752 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 7704-0C44
  ID-3: /home raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
  ID-4: /swap raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
  ID-5: /var/cache raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
  ID-6: /var/log raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
  ID-1: swap-1 type: file size: 20 GiB used: 0 KiB (0.0%) priority: -2
    file: /swap/swapfile
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-3:2 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2a class-ID: e001
  Device-2: 1-5:3 info: Lenovo Essential Wireless Keyboard and Mouse Combo
    type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 4 rev: 2.0
    chip-ID: 17ef:60a9 class-ID: 0300
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 38.0 C mobo: N/A
  Processes: 261 Uptime: 4m wakeups: 0 Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1384 libs: 362 tools: gnome-software,pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.27
Not sure if it’s the same issue as this but worth trying
Hi, I saw and tried the solution in that post before making this post, but the solution there does not work here… thanks anyway. The error that I see suggests that the problem has something to do with GDK, but I don’t know what exactly.
Think I found a workaround. The config file in ~/.config/pamac had width set to some value > 71000. Checked same file on another machine running Manjaro Gnome, and it showed width = 950. Went back to file on machine with error, set width = 950, and saved file. Pamac GUI seems to launch now when I click on it from the dock. Launching pamac GUI from the terminal still generates the error below, which I’ll leave for the devs to look into, but at least the GUI is launching again.
$ pamac-manager                                            ✔  43s 
(pamac-manager:3685): Gdk-CRITICAL **: 00:52:49.937: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
