I was not sure if this was the correct place to post my question. Apologies if it is not…
I am running Manjaro stable.
I have been noticing that in the past couple of days Discover was indicating that there where updates to the system. Usually, Pamac tells me when updates happen, and usually at the same time as Discover, but not in the last couple of days. Today, I noticed that when I opened Pamac for the first time today, it was showing me that the system was updated and I knew that that was not the case because Discover was telling me updates were pending (about 1.3 Gigs).
I then opened Pamac today for the second time and refreshed my mirrors list. Instead of showing me the system is updated message, it finally was showing all the packages that needed to be updated. Are the mirrors today slow? I am in the southern part of the USA.
I checked if my mirrors list was ok with
pacman-mirrors --status
and all the mirrors were listed as ok.
I don’t want to update just yet if the mirrors might be slow. I did notice it took longer to open the Pamac GUI a couple of times. I am thinking it might be a good time to wait a couple of days to upgrade just in case.
Here is my system info:
root=UUID=920f72cd-bba8-4638-bd56-2c95fa695fdc rw quiet apparmor=1
security=apparmor resume=UUID=29279fc2-08a7-4ece-a1ee-c14a14c56eda
udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: TOSHIBA product: Satellite A505 v: PSAT0U-01F001
serial: <filter>
Mobo: TOSHIBA model: Portable PC serial: <filter> BIOS: INSYDE v: 1.80
date: 05/25/2010
ID-1: BAT0 charge: 89.7 Wh condition: 89.7/97.2 Wh (92%) volts: 10.8/10.8
model: PA3727U-1BRS type: Li-ion serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse PID:0080
serial: N/A charge: 55% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 3.71 GiB used: 2.3 GiB (61.9%)
Info: Dual Core model: Intel Core2 Duo T6600 bits: 64 type: MCP arch: Penryn
family: 6 model-id: 17 (23) stepping: A (10) microcode: A0B L2 cache: 2 MiB
bogomips: 8783
Speed: 1197 MHz min/max: 1200/2200 MHz Core speeds (MHz): 1: 1197 2: 1197
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid
cx16 cx8 de ds_cpl dtes64 dtherm dts est fpu fxsr ht lahf_lm lm mca mce mmx
monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse pse36 pti
rep_good sep sse sse2 sse4_1 ssse3 syscall tm tm2 tsc vme xsave xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Toshiba
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:2a42
Device-2: Chicony USB2.0 UVC WebCam type: USB driver: uvcvideo bus ID: 1-2:2
chip ID: 04f2:b128
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,intel,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS-1 res: 1366x768 hz: 60 dpi: 98 size: 353x198mm (13.9x7.8")
diag: 405mm (15.9")
OpenGL: renderer: Mesa DRI Mobile Intel GM45 Express (CTG)
v: 2.1 Mesa 20.3.3 direct render: Yes
Device-1: Intel 82801I HD Audio vendor: Toshiba driver: snd_hda_intel
v: kernel bus ID: 00:1b.0 chip ID: 8086:293e
Sound Server: ALSA v: k5.10.7-3-MANJARO
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Toshiba
driver: r8169 v: kernel port: 5000 bus ID: 02:00.0 chip ID: 10ec:8136
Device-2: Realtek RTL8191SEvB Wireless LAN driver: rtl8192se v: kernel
port: 3000 bus ID: 03:00.0 chip ID: 10ec:8172
Local Storage: total: 1.27 TiB used: 71.45 GiB (5.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MK4055GSX
size: 372.61 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: 1M
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000NM0033-9ZM173
size: 931.51 GiB block size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
serial: <filter> rev: SN04
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW TS-L633Y rev: TF01
dev-links: cdrom
ID-1: / raw size: 926.2 GiB size: 910.67 GiB (98.32%) used: 71.45 GiB (7.8%)
fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 920f72cd-bba8-4638-bd56-2c95fa695fdc
ID-1: swap-1 type: partition size: 5.31 GiB used: 1.9 MiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 29279fc2-08a7-4ece-a1ee-c14a14c56eda
ID-1: /dev/sda1 maj-min: 8:1 size: 1.46 GiB fs: ntfs label: System
uuid: 9E4234CD4234ABC1
ID-2: /dev/sda2 maj-min: 8:2 size: 360.47 GiB fs: ntfs label: TI102782W0E
uuid: F2F05B87F05B50C9
ID-3: /dev/sda3 maj-min: 8:3 size: 10.68 GiB fs: ntfs label: HDDRECOVERY
uuid: 3E3282B932827625
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-2:2 info: Chicony USB2.0 UVC WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04f2:b128
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
Device-1: 6-1:2 info: Logitech V220 Cordless Optical Mouse for Notebooks
type: Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s chip ID: 046d:c51b
Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
Hub-8: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 194 Uptime: 4h 06m wakeups: 4 Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.1 Packages: 1506 pacman: 1497 lib: 431 flatpak: 0
snap: 9 Shell: Bash v: 5.1.0 running in: yakuake inxi: 3.2.02
My mirrors list is:
Repos: Packages: 1531 pacman: 1522 lib: 438 flatpak: 0 snap: 9
1: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
2: https://us.mirrors.fossho.st/manjaro/stable/$repo/$arch
3: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
4: https://mirror.clarkson.edu/manjaro/stable/$repo/$arch
5: http://distro.ibiblio.org/manjaro/stable/$repo/$arch
6: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
7: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
8: https://mirror.dacentec.com/manjaro/stable/$repo/$arch
How to make sure that my mirrors list is optimized and
that everything is ok before proceeding with the updates?
I want to make sure I am doing the correct procedure...
thanks in advance for the help provided.
Note: I read in the Manjaro wiki that to update
the package database I need to use:
sudo pacman -Syu
Any other commands I need?
