Pamac GUI crashes when I click on the "Installed" tab
Hello everyone,
After the last update on December 10, the Pamac GUI crashes when i click on the tab “Installed”.
Here is the error message:
Segmentation fault (core dumped)
Then I tried reinstalling Pamac:
sudo pacman -Syu pamac-manager
: Synchronizing package databases...
 core is up to date
 extra is up to date
 multilib is up to date
error: target not found: pamac-manager
I found this suggestion in the forum, with the same error message:
sudo pacman -Sy pamac pamac-manager --noconfirm
 core is up to date
 extra is up to date
warning: pamac-gtk-11.6.0+2+g5ac9b28-1 is up to date -- reinstalling
Do you have an idea?
Best regards
snydar
Here’s one. Preface all of your commands so that they output in English. This will generally assist more users to help with your issues; example:
LC_ALL=C sudo pacman -Syu pamac-manager
sudo pacman -Syu pamac-gtk3
…would be the command, but will it resolve your coredump ? pamac-gtk3 is at version 10.6.0-2, but you installed pamac-gtk (the gnome version). Cinnamon is still gtk3.
I don’t know why, but now Pamac no longer crashes when I click on the tab… I’ll set it to done.
Thanks anyway :slight_smile:
