the minimize, maximize and close button disappears after the last testing update, as shown:
at the upper-right corner, but I can still click the position to minimize, maximize or close it even if there is no icon.
Check ‘Application Styles’ and the ‘configure GNOME/GTK Application Style…’. I noticed that I only have one option for ‘GTK theme’ rather than previously I had separate buttons for GTK2 and GTK3.
I only use the default Breath
Try renaming the file window_decorations.css
to window_decorations.css.bak
in ~/.config/gtk-3.0
,try opening a gtk to see if its working,then reboot,this should fix the problem (at least in my case it works).
It fixes the problem, thanks! So how does it work?
