Hello, when launching Pamac with libpamac-plugin-flatpak
installed and Flatpak support enabled, the application crashes on startup. Obviously, removing the package “fixes” the issue, but removes support for Flatpaks in Pamac…
Here is the output of running pamac-manager
in a terminal:
** Message: 13:50:09.966: flatpak_plugin.vala:330: refreshing flathub appstream data
(pamac-manager:14599): Gdk-CRITICAL **: 13:50:09.967: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
flatpak:ERROR:common/flatpak-variant-impl-private.h:1197:var_summary_get_metadata: assertion failed: (start <= end)
Bail out! flatpak:ERROR:common/flatpak-variant-impl-private.h:1197:var_summary_get_metadata: assertion failed: (start <= end)
From what I can tell this is a bug with the application, but any and all suggestions would be helpful.
Testing on my laptop shows this to not be the case… since it actually works! Here’s my system info:
Kernel: 5.10.59-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64
root=UUID=1e9d7841-bf50-4b3f-bda7-ab83d3f59840 rw rootflags=subvol=@ quiet
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop System: Micro-Star product: MS-7B51 v: 1.0 serial: <filter>
Mobo: Micro-Star model: MPG Z390 GAMING PLUS (MS-7B51) v: 1.0
serial: <filter> UEFI: American Megatrends v: 1.10 date: 08/22/2018
Device-1: hidpp_battery_0 model: Logitech K520 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M510
status: Discharging
RAM: total: 15.57 GiB used: 3.04 GiB (19.5%)
Info: 6-Core model: Intel Core i7-8700K bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 12 MiB bogomips: 88824
Speed: 800 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 799 6: 800 7: 800 8: 800 9: 801 10: 801 11: 800 12: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA TU106 [GeForce RTX 2070 Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f07 class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2:3 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 4480x1445 s-dpi: 96 s-size: 1185x382mm (46.7x15.0")
s-diag: 1245mm (49")
Monitor-1: HDMI-0 res: 2560x1440 dpi: 109 size: 596x335mm (23.5x13.2")
diag: 684mm (26.9")
Monitor-2: DP-5 res: 1920x1080 hz: 75 dpi: 102 size: 480x270mm (18.9x10.6")
diag: 551mm (21.7")
OpenGL: renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Device-4: JMTek LLC. JOUNIVO JV605PRO type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5:6 chip-ID: 0c76:605d
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.10.59-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Device-2: Realtek RTL88x2bu [AC1200 Techkey] type: USB driver: rtl88x2bu
bus-ID: 1-9:8 chip-ID: 0bda:b812 class-ID: 0000 serial: <filter>
IF: wlp0s20f0u9 state: up mac: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-4.3:10 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 1.42 TiB used: 440.38 GiB (30.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH31000G
type: SSD serial: <filter> rev: 70RL scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDH3500G
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Generic model: Flash Disk
size: 58.59 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 8.07 scheme: MBR
Optical-1: /dev/sr0 vendor: _NEC model: DVD+-RW ND-6650A rev: 102C
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 41.99 GiB size: 41.99 GiB (100.00%)
used: 33.83 GiB (80.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 1e9d7841-bf50-4b3f-bda7-ab83d3f59840
ID-2: /boot/efi raw-size: 125 MiB size: 123 MiB (98.44%)
used: 835 KiB (0.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: FAA2-54AA
ID-3: /home raw-size: 889.4 GiB size: 874.36 GiB (98.31%)
used: 406.54 GiB (46.5%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: f289b15e-41c3-4baa-a8e3-c22a1d3207cf
ID-4: /run/timeshift/backup raw-size: 41.99 GiB size: 41.99 GiB (100.00%)
ID-5: /var/cache raw-size: 41.99 GiB size: 41.99 GiB (100.00%)
ID-6: /var/log raw-size: 41.99 GiB size: 41.99 GiB (100.00%)
ID-1: swap-1 type: zram size: 4 GiB used: 2.5 MiB (0.1%) priority: 100
dev: /dev/zram0
ID-1: /dev/sdc1 maj-min: 8:33 size: 58.59 GiB fs: vfat label: N/A
uuid: D9AE-3423
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-2:3 info: Logitech Webcam C270 type: Video,Audio
power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Device-3: 1-3:4 info: Initio INIC-1511L PATA Bridge type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 2mA
chip-ID: 13fd:1040 class-ID: 0805 serial: <filter>
Hub-2: 1-4:5 info: VIA Labs VL812 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2812 class-ID: 0900
Device-1: 1-4.1:7 info: Valve Wireless Steam Controller type: Keyboard,HID
driver: hid-steam,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 28de:1142 class-ID: 0300
Device-2: 1-4.2:9 info: Alcor Micro Flash Drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 058f:6387 class-ID: 0806 serial: <filter>
Device-3: 1-4.3:10 info: Broadcom BCM20702A0 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:21e8
Device-4: 1-5:6 info: JMTek LLC. JOUNIVO JV605PRO type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0c76:605d class-ID: 0300
serial: <filter>
Device-5: 1-9:8 info: Realtek RTL88x2bu [AC1200 Techkey] type: Network
driver: rtl88x2bu interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 46.0 C mobo: N/A gpu: nvidia temp: 58 C
Processes: 334 Uptime: 1h 55m wakeups: 8 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1184 lib: 334
flatpak: 0 Shell: Zsh v: 5.8 running-in: xfce4-terminal inxi: 3.3.06
Thank you!
