Pamac finds aur package that is not in aur
Hi, I am encountering a weird pamac behavior: aur search returns package that apparently are not in the AUR. For instance, pamac search -a flox returns flox 0.60. However, going to AUR (en) - Packages, there is no flox package at all. Any clue?
Hi @callegar,
It sounds like your package list is out-of-date. Refresh it with:
pamac update --force-refresh
Hope this helps!
pamac outdated meta data on your system
This is an issue with pamac, it does not update the databases when using search.
Better clue would be to post actual response from terminal instead of a narrative response
If response from pamac search -a flox shows package is available from AUR
flox  0.60                                                             AUR
update AUR database as per previous posts
But response might show installed package no longer available from AUR
flox  0.60 [Installed]
I have removed/replaced 2 similar ex-AUR packages recently
websearch for aur flox shows dead links to AUR and upstream https://beta.floxdev.com
maybe this project is no longer beta ?
