Pamac fails with GOCACHE not defined
I am unable to install obfs4proxy from AUR as root user (not sudo)
pamac install obfs4proxy
Results ins
go: downloading gitlab.com/yawning/edwards25519-extra.git v0.0.0-20211229043746-2f91fcc9fbdb
build cache is required, but could not be located: GOCACHE is not defined and neither $XDG_CACHE_HOME nor $HOME are defined
==> FEHLER: Ein Fehler geschah in build().
    Breche ab...
Finished with result: exit-code
Main processes terminated with: code=exited/status=4
Checking gocache:
[root@manjaro asd]# echo $XDG_CACHE_HOME
/root/.cache
[root@manjaro asd]# go env GOCACHE
/root/.cache/go-build
I am running the minimal ARM edition on RPi 3
Pamac doesn’t use root for building.
You might be better of (in this case) with a different AUR helper or do it manually with makepkg.
Thanks! Running it as normal user worked fine!
