Pamac doesn't build packages from AUR
Hello everyone, new in the forum!
Before today I have never had a problem installing/building packages from the GUI from the AUR but now I am encountering some issue when I do it.
For example, today I wanted to install ‘portainer’ (I know from the AUR comments that it became a bit unstable) and when I click on ‘Build’ → ‘Apply’ it remain waiting for ‘Check inter-conflicts’ and the GUI is not giving me any error.
So, I’ve tried running the GUI from the terminal to see if some logs are given
pamac-manager:
pamac_transaction_clone_build_files_if_needed: assertion 'pkgname != NULL' failed
It is the same for every package I would like to install from the AUR (teams based on electron, icaclient and many others).
Sometimes it completely crashes, this is the logs i took
Thanks in advance, much appreciated :slight_smile:
Edit:
This is my full inxzi
  Kernel: 5.16.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
    root=UUID=14d91570-f762-4106-889d-9a851d6dc02c rw rootflags=subvol=@
    quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
    systemd.unified_cgroup_hierarchy=1
    resume=UUID=f1d4967a-02c4-4be4-be76-96ec8d6adaf1 loglevel=3
  Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
  Mobo: ASUSTeK model: PRIME Z690-A v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 1003
    date: 01/19/2022
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: Discharging
  Info: model: 12th Gen Intel Core i9-12900K bits: 64 type: MST AMCP
    arch: Alder Lake family: 6 model-id: 0x97 (151) stepping: 2 microcode: 0x18
  Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
    cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
    L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB desc: 1x30 MiB
  Speed (MHz): avg: 4647 high: 5108 min/max: 800/5200:3900 scaling:
    driver: intel_pstate governor: performance cores: 1: 5052 2: 5037 3: 5000
    4: 5100 5: 5024 6: 4837 7: 5048 8: 4791 9: 5038 10: 5100 11: 5087
    12: 5100 13: 5108 14: 5002 15: 4993 16: 4967 17: 3912 18: 3922 19: 3912
    20: 3900 21: 3882 22: 3931 23: 3922 24: 3886 bogomips: 152985
  Type: spectre_v2
    mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
  Device-1: Intel AlderLake-S GT1 vendor: ASUSTeK driver: i915 v: kernel
    bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0300
  Display: wayland server: X.Org 1.21.1.4 compositor: gnome-shell driver:
    loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
    s-diag: 777mm (30.6")
  Monitor-1: XWAYLAND0 res: 2560x1440 hz: 165 dpi: 108
    size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
  OpenGL: renderer: Mesa Intel Graphics (ADL-S GT1) v: 4.6 Mesa 21.3.6
    direct render: Yes
  Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:7ad0 class-ID: 0403
  Device-2: Sennheiser Sennheiser USB-ED 01 type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.1:4 chip-ID: 1395:003c
    class-ID: 0300 serial: <filter>
  Sound Server-1: ALSA v: k5.16.9-zen1-1-zen running: yes
  Sound Server-2: PulseAudio v: 15.0 running: no
  Sound Server-3: PipeWire v: 0.3.45 running: yes
  Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
    port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-2: veth97c9a0f state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
  Local Storage: total: 4.55 TiB used: 216.03 GiB (4.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P3CR013
    temp: 32.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD40EFAX-68JH4N0 size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
    rev: 0A82 scheme: GPT
  ID-1: / raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
    used: 216.03 GiB (24.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
  ID-4: /var/log raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
  ID-5: /var/tmp raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
  Kernel: swappiness: 133 (default 60) cache-pressure: 100 (default)
  ID-1: swap-1 type: partition size: 34.38 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-2: swap-2 type: zram size: 31.09 GiB used: 4.8 MiB (0.0%)
    priority: 100 dev: /dev/zram0
  System Temperatures: cpu: 27.8 C mobo: N/A
  Processes: 469 Uptime: 1h 50m wakeups: 2 Memory: 31.09 GiB
  used: 5.87 GiB (18.9%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1478 lib: 464 Shell: fish
  v: 3.3.1 default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.12
I also have issue with pamac and aur.
Google-chrome update doesn’t appear in pamac.
Gnome stable.
Please check if it is already reported or not: Issues · Applications / pamac · GitLab
I haven’t found anything suitable, so I’ve opened a new report.
https://gitlab.manjaro.org/applications/pamac/-/issues/1242
a workaround for this issue is:
pacman -S yay
yay -S ‘the-aur-package’
hope it helps.
Thanks for the tip, it works :slight_smile:
