My laptop occasionally reboots or freezes inexplicably. I suspect it may be due to an issue with the Nvidia driver. I use an external monitor and manage the switching between the discrete and integrated graphics using Optimus Manager (because my external monitor is directly connected to the discrete GPU). However, yesterday, I disabled the PCI reset feature in Optimus Manager, and I was able to use my laptop without any issues throughout the day. So now Iβm not sure what the exact problem is. I tried checking the boot logs using βjournalctl -rbβ and βjournalctl -rb -1,β but there is no information about any errors. I also checked the logs using βsudo dmesg -T,β and I found an βOut of memoryβ error. Could this be causing the reboots?
The following is the result of βjournalctl -rb -1β
9ζ 28 01:01:02 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 01:01:01 ling-20ym anacron[12128]: Anacron started on 2023-09-28
9ζ 28 01:01:01 ling-20ym CROND[12119]: (root) CMD (run-parts /etc/cron.hourly)
9ζ 28 01:00:58 ling-20ym plasmashell[3412]: 01f4:fixme:winsock:setsockopt Ignoring SO_RANDOMIZE_PORT
9ζ 28 01:00:55 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 01:00:48 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 01:00:41 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 01:00:34 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 01:00:27 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 01:00:20 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 01:00:13 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 01:00:06 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 01:00:01 ling-20ym CROND[12042]: (root) CMDEND (timeshift --check --scripted)
9ζ 28 01:00:01 ling-20ym systemd[1]: run-timeshift-12043-backup.mount: Deactivated successfully.
9ζ 28 01:00:01 ling-20ym crontab[12073]: (root) LIST (root)
9ζ 28 01:00:01 ling-20ym crontab[12072]: (root) LIST (root)
9ζ 28 01:00:01 ling-20ym CROND[12042]: (root) CMDOUT (------------------------------------------------------------------------------)
9ζ 28 01:00:01 ling-20ym CROND[12042]: (root) CMDOUT (Last daily snapshot is 9 hours old)
9ζ 28 01:00:01 ling-20ym CROND[12042]: (root) CMDOUT (Daily snapshots are enabled)
9ζ 28 01:00:01 ling-20ym CROND[12042]: (root) CMDOUT (Mounted '/dev/nvme1n1p6' at '/run/timeshift/12043/backup')
9ζ 28 01:00:01 ling-20ym CROND[12043]: (root) CMD (timeshift --check --scripted)
9ζ 28 00:59:59 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 00:59:52 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 00:59:45 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 00:59:38 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 00:59:31 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 00:59:24 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 00:59:17 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 00:59:10 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
9ζ 28 00:59:03 ling-20ym plasmashell[3412]: 02f4:fixme:virtual:NtQueryVirtualMemory (0xffffffff,(nil),info_class=1,0x19758d60,16392,(nil)) Unknown information class
and then the laptop reboot.
The following is the result of " sudo dmesg -T"
[ε 9ζ 28 01:07:08 2023] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/v2raya.service,task=v2ray,pid=940,uid=0
[ε 9ζ 28 01:07:08 2023] Out of memory: Killed process 940 (v2ray) total-vm:60046432kB, anon-rss:18645572kB, file-rss:164kB, shmem-rss:0kB, UID:0 pgtables:86028kB oom_score_adj:0
[ε 9ζ 28 01:07:18 2023] oom_reaper: reaped process 940 (v2ray), now anon-rss:976kB, file-rss:164kB, shmem-rss:0kB
[ε 9ζ 28 01:13:03 2023] v2ray invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
[ε 9ζ 28 01:13:03 2023] CPU: 14 PID: 1963 Comm: v2ray Tainted: P OE 6.5.3-1-MANJARO #1 6391e71545040710026529a97e4fbb6ca4044529
[ε 9ζ 28 01:13:03 2023] Hardware name: LENOVO 20YM/LNVNB161216, BIOS GXCN43WW 06/15/2022
[ε 9ζ 28 01:13:03 2023] Call Trace:
[ε 9ζ 28 01:13:03 2023] <TASK>
[ε 9ζ 28 01:13:03 2023] dump_stack_lvl+0x47/0x60
[ε 9ζ 28 01:13:03 2023] dump_header+0x4a/0x240
[ε 9ζ 28 01:13:03 2023] oom_kill_process+0xf9/0x190
[ε 9ζ 28 01:13:03 2023] out_of_memory+0x246/0x590
[ε 9ζ 28 01:13:03 2023] __alloc_pages_slowpath.constprop.0+0xa5f/0xd90
[ε 9ζ 28 01:13:03 2023] __alloc_pages+0x32d/0x350
[ε 9ζ 28 01:13:03 2023] __folio_alloc+0x1b/0x50
[ε 9ζ 28 01:13:03 2023] vma_alloc_folio+0xa0/0x380
[ε 9ζ 28 01:13:03 2023] ? srso_alias_return_thunk+0x5/0x7f
[ε 9ζ 28 01:13:03 2023] __read_swap_cache_async+0x143/0x2b0
[ε 9ζ 28 01:13:03 2023] swapin_readahead+0x374/0x4c0
[ε 9ζ 28 01:13:03 2023] do_swap_page+0x1ad/0xbb0
[ε 9ζ 28 01:13:03 2023] __handle_mm_fault+0x78d/0xbb0
[ε 9ζ 28 01:13:03 2023] handle_mm_fault+0x155/0x350
[ε 9ζ 28 01:13:03 2023] do_user_addr_fault+0x203/0x640
[ε 9ζ 28 01:13:03 2023] exc_page_fault+0x7f/0x180
[ε 9ζ 28 01:13:03 2023] asm_exc_page_fault+0x26/0x30
[ε 9ζ 28 01:13:03 2023] RIP: 0033:0x55f6dc2eaaab
[ε 9ζ 28 01:13:03 2023] Code: Unable to access opcode bytes at 0x55f6dc2eaa81.
[ε 9ζ 28 01:13:03 2023] RSP: 002b:00007f4a3fffed10 EFLAGS: 00010202
[ε 9ζ 28 01:13:03 2023] RAX: 000000c3a13df2f0 RBX: 0000000000000010 RCX: 0000000000000000
[ε 9ζ 28 01:13:03 2023] RDX: 000000c3a13df2f0 RSI: 0000000000000010 RDI: 0000000000000002
[ε 9ζ 28 01:13:03 2023] RBP: 00007f4a3fffed90 R08: 0000000000000008 R09: 000000c3a13df2f8
[ε 9ζ 28 01:13:03 2023] R10: 0000000000000002 R11: 0000000000000057 R12: 00007f4a3fffed90
[ε 9ζ 28 01:13:03 2023] R13: 0000000000000000 R14: 000000c0012181a0 R15: 000000c81d42e000
[ε 9ζ 28 01:13:03 2023] </TASK>
[ε 9ζ 28 01:13:03 2023] Mem-Info:
[ε 9ζ 28 01:13:03 2023] active_anon:2551688 inactive_anon:2170521 isolated_anon:0
active_file:0 inactive_file:848 isolated_file:0
unevictable:0 dirty:1 writeback:0
slab_reclaimable:15688 slab_unreclaimable:156810
mapped:2554 shmem:5 pagetables:22552
sec_pagetables:0 bounce:0
kernel_misc_reclaimable:0
free:42737 free_pcp:692 free_cma:0
[ε 9ζ 28 01:13:03 2023] Node 0 active_anon:10206752kB inactive_anon:8682084kB active_file:0kB inactive_file:3028kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:10216kB dirty:4kB writeback:0kB shmem:20kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 15282176kB writeback_tmp:0kB kernel_stack:14016kB pagetables:90208kB sec_pagetables:0kB all_unreclaimable? no
[ε 9ζ 28 01:13:03 2023] Node 0 DMA free:11264kB boost:0kB min:40kB low:52kB high:64kB reserved_highatomic:0KB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15992kB managed:15360kB mlocked:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
[ε 9ζ 28 01:13:03 2023] lowmem_reserve[]: 0 3123 23355 23355 23355
[ε 9ζ 28 01:13:03 2023] Node 0 DMA32 free:90084kB boost:0kB min:9032kB low:12228kB high:15424kB reserved_highatomic:0KB active_anon:2470456kB inactive_anon:293512kB active_file:0kB inactive_file:320kB unevictable:0kB writepending:0kB present:3280768kB managed:3214248kB mlocked:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
[ε 9ζ 28 01:13:03 2023] lowmem_reserve[]: 0 0 20232 20232 20232
[ε 9ζ 28 01:13:03 2023] Node 0 Normal free:69600kB boost:6144kB min:64648kB low:85364kB high:106080kB reserved_highatomic:2048KB active_anon:7736088kB inactive_anon:8388668kB active_file:0kB inactive_file:2544kB unevictable:0kB writepending:4kB present:21203968kB managed:20724336kB mlocked:0kB bounce:0kB free_pcp:2768kB local_pcp:528kB free_cma:0kB
[ε 9ζ 28 01:13:03 2023] lowmem_reserve[]: 0 0 0 0 0
[ε 9ζ 28 01:13:03 2023] Node 0 DMA: 0*4kB 0*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 1*1024kB (U) 1*2048kB (M) 2*4096kB (M) = 11264kB
[ε 9ζ 28 01:13:03 2023] Node 0 DMA32: 273*4kB (UME) 123*8kB (UME) 63*16kB (UME) 24*32kB (UME) 8*64kB (UME) 109*128kB (UME) 65*256kB (UME) 39*512kB (M) 35*1024kB (ME) 0*2048kB 0*4096kB = 90764kB
[ε 9ζ 28 01:13:03 2023] Node 0 Normal: 1076*4kB (UME) 189*8kB (UME) 215*16kB (UME) 52*32kB (UME) 13*64kB (UME) 4*128kB (ME) 4*256kB (ME) 3*512kB (UM) 51*1024kB (M) 0*2048kB 0*4096kB = 67048kB
[ε 9ζ 28 01:13:03 2023] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=1048576kB
[ε 9ζ 28 01:13:03 2023] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
[ε 9ζ 28 01:13:03 2023] 4284 total pagecache pages
[ε 9ζ 28 01:13:03 2023] 3403 pages in swap cache
[ε 9ζ 28 01:13:03 2023] Free swap = 8kB
[ε 9ζ 28 01:13:03 2023] Total swap = 24000508kB
[ε 9ζ 28 01:13:03 2023] 6125182 pages RAM
[ε 9ζ 28 01:13:03 2023] 0 pages HighMem/MovableOnly
[ε 9ζ 28 01:13:03 2023] 136696 pages reserved
[ε 9ζ 28 01:13:03 2023] 0 pages cma reserved
[ε 9ζ 28 01:13:03 2023] 0 pages hwpoisoned
[ε 9ζ 28 01:13:03 2023] Tasks state (memory values in pages):
[ε 9ζ 28 01:13:03 2023] [ pid ] uid tgid total_vm rss pgtables_bytes swapents oom_score_adj name
[ε 9ζ 28 01:13:03 2023] [ 344] 0 344 8497 256 81920 352 -250 systemd-journal
[ε 9ζ 28 01:13:03 2023] [ 345] 0 345 8991 209 90112 768 -1000 systemd-udevd
[ε 9ζ 28 01:13:03 2023] [ 680] 0 680 3146 242 69632 160 0 bluetoothd
[ε 9ζ 28 01:13:03 2023] [ 681] 0 681 2545 316 53248 96 0 crond
[ε 9ζ 28 01:13:03 2023] [ 682] 81 682 2443 288 57344 192 -900 dbus-daemon
[ε 9ζ 28 01:13:03 2023] [ 684] 102 684 77167 247 94208 736 0 polkitd
[ε 9ζ 28 01:13:03 2023] [ 685] 0 685 4524 192 73728 256 0 systemd-logind
[ε 9ζ 28 01:13:03 2023] [ 718] 0 718 86008 279 167936 1248 0 NetworkManager
[ε 9ζ 28 01:13:03 2023] [ 739] 0 739 97824 280 131072 1024 0 ModemManager
[ε 9ζ 28 01:13:03 2023] [ 771] 0 771 4653 214 81920 416 0 wpa_supplicant
[ε 9ζ 28 01:13:03 2023] [ 782] 0 782 7754 320 98304 416 0 cupsd
[ε 9ζ 28 01:13:03 2023] [ 797] 0 797 2716 397 69632 192 0 EasyMonitor
[ε 9ζ 28 01:13:03 2023] [ 804] 0 804 64850 288 176128 640 0 ECAgent
[ε 9ζ 28 01:13:03 2023] [ 810] 209 810 4223 251 73728 192 0 dbus
[ε 9ζ 28 01:13:03 2023] [ 869] 0 869 5732 241 81920 1696 0 python3
[ε 9ζ 28 01:13:03 2023] [ 870] 0 870 39029 345 172032 992 0 sddm
[ε 9ζ 28 01:13:03 2023] [ 872] 0 872 6517394 3982 618496 12288 0 Xorg
[ε 9ζ 28 01:13:03 2023] [ 882] 0 882 252891 696 294912 5216 0 ToDesk_Service
[ε 9ζ 28 01:13:03 2023] [ 1028] 0 1028 19697 309 151552 448 0 sddm-helper
[ε 9ζ 28 01:13:03 2023] [ 1032] 963 1032 5268 247 77824 544 100 systemd
[ε 9ζ 28 01:13:03 2023] [ 1033] 963 1033 6480 241 77824 928 100 (sd-pam)
[ε 9ζ 28 01:13:03 2023] [ 1044] 963 1044 349012 1119 847872 12704 0 sddm-greeter
[ε 9ζ 28 01:13:03 2023] [ 1047] 963 1047 2233 264 57344 96 200 dbus-daemon
[ε 9ζ 28 01:13:03 2023] [ 1818] 0 1818 612690 3712 348160 5184 0 v2raya
[ε 9ζ 28 01:13:03 2023] [ 1850] 0 1850 15063350 4712360 88526848 5951296 0 v2ray
[ε 9ζ 28 01:13:03 2023] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/v2raya.service,task=v2ray,pid=1850,uid=0
[ε 9ζ 28 01:13:03 2023] Out of memory: Killed process 1850 (v2ray) total-vm:60253400kB, anon-rss:18848804kB, file-rss:636kB, shmem-rss:0kB, UID:0 pgtables:86452kB oom_score_adj:0
[ε 9ζ 28 01:13:13 2023] oom_reaper: reaped process 1850 (v2ray), now anon-rss:728kB, file-rss:636kB, shmem-rss:0kB
[ε 9ζ 28 08:11:39 2023] systemd-journald[344]: File /var/log/journal/f993508270894493b75f29fdf5676bad/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
