Hi everyone, i’m having an issue with pamac where it randomly starts using 10+gb of RAM (I have 24gb total). This didn’t happen before but I can’t pinpoint any possible cause. I’m also pretty sure it happens everytime I leave pamac open (in tray).
Here is the output of journalctl -b | grep pamac in case it’s any help.
journalctl -b | grep pamac ✔
feb 14 13:19:03 darioque pamac-checkupdates[2133]: libostree pull from 'flathub' for appstream2/x86_64 complete
feb 14 13:19:03 darioque pamac-checkupdates[2133]: /var/tmp/flatpak-cache-5G36I2/repo-mRwDgs: Pulled appstream2/x86_64 from flathub
feb 14 13:19:19 darioque systemd[1]: pamac-daemon.service: Deactivated successfully.
feb 14 13:19:19 darioque systemd[1]: pamac-daemon.service: Consumed 2.341s CPU time.
feb 14 18:21:55 darioque kernel: [ 1380] 1000 1380 106473 1784 274432 3328 0 pamac-tray
feb 14 18:21:55 darioque kernel: [ 4464] 0 4464 6881984 2233335 54620160 4542432 0 pamac-daemon
feb 14 18:21:55 darioque kernel: [ 12902] 1000 12902 2332393 2196774 18268160 64864 0 pamac-checkupda
feb 14 18:21:55 darioque kernel: oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/pamac-daemon.service,task=pamac-daemon,pid=4464,uid=0
feb 14 18:21:55 darioque kernel: Out of memory: Killed process 4464 (pamac-daemon) total-vm:27527936kB, anon-rss:8932912kB, file-rss:428kB, shmem-rss:0kB, UID:0 pgtables:53340kB oom_score_adj:0
feb 14 18:21:55 darioque systemd[1]: pamac-daemon.service: A process of this unit has been killed by the OOM killer.
feb 14 18:21:57 darioque kernel: oom_reaper: reaped process 4464 (pamac-daemon), now anon-rss:360kB, file-rss:428kB, shmem-rss:0kB
feb 14 18:21:57 darioque systemd[1]: pamac-daemon.service: Main process exited, code=killed, status=9/KILL
feb 14 18:21:57 darioque systemd[1]: pamac-daemon.service: Failed with result 'oom-kill'.
feb 14 18:21:57 darioque systemd[1]: pamac-daemon.service: Consumed 2min 1.854s CPU time.
feb 14 18:24:50 darioque kernel: pamac-daemon invoked oom-killer: gfp_mask=0x140dca(GFP_HIGHUSER_MOVABLE|__GFP_COMP|__GFP_ZERO), order=0, oom_score_adj=0
feb 14 18:24:50 darioque kernel: CPU: 2 PID: 13028 Comm: pamac-daemon Not tainted 6.7.0-0-MANJARO #1 eb165ca8878b8cd74fb6259397f126da5e5ca371
feb 14 18:24:50 darioque kernel: [ 1380] 1000 1380 106473 184 274432 4864 0 pamac-tray
feb 14 18:24:50 darioque kernel: [ 12902] 1000 12902 7017022 2389916 55541760 4519200 0 pamac-checkupda
feb 14 18:24:50 darioque kernel: [ 13023] 0 13023 1994011 1879531 15269888 0 0 pamac-daemon
feb 14 18:24:50 darioque kernel: oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-1000.slice/session-2.scope,task=pamac-checkupda,pid=12902,uid=1000
feb 14 18:24:50 darioque kernel: Out of memory: Killed process 12902 (pamac-checkupda) total-vm:28068088kB, anon-rss:9559156kB, file-rss:508kB, shmem-rss:0kB, UID:1000 pgtables:54240kB oom_score_adj:0
feb 14 18:24:52 darioque kernel: oom_reaper: reaped process 12902 (pamac-checkupda), now anon-rss:432kB, file-rss:376kB, shmem-rss:0kB
feb 14 18:48:29 darioque sudo[15488]: darioque : TTY=pts/0 ; PWD=/home/darioque ; USER=root ; COMMAND=/usr/bin/killall pamac-daemon
feb 14 18:48:31 darioque systemd[1]: pamac-daemon.service: Deactivated successfully.
feb 14 18:48:31 darioque systemd[1]: pamac-daemon.service: Consumed 2min 11.258s CPU time.
Any support is appreciated, thanks!
