Pamac complains about not permitted operations
pamac complains about not permitted operations:
cp: preserving times for '/var/tmp/pamac/dbs/sync': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync': Operation not permitted
updates from repo and AUR result in succes, /var/log/pacman.log shows no errors.
example
pamac remove --orphans
 searching orphans ...
Preparing...
Checking dependencies...
To remove (3):
  python-toolz           0.12.1-2    extra
  libtermkey             0.22-3      extra
  python-pyrate-limiter  3.6.0-2     extra
Total removed size: 1,0 MB
Apply transaction ? [y/N] y
Authenticating as: Hans (h)
Password:
Removing python-toolz (0.12.1-2)...        [1/3]
Removing libtermkey (0.22-3)...        [2/3]
Removing python-pyrate-limiter (3.6.0-2)...        [3/3]
Arming ConditionNeedsUpdate...        [1/1]
There are some old db files in /var/tmp/pamac/dbs/sync from the deprecated community repo & mesa-nonfree that I do not need anymore. cleaned out the old files
pamac upgrade gives the same error.
The folder /var/tmp/pamac/dbs/sync is owned by root with these permissions: drwxrwxrwx files inside are owned by the user.
I would expect pamac to ask for elevated rights as usual.
$ pamac list --installed | grep pamac
libpamac                                   11.6.4+2+g1421283-1               extra     3,9 MB
pamac-cli                                  11.6.0-4                          extra     184,7 kB
pamac-gnome-integration                    11.7.1-3                          extra     14,7 kB
pamac-gtk                                  11.7.1-3                          extra     556,4 kB
for me /var/tmp/pamac is owned by “$user” as all subdirectories and files (except files in symlink /var/tmp/pamac/dbs/local/)
But how does the ownership change?
Incorrectly using sudo pamac is a first thought. But then again.
We have other examples of it changing between users on a multi-user system as well.
(so then user A cannot access because the path is owned by user B)
I might have done this a few years back, the behavior is recent, maximum a week. Checked shell history and have not used sudo in combination with pamac.
Changing the ownership of /var/tmp/pamac/ to the $user with
sudo chown -R [user] /var/tmp/pamac/ and running pamac upgrade does not show the error anymore.
Some changes were made to libpamac a week ago.
